Everything posted by lekmedm
Not true about the Nokians anymore: http://www.tirefactory.net/Hakkapeliitta%202.htm I had Nokian Hakkapalliita 2 winter tires on my wife's '98 OB, and they were absolutely phenomenal. But then again, I would expect that kind of performance from a tire designed in a country that sees so much snow and test their tires in the Arctic Circle! :cool:
Hey all, I recently bought an '06 Outback XT LTD with the OEM Navi installed. The Navi has one downside that gets to me. It won't let you program destinations while the car is moving. Now, I know this is a safety feature, but what a PITA!!! It's just not practical while on the road to pull over every time you want to program something in. Does anyone know of any way to get around this and disable this feature? I've been reading a thread on legacygt.com about this, but they haven't come up with anything yet.
Nah, a new (used) motor from a salvage yard costs around $1200, and that's if you can find one in good condition. Plenty of them already knock! Then, have that motor broken down, cleaned out, and resealed, and we're talking $3500 - $4000 in repairs. Now, I'd have to keep that car for, what, 4-5 years for it to pay off, and that's assuming that nothing else goes wrong with it in that time (or it doesn't get totaled). We would have been looking for something newer sooner than that anyway.
I currently have a '98 OBW with 2 sets of 15 inch rims. I am considering buying a newer OBW from maybe 2002-2004, and I know these come with 16 inch rims. Since my extra set is for winter tires, I was wondering if I could hold onto them for the new Outback. I just don't know if they will clear the brakes and what-nots
I was touching the little metal doo-dads (how's that for technical?) on top of the fuse, and it showed 12V. Actually, you got me thinking, so I went back to check. I tested the fuse, and there was 12V there like before. But something possessed me to pull the fuse, and it was blown! Holy cow! I checked that fuse visually before and it was OK. So now I replaced it, and everything is as it should. I think this is really weird because I swear it was fine before. And why was it showing current just before I pulled? Anyways, problem solved. Thanks to all for all the input. This site is an incredible resource.
I do not believe the 15 is a fuse. It doesn't make sense to run 2 fuses in series with no components in between. Besides, in the rest of the diagram there are also the same kind of boxes with different numbers on them. I also wonder what the F45 and B62 ovals mean. I would like to point out that my interior lights went out as well. On the wiring diagram, it looks like both the lights and radio memory work off this same circuit. The fuse in the driver's kick panel is the switched ACC power to the radio, and it is fine. I thought of the trick you mentioned about the red and yellow wires earlier and confirmed that the aftermarket radio is fine. I'm still trying to get some information before I'm only left with digging into the car and tearing out the electrical so I can check it at each junction. Stay tuned! Anyone have any ideas?
Can anybody shed some light on some parts of this wiring diagram? I'd like to know whats in between the fuse and the radio harness (and where I can find it). Also, does anyone think I could, as a last resort, just run a new wire from the fuse, through the firewall, and to the harness if all else fails?
Okey-dokey... Well, I checked power at the car's radio harness. Both ACC and ILLUM wires get power, but pin #6, MEM, does not under any circumstances, which makes sense since the Subie radio loses its memory. The thing is, the fuse that powers that line (which is under the hood) is running power. The wiring diagram does show something that looks like this running backwards: radio wiring harness ---> some other intermediate harness ---> another connection that I suspect (with the number 15 on it ---> fuse under hood. I ain't the sharpest tool in the shed when it comes to dem dar fancy symbols on wiring diagrams, so anyone, HELP!
I hate to be a PITA, but I need to resolve this issue by the end of the weekend, so all ideas are welcome. I have 2 issues: 1. my aftermarket radio doesn't show any signs of life at all, and I don't know why (and don't know if, perhaps, the radio is at fault) 2. my interior lights don't work I've checked and replaced the fuses as I mentioned above. Is there some way I can check if the radio powers up at all without blowing it up? I can send it back to the vendor for a replacement, but I wouldn't want to go through that trouble if the radio works and the car is at fault. Help! :-\
A bit of history first... my '98 OBW came with the original Subie radio/CD combo which worked fine. I replaced it with an aftermarket radio I had from another car I was getting rid of. That radio worked fine except that the tuner did not work. So now I decided to get a different aftermarket radio. I did a nice, clean job soldering and insulating the wires for the harnesses, but when I plugged it into the car's harness, nothing happened. I checked all the fuses, and they are good. I checked the harness for power, and it's also there. Am I missing something, or is the radio a dud? I put the original Subie radio back in, and it works except for the fact that it loses the station memory, which it never did before. One extra thing I've noticed is that the interior lights are out, both dome and map. Is there something related here? I can send the radio back for a replacement, but I first wanted to check out other possibilities. It just seems too strange.
Leaky Tires
lekmedm replied to Phugoid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
What condition are your rims in? I have a set of aluminum rims that have a bit of corrosion around the inside bead which makes them leak slowly. I have my winter tires on those right now. I have a second set of the same kind of rims (6 spoke) that are in much better condition with all season tires and they don't leak at all. -
Your Dad never did any maintenance except oil changes?!?!?! ...and you're at 400k km...? Changing the spark plugs was an excellent idea, but those ignition wires need to go, too! If your problem persists, replacing the coil pack may be in order as previously mentioned. BTW, has the timing belt ever been changed? What about the tranny fluid and the oil in the front and rear diffs?
Hi all! A simple (I hope) question. Where is the switch on the hatch of a '98 Impreza Outback that will turn off the door ajar light on the dash? The door ajar light on my friend's dash is on all the time, and from what I've read here, I guess there's a good chance it's due to the hatch. When I was looking around it today, I couldn't find any switch for the life of me. Actually, I couldn't find in on my Legacy Outback either! Anyway, I'm trying to find out why that light is on in her car and it's the kind of light that doesn't show the exact door that's open, it just shows that one of them is not completely closed.
