Posts posted by Davalos
I cringe at the sight and can hear GD's chastizement (and education) pound me in the head when I did something like that with my Brat.
Hahah - yeah. I think I've been punished enough already - you should SEE the spaghetti I've made in here! All the Kings Horses better show up ... or Humpty might not aspirate again, haha.
Man ... :-\
Yep. Goes directly to the alt. I'd be surprised if it survived... assuming that wasn't the cause of your problem in the first place.
Ok, so I'm about to have the Alternator tested.
I took the shielding off the white guy, and there's an inline spit. In actuality - the alternator portion (also white) is spliced take-off from the MAIN white line which disappears into the front clip and APPEARS to veer left (Dvr Sd) .... anyone know where THAT goes?
Next time the dealer tells you 5 days for something get on USMB and ask in the Subaru parts wanted section.
Most of the time Priority mail would beat that by 3 days. I have at least 30 of them (used).
Hehe ... I just might need a few more before I'm done poppin' 'em!
Helps a little - I am pretty sure it's the highest rated link of them all - meaning, the most juice can flow thru the black one before it blows ... which is probably BAD for me, hehe!
Okay. Before I start ... I admit - I'm a dork. I shouldn'tadunnit:
So - that's out of the way. But I did. I just need to know what do do from here:
'90 Loyale EA82 non-turbo.
Fusible link. The one towards the firewall (the black one) popped while I was heading down the expressway about a week ago. I didn't have another one, so I (gulp) 'made one' out of some romex to get me home. OK OK! I KNOW!! But that's not the end of the story.
I got home
No one could get them but the Dealer. 5 Day lead time. So I paid my $13 and went on my way ... tick tock.
Drove around ALL WEEK, no problem. All around town. 30-mile trip on expressway. And back. No problem.
Couple days ago, it happened: Was on Expressway again - and POW! No power, no nothing ... fusible lin.. uh oh ... wait!
Pop the hood, check out the situation - I had stuffed the ends of my romex (14 ga) into the sleeves of the clips of each end of the fried black fusible link. Anyway, something shorted, and heated up the wire enough to melt the black cover a bit AND cream the lower wire that feeds the fusible link body. Ouch. (I KNOW!!! I KNOW!!!).
So what did I do? If COURSE! I bypass the bottom of the body of the fusible link! (I mean ... what wold YOU do!?). I snipped the wire (white), stripped it down, and wire-nutted it to some more romex, which I then fed BACK into the good side of the fusible link (the black one), and connected to it to what was left. Wire nut, e-tape, baddaboom.
Listen ... I HAD TO GET HOME!!!
And .. I made it home.
Called the dealer. "Nope not in yet - maybe tomorrow" ... I had ONE MORE TRIP to make!
Driving around down was no problem. I think this might have to to with RPM, but I'll shut up with my theories. Anyway, I was driving to the airport on the expressway last night, and POW!! Out for the count. No problem - pop the hood, check it out - yep: same thing. Running out of what's left of that side of the fusible link, so (gulp) ... direct connection. Right from the Romex to the terminal. solid connection - good contact. Put the key in, fired right up! Wooo!
Wrong. 2 minutes down the road, POW! But this time, smoke. This time, small little special fire, made especially for me. Romex on fire. Glowing. 650 amps glowing.
I did NOT make it home ...
I KNOW!! I KNOW!! I shouldn't have done it! I KNOW they're there for a reason! I needed to get home. Yes, I walked. I've paid my punishment - I'll probably walk back, too.
Wring Schematic - Where does the wire go from the black fusible link? it's wrapped with a number of other wires and heads towards the alternator. It's a pretty beefy wire, relative to most braided copper under the hood.
And the most important question - USUAL SUSPECTS for the cause? Even tho I probably created a few more suspects, I know (yeah yeah, rub it in).
Assuming it's still sitting there abandoned along the side of the expressway, what should I bring?
RIP?
(go ahead ... let me have it!) I did the same thing when I was a kid on the lake (hmm .. ice hasn't broken yet - looks pretty thin tho ... maybe just a couple more steps ...)
Also Behind the Passenger's side Strut Tower, under the Windshield's base; you'll find a Twin Relay's Setup, that Controls when the AC Compressor and the Condenser fan Engages... if those fail, the Blower fan's Relay will Fail too; so I Kindly Suggest you to check all the Relays.
Ah ok - so they're in series ... got it. That makes a lot more sense - I didn't make the connection that they were all in tandem. Thank you!
Northwet - it's the same noise level (normal) in about all speeds. The blower has never been a speed-demon. It either works totally normally, or not at all (and we're talking the fan).
ruparts - that's weird that you have just about the same thing, just the opposite. I can't figure out if that's worse than what I have ... I kinda think it is, maybe. hehe!
Loyale 2.7 ... Wow ... that was like trying to take a sip out of a fire hose, hehe! Thanks! I think! Not sure which part of that to start with, but ... wow! Looks like I need to go back to school, hehe!
I have a weird one ... maybe. '90 Loyale wagon 1.8 stick non-turbo.
I have an intermittent fan issue. It sometimes works, sometimes doesn't. At first, I kinda thought it was random. It stated last year, towards the end of the winter. I started to notice that every once in awhile, the fan just wouldn't work - not in any speed. Other times, it would. No biggie. Minor inconvenience - end of the winter & all, right? And all summer, I don't really think it worked. I never really noticed one way or another - A/C has never worked, so it's not been even needed. But this Fall, I kinda started to realize that it was going to be an issue. By October, it was getting cold - and after awhile, I started to notice a pattern with the fan, which I THINK might help figure it out.
The fan either works or it doesn't. And if I had to take a guess, I'd say it's gotta be heat-related. If the car sits out all night, the fan'll start running within about 10-15 seconds when I start. The fan almost NEVER starts-up right away. It's those juicy few moments of anticipation that makes this so much fun hehe!
Once the car is warm, however, that's it - no more fan after that. If I get get up in the morning & go out to start him up, the fan kicks-in, and I'm nice & warm on my way to my destination. But once I turn it off, that's it - probably for the day. Any other time I start the car after that, and nothing. No fan, no heat, and BRRR!! ... no matter how many times I do it during the day, the likelihood is that I'm not getting any fan action. This is I would say 90% accurate on both sides of the equation - 10% of the time, the fan will NOT work in the morning, even when dead-cold, and 10% of the time the fan WILL work after it's warmed-up.
Any ideas?
THANKS!
Here ya go, man ...
http://www.ultimatesubaru.org/forum/showthread.php?t=90698
I gotta throw-in with "off a tooth". Sometimes, the simplest answer is the correct one. If you have crappy running, reduced compression, and fouled plug ...
You're sounding like me: "Screw it - let's replace the motor!"
Dude ... dud you ever check the timing difinitively? Last year, when my '90 Loyale snapped a belt, I ended up pulling the heads & rebuilding them because I was getting the same problem (bad compression) when I put it back together the way I thought it was supposed to be ... and it turns out I DIDN'T HAVE TO! This really sounds like a timing problem.
I'll see if i can find the thread ...
But but but ... the can said "Structural Foam" haha!
Yeah - I was hoping just to keep water out of the cabin, but I couldn't even accomplish that.
I did a search but couldn't find other threads where people had done this repair - any idea which keywords to use in the search string?
Okay, so instead of waiting for "Um, YES, Davalos, you moron - we need pics!"...
This is the rear passenger floorpan after only about 10 minutes on the road. It's all coming from the upper left side of the pic (under the plastic by the rear passenger door) - you can see the road sand building up there - anyway, it pools in the upper part there, and when WHOOSH! when you put on the breaks.
This is my (ahem!) "fix" that I thought might do ok ... but it didn't. Anyway, it tells you where the hole is, in case I didn't describe it well - I'm sure a lot of us out there know this one.
... Man, now that I think about it ... that expanding foam is gonna make welding SUCK if I end-up having to! hehe! Me & my big ideas! ...
That music was the sound of impending doom ... death ...
I noticed water in my rear passenger’s floorpan the other day when driving in the rain. Got it on the lift and took a peek around the bottom and found a big-assed hole in front of the rear tire in the rear well, directly above and in-front of what looks to be like a torsion bar mount, but I'm sure it's not.
I’ll see if I can et some pics, but my guess is this is common enough that I don’t really need to show them. I can get 3-fingers in the hole on the passenger’s side, and with ONE finger, I MADE a hole in the identical spot on the driver’s side, so if I can do it with my finger ... it's kinda bad. Between the 2 places, I shot about a can of expanding foam as deeply as I could into the cavities. Sadly, this didn’t work as far as keeping the water out of the passenger floor pan, but I'm sure it made my car quieter . I haven’t torn out the plastic from above the rocker and the rear well from the inside, but I’m 100% sure that’s where it’s coming from.
So, aside from the question of “is it fixable”? … the question is more “is this the beginning of the end”? This car has been very good to me, and has served me well, so if it had to be the End, then I would walk away still proud to having been a Soobie owner. At the same time, I have been very good to IT, and I do have a lot of investment in it – I don't mind investing more, so long as it's not throwing good money after bad. I have seen a few threads about fixing rust when it starts to get too bad, but my general experience is that It’s uaually a losing battle.
It's a work vehile - not something I cruise for chicks in (not that there are chcks out there who say "Wooo! Check out that Sexy Loyale 2WD!!! I'm getting sooo wet!...", but keeping water out is kinda important ...
Whatayall think? Need Pics?
Someone emailed this to me in one of those bulk emails filled with pics like this one ...
Most of them were like "Guy puts A/C unit in window of Chevy with duct tape," but this one was worth posting here. It actually kinda looks like the exhaust is real (at least one of them anyway). Wonder if it's got hydraulics, hehe! Anyone wanna claim it?
You are probably looking for a digi unit with a speed input but, something like this little vac gauge would do the trick. It probably lets you rotate the face for "calibration" Im guessing.
http://www.carparts.com/MILES-PER-GALLON-GAUGE/GP_2008961_N__10618.car
That's sweet. Yeah, a digital one would be cool, but I gotta take what I can get apparently. I mean, vacuum alone can't be the only thing, because it doesn't compensate for speed. but it WOULD be at least a start. It at least seems like it would give me the info "This is the Best Mileage you can get under these conditions", and as long as I keep the needle to the best mileage potential, that will appear when I do the miles-per-tank calculation. The "Hey Cool" factor might just have to wait.
This is something I can do easily enough, yes? Is it just a mount-n-connect? I'm sure there's a vacuum output I can find ...
Right. Aside from the "hey kinda cool!" factor, I'd like to get some immediate feedback on what my mileage is in real-time. I mean, i can get 46 mpg if I drive from on gas station to the next on the expressway doing 55 ... but that's a no-brainer. I wanna see what hills do, what coasting does, slamming on the gas, sitting @ lights, etc. It might not be worth the cost, but it'd be a good feedback mechanism. I do the "per-tank" thing already. And I have gotten anywhere from the 18s to the 30s in mileage.
And you're right - that device I posted was for OBDII plugs ... but its as close as I could get in a quick search - I wanted to see if you folks had done anything close to that already, or if I was gonna start from scratch.
Where can I get more info on Vacuum gagues?
hey Folks!
Anyone ever try installing one of these gas mileage meters on an EA82 or EA81? Is it even possible?
There seem to be a few options out there ... but I dunno if there's even anyplace to plug into ...
Anyone ever done this? I've been "Hypermiling" lately and have been getting 34mpg out of mine for the past few tanks. I'd love to see it in real-time.
I do construction, and I haul around stuff a lot. You can see some of my What kind of Crazy things ... thread for more of that.
Recently, I took all the seats out to remove & really clean the carpet. And while it was drying, I only put back in the drivers' seat. And it was then I realized that my (non-human) hauling capacity went WAY UP! I'm thinking of cutting a sheet of plywood into an "L" shape that will serve basically as a bed to make my Soobie into a 'utility hauler.' I can get 10' goods in there now with the hatch closed!
I already made a "Sheet Goods Hauler" with just a simple piece of angle-iron that fits over the brackets that the rear flip-up seats clamp to. I put notches in it & slide it over the top of that, and it forms a nice, secure & solid resting place for plywood, drywall, Dur-Rock, or whatever I put back there. You can slide 4' wide goods into the back if you bring it up that high - there is one "Sweet Spot" there where they will fit - doesn't fit otherwise. I have a "Roll-up" frame that I use to support the back. Looks stupid when you do it, but it works!
i put in a 1000 watt inverter to run some light power tools, instead of the spare tire i have 24 series deep cycle with a charge isolator, i want to make a jeep style spare tire carrier swing out thingy on the back soon
I'd like to see some pics of that!
Welcome Dude!
Post some pics!
On the fasteners for the trim pieces,
Try the "HELP" racks at the parts stores, lots of goodies to be found there. And try a couple different stores as they all carry different items.
Thanks - I'm actually thinking about some regular wall-anchors & setting them with epoxy - then using a super pan-head screw for it. I have this stainless steel kick going now - replacing a lot of the visible stuff with stainless ...
She's still out there drying... I'm trying to think of good ways of gettin' those seats to speed-up, hehe!
I gotta admit ... I did exactly that just now ... had been procrastinating for a LONG time ... just vacuuming it, spraying on some 'Fabreeze' from time to time ...
BUT - last Friday, we got almost EIGHT INCHES of rain in a 24 our period ... and GUESS WHO left his windows open? Hmm? C'mon - GUESS! Haha!
Anyway, after bailing it out, shop-vac'in it 100 times ... couple days later - Eeeeewwwwwwwwwwww! Naaaaaaaaaaasty! Mold had totally taken over ... completely. The smell was literally making me sick. Daaayum!
So ... I took the plunge. Side trim-covers out, center console, under-dash tray, seats out, lap belts out, then the back seat (btw - what with that mystery-wrench hidden in there?) … came out pretty well – only hitch was that duct/pipe @ the passenger’s seat that I still don’t know what is … anyway – I got a 30-gallon trash can, filled it with hot water, some serious carpet cleaning solution (the stuff they use in those truck-mounted cleaners) & let it soak in there overnight. Then I draped it over the car, got out the step-ladder & power-washed the CRAP out of it! Wow! I have to admit – I was expecting it to disintegrate – but he’s right – it held-up very well! And I used 3200psi with a 40 degree nozzle – not for the faint of heart. I did the rear carpet this way a couple days ago – took 2 days to dry because of the padding, but that’s ok.
So … then I said “Heyy …. Those seats are lookin’ kinda dingy …” and I took the power washer to them, too back seat bottom, too. I have a feeling they’ll be wet for awhile longer than the carpet! But MAN are they nice & clean!
It was also a good opportunity to check out the integrity of the floorpan – looks pretty good! I’m gonna totally blast it, disinfect it, shop vac it, get it all nice & dry & then hit it with some shaker-can rustoleum for fun. Paint is cheap. Rust is not. Plus, I like the smell of new paint.
Best news - $4.32 in CHANGE!! WOOHOO!!! And, I'm probably gonna get better gas milage, since I'm not carrying around all the extra weight in pencils, crayon, broken glass, paperclips, french-fries and pop-bottle caps I found un there. YIKES!
So in a couple days ... *IF* the seats are dry enough - I'm on my way. Anything I should hit while I've got it apart? I threw all the plastic in the dishwasher ... nice & shiney! Anyone ever try painting this plastic?
p.s. Coupla loose wires under the passenger’s seat that don’t look like they have matches. Are those options that just never got used?
Also – I’m gonna use some stainless fender washers to replace the 4 grommets in there that hold the carpet down. Any suggestions on replacements for those plastic “expando-anchors” that hold down the raceway trim pieces @ each door? They’re kinda useless & some of them sorta got destroyed coming out.
The funny thing is I had my old GL ALMOST that full of beer
Hey when you find a dock sale at $2.10 a case plus deposit of Alaskan ESB and amber and Zima (girlies had to drink something...) you tend to take all you can carry
I forget how many cases I got... something like 30 or 40
Hahah! Omg, that's awesome! Man, you're carrying about 5.4 million calories!
Well ... I may have finally done it ...
Posted
Oh, I did more than that ...
