OB99W
Everything posted by OB99W
Help ! ! ! !
OB99W replied to curtisbad's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Under what conditions does it overheat? Do a search for "head gasket" on this forum and see if the symptoms of bad ones seem familiar. -
Nice pictures -- did you compare them with the ones in the links in my previous post (#7) in this thread? The in-dash shots certainly look similar. The version of Compact Disk Database (CDDB 2578) matches the one used in certain Kenwood models. Perhaps you could contact Gracenote and ask them if there's a correlation. http://www.gracenote.com/ Beyond that, it's not likely that many of us on USMB have much experience with JDM nav systems. Good luck.
I may regret asking... ...but why do either of you favor a Fram filter (that's painted blue)? When the OEM ones were Tokyo Roki, I used only those. Once Subaru switched, so did I -- to Purolator Classic. So far, no problem (other than the cup-type filter wrench that fit the Tokyo Roki doesn't fit the Purolator). As to filters rusting through, I've had it happen to the external ATF filter on the 4EAT -- road salt will do that.
If the two cylinders that cut out are paired 1&2 or 3&4, it's certainly possible that the igniter is failing when it gets hot. Once it acts up, a voltmeter in the hands of someone who really is an "electrical specialist" should be sufficient to determine if that or something related is the cause. On the other hand, if the problem cylinders aren't paired as I mentioned, which two are they?
If you decide to use resistance measurements as a means of checking the coil pack, be aware that: 1) A bad coil can sometimes check "good" if resistance is the only basis used. 2) There are sometimes errors in the factory manuals with respect to the coil testing procedure, and a good coil might seem to be bad based on that. If resistance readings don't match what the manual says, post what you got and we can probably tell you whether there's likely a real problem or not.
Oh, well if we want to do the job right, ... There are all kinds of adhesives, etc. (including double-sided tape, which for certain purposes is a simple solution) that 3M has for automotive applications. Click on the links at the left of the following page for lot's of info: http://solutions.3m.com/wps/portal/3M/en_US/Automotive/OEM/
You likely have an OEM Kenwood system. Does the following look familar? http://minkara.carview.co.jp/userid/261117/car/160672/1019101/note.aspx (You can use a web-based translator, but there isn't much more of a clue than the picture and the Kenwood link, which is dead.) Kenwood was an OEM supplier: http://www.cars101.com/subaru/navigation.html The Kenwood firmware comes on a DVD, and I believe it's needed to change both the OSD language and GPS map. If you don't have an English copy of the owner's manual, you might be able to get the info for free. From http://techinfo.subaru.com/html/index.jsp : "OWNERS MANUALS: If you are a current Subaru owner, and you are looking for an Owners Manual, please go directly to https://my.subaru.com. You will be able to view your specific Owners Manual free of charge with your free registration to the site." I hope that helps.
How have you determined that the problem is related to "the speed sensor"? If by trouble code, which code was retrieved? The '99 does have known VSS-related problems, sometimes manifesting as speedometer issues. However, "delayed engagement"/slipping is also common. See: http://www.ultimatesubaru.org/forum/showthread.php?t=87708
