badchicken425
  1. Thanks for all your help I was able to locate a fuel pump assembly for 100.00 on Ebay. I got it in the mail today and installed it in the Baja and the little Scooby Truck is up and running again. .
  2. Can I fix it without having to buy the whole assembly?
  3. Fuel pump is pulled and there does appear to be a crack. AAAAAAh0/B23hl2I8Ydg/w907-h510-no/20140501_161926.jpg
  4. Adjusted the TPS reset ECU and it ran great for about a minute then started idling rough and died now wont start. Checking the fuel pump next.
  5. I Have a 2003 Subaru Baja 2.5 litre Automatic.That suddenly stopped running when I was pulling into a parking lot and is giving me a P0122 error code (Throttle position sensor circuit low input). It will sometimes start idle high for a few minutes then start to idle rough and die. I replaced the throttle position sensor same thing happens. While adjusting the position sensor with the key in the ignition on position I hear a humming coming from underneath car. and when I attempt to start it will flash The AT oil temp light on dash. Any thoughts or ideas? Thanks, Badchicken425 I reset the ecu and got it started it idled rough then smoothed out after time but I could not accelerate otherwise it would die. the error code and transmission light have now vanished
  6. Yah i just found some brat parts on craigslist Thanx
  7. does anyone know where to get a 78 dl wagon passenger front fender please let me know badchicken425@yahoo.com
