jamesbissland
  1. Thats promising!! My trans number is TZ1A42FDBA from a NZ new 01 Outback with an EJ25 SOHC and the only trans I can find in NZ to replace it (as most are JDM import) is a TZ1A4ZFCBA from an 01 Outback/Lancaster Jap import (that I think had an EJ25 DOHC) So by the look of it, it is actually an earlier one Any info would be great if I can swap them! Many thanks in advance James
  2. sorry to bring back such an old thread!! a quick question if anybody knows the answer.. if the part number of two trans are exactly the same apart from the 8th diget (version).. can a later one replace an earlier on? ie, can a 'D' replace a 'C'? many thanks in advance James
  3. Hi All, Just wondering if anyone would have any technical drawings or cad files of a standard Ring gear and Pinion shaft for a 5 speed (4 or 8 bolt) gearbox from around the '92 or 99 vintage. Many thanks in advance James
  4. Is that nope you dont know, or nope they aren't the same?
  5. Hi All Would anyone know if the bolt pattern on the EA81/82 flywheel is the same as the bolt pattern on the EJ series engine flywheel? Many thanks in advance, James
