mtsuberu
  1. Is it just me or does anyone else have the problem of suppliers from subaru to aftermarket places being able to distinguish "2003 imprezza outback sport 2.54". I often even after reiterating the model receive the wrong problem... so... is it possible to order the tensioner roller alone or do we have to buy the tensioner with roller attached for timing belt change??
  2. Thanks again!!!! It is running like a champ! In tank filter was dirty . I also cleaned out the tank it was also dirtier than I would have expected.
  3. Thanks again! I get a system to lean error from obd11. and the po130 from o2 sensor rears its head again. I am hopeing it is the pump? I will let you know soon. Thanks for the info I have not needed a manual till recently. Currently my frontier is undergoing a timing belt change and the soob is not playing well I have to get one running for my wife by 7am. I will let you know! THANKS
  4. Thanks to all!!! my 2003 has 104000 miles on it. Lots of start and stop driving and nassssty Montana weather to put up with. I have changed the o2 sensor the coolant temp sensor fuel filter plugs/ wires and have kept it maintained. Currently hesitation problems and high lows in idle as well as I think I can hear the fuel pump straining to pump??
  5. any info on changing the fuel pump on a 2003 outback sport? Any reason to not change it yourself?
  6. I will replace the coolant temp sensor! Thanks. FYI new plugs and wires fuel filter air filter. For some reason isopropyl helps if it is acting up. I have had this problem for several tanks of gas the last were 91 octane. I tried seafoam in gas tank it was a temp fix as isopropyl is. Hopefully this info may help.
  7. Hello, I changed my o2 sensor this helped the missing and hesitation problem, RUNS great UNTIL. Now after turning off the engine and restarting it is back to the same problem??? 2003 2.5 outback sport
  8. Blizzak ice and snow tires 2003 outback sport. I live in snow 5 months out of the year they are great!
  9. I live in Montana so I really do not know it has been cold since it started? Also some days it will run for awhile then act up? My novice impression is it needs either more or air. It sounds muffled. I first thought water or fuel line freezeup. Isopropyl helps some. Two oil changes ago I noticed the oil filler cap barely on it was not tightened all the way by the mechanic. I will never pay for an oil change again!! Is it possible an o2 sensor or throttle problem? My wife has mentioned it backfiring also. Help
  10. Cold. Also somedays it runs fine for an hour then it starts.
  11. First off let me reiterate you guys are great! 2003 Outback sport 103,000 miles. My soob is not normal... It wants to die when taking off unless rpm's are ever soooo slowly applied??? If I gas it it bogs and losses power.Mechanic says diagnostics AOK? Sometimes isopropyl helps and sometimes not? I replaced plugs fuel filter anti freeze and oil recently.
