Everything posted by starsea
Cutting off during right turns.
starsea replied to starsea's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXChecked with engine running. The light message is the bad cat one (o2 sensor) has been on since 2006. I'll check the ground.
starsea replied to starsea's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI checked my trans fluid, it is on the L so I guess that is low. It only does it with a right turn never a left. The turns are of the clover leaf type. What happens is the car starts shuddering and the check engine light goes off and on (normally it is on all the time). But the car has enough momentum to keep going and doesn't stall. After checking the fluid I think it might be because I a little low on fluid.
When I take a tight right on a highway ramp my 2003 OBW shutters like it is trying to cut off. I notice that the RPMs are kind of low and downshifting seems to correct it but this an AT. Any ideals?
Missing brake parts?
I just picked up some front pads for my 2003 OBW. They are from O'Reillys. They are the Japanese ceramic ones. There are no shims or clips in the box. Is something missing?
Camshaft pulley holding tool
starsea replied to Mikevan10's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
- Buying parts online?
starsea replied to starsea's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes when I turned the can upside down to empty it, it was bubbling out between the compression fitting and hose. Earlier when I tried using the fluorescent stuff you could see it splattered in the area.- Buying parts online?
starsea replied to starsea's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt is a 2003 4cyl Outback wagon. Yes I am interested in the discharge hose.- Buying parts online?
I need a high pressure hose assembly for my 2003 OBW air conditioner. I see a couple online from $53 - $122. What is the OEM part number?- beep x 5
starsea replied to starsea's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat was it. Thanks!- beep x 5
starsea replied to starsea's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt has an aftermarket Pioneer stereo in it. Or is this a Subaru thing?- beep x 5
A couple of months ago I cleaned the battery post on my 2003 OBW. When I cut the car off now it beeps 5 times. Any ideals?- Trailer wiring
What is the black and white wire hot wire used for on the trailer hitch connector (the one in the car that you plug into)? Electrical brakes? I'm going to use the old converter out of my Suzuki Sidekick. I need to rearrange a few wires but the color coding is the same.- 300,000 on Legacy tonight
starsea replied to gbrand's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWOOHOO!- Trailer Hitch Wiring Harness
starsea replied to abraxaas's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy 2003 OBW has it on the passenger side. Easy to find.- 2006 Outback Wagon, Trailer lights
starsea replied to juelbedwards's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy 2003 OBW is on the passenger side. Easy to find.- Dash light out
starsea replied to starsea's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks!- Dash light out
The light for my odometer and the shift indicator (on the center console between the seats) went out on the same day. Kind of sounds like a short. Does anyone know what kind of light they take or what the problem might be?- Cv Drive Shafts
starsea replied to starsea's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGee I'm glad I asked before I bought one. Probably go with MWE. Has anyone used the GCE axles?- Cv Drive Shafts
I'm replacing my cv drive shaft (2003 OBW) and was wondering if it really matters whether I use a new or rebuilt one. Napa has the new one. Autozone has the rebuilt one.- Cool timing belt change tip (crankshaft pully)
Not having a ST 499977000 tool or a face spanner wrench Doug Penland came up with this method of removal of the crankshaft pulley. (the photo was taken while we were putting it back on. to remove, the bar would be behind the upper extension and in front of the bottom one) the tools the placement- Timing belt mileage records?
starsea replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI finally changed it. 112838 miles on it. It looked like it still had some life left to it.- Timing belt mileage records?
starsea replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have 109000 miles on my 2003 OBW. Hope to change it very soon.- Timing belt mileage poll
http://www.ultimatesubaru.org/forum/showthread.php?t=65217- Parts for timing belt change?
starsea replied to starsea's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm back in town finally. This is the list I've come up with. Still don't see any O rings for the camshaft cap but I guess they are up under the camshaft cap. They caps don't come off during the timing belt change do they? The holding tool for the right side looks like something I can make. For the left side it looks like I can use two vice grips taped together. What did you all do about it? Also I didn't see a water pump for the Outback, is the Legacy one the same one? https://www.subarugenuineparts.com Description Total Cost Timing belt $62.18 Idler pulley $54.86 Idler pulley $59.82 upper and lower Tensioner $105.15 Front crank seal $5.87 Water pump, $84.14 legacy, 2.5l Thermostat $10.94 Total: $382.96- Parts for timing belt change?
starsea replied to starsea's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRight, I have a 4 cyl. - Buying parts online?
