Havoc_66
Posts posted by Havoc_66
Well, like the topic says, I broke a wheel stud. I don't want to pay les Schwab $250 to fix it, so I was hoping someone could give me some pointers. I think I have to take off the brakes and pound the old one out, but it's on the rear wheel so that means drum brakes. Do those need to come off? Any advice is welcome! Thanks!!
OH! The car is a 94 Impreza in case it makes a difference.
No that was great, thank you!!!
If it's a head gasket your oil would look like chocolate milk, and so would your coolant. Also is there bluish white smoke coming out the tail pipe? Also a tell tale sign of blown head gasket.
Any chance you might have over filled the oil and it came back out the dipstick? It happens a lot actually!
Which way should the fan on the radiator spin? Pushing air out of the car, or pull it in?
....wow. Um, weber it is! No, it's a 4 pole. It has start and acc. Along with batt and on and starter. So I guess 5 poles all together. It's got me confused.
Eh, then it can stay. California sucks.
The california emissions are going to be your saving grace when you do have to take it to emissions. I doubt it would pass right at the moment with how much unburned fuel its spewing out.
Yeah, but those sensors get costly in the long run. I need it for now, but later?
It's actually a little worse than that... whenever the car is in the "on" position, it acts as if it is in the "start" position, meaning the STARTER MOTOR IS CONSTANTLY ON! even when the car is running!
This problem did not occur with the stock ignition switch, but the lock cylinder was so worn that it just got stuck in the "on" position with no way to turn it off or start it.
Mo... what ed is saying is that a new lock cylinder can be made for the stock ignition switch (with the steering lock bolt) and keyed for $133. You can go that way if you want, it's certain to work.
But we should address the cooling and richness issues first.
Definately, I think that fan is our problem with the overheating issue. I didn't know the starter was staying on, You never had it on that long. My fault.
But with the fan, I'm assuming it's 12v, we should find out for sure. I'd rather have it run constantly than not at all. We should investigate those "mystery wires" from the fan. I'll get a new sensor. Is there any way to get rid of the California emissions s**t?
Ok, we have a $10 shucks ignition. It works and turns the engine over, but the on and the start positions seem to be synonomous. The "idiot lights" do come on when we turn the key, but the car also turns over. There seems to be no accessory position. I have the opinion that if the car starts, then it works, but we have no acc option, meaning the car is on or it's not. There is no steering lock. Is there any way to fix this? Are we wiring it wrong, or are we gonna have to live with this for ten bucks?
Yep, here I is. Better question how do you fix the original factory ignition?
Ah, the smell of fuel in ones exhaust.
How does one lean out a Hitachi carb on an '83 EA71 with California emissions package?
Very good question, since it is my car (well eventually) I'd like to know too. Is it the blatant screw under the air cleaner that you can see without really having to remove it completely?
I broke a wheel stud! How do I fix it?
Posted
No, I've got the damn drum brakes on the rear. I really appreciate the advice! But looks like this is gonna be a pain.
