kc8apm
Posts posted by kc8apm
UPDATE: It seems it was a slightly loose exhaust manifold heat shield. D'oh. Engine a-ok.
It's been doing it for thousands of miles now. I'm going to send some oil to blackstone at the next oil change to see if they see bearing materials; if it comes back clean, I'll start looking elsewhere.
I've got an ej18, 123k miles on it, and lately I can hear a knocking sound on acceleration, usually only in 2nd or 3rd gear, and it's very faint, as in so faint that I can only hear it if it's absolutely quiet and I have the windows rolled up and the vent fan and radio off. It only knocks under load, and it seems to be RPM dependent. It's louder going up steep hills. I'm worried it's the beginning of rod knock, but I'm not absolutely sure. I don't think it's anything with the heads or lifters because it's load dependent, and I don't think it's axles because it's RPM, not speed dependent. Does anybody have experience with this?
I stick it in 5th and have somebody in the car sit on the brakes...
1994 impreza, fwd 5mt ej18, 120k miles -- 32-33 mpg all highway driving if easy on throttle. 29-31 in my typical mixed commute.
if elmo says it's true, it must be true.
Ah that's probably it, I usually have my heater control set to mix defrost/floor or to defrost. I didn't know it caused A/C to kick on... Is this really true?
Does the A/C compressor clutch engage even if the heat/fan blower is on, but not the A/C? I know on my 2005 impreza it does, but I didn't think it did on the 1994.
it's had spark plugs, air filter, all belts, timing belt, valve cover gaskets changed when I got it 25k miles ago. It's not that it's running badly, it's not. It's that there's a noticeable transition in throttle response caused by SOMETHING, but I just want to know what it might be. EGR valve?
Ok, hopefully someone will have an idea what might be going on here. I've got a 94 EJ18 impreza. If I'm at near full throttle, pulling up through the power band, say like I'm accelerating in 2nd gear, the engine bogs and seems like it's pulling at 80%. Then, at around 2500-3000 RPM I hear a single audible 'click' like that of a relay, and the engine comes alive and starts pulling noticeably harder. This happens very frequently and has been since I bought the car 30k miles ago. Not a big deal, I'm just wondering what might be causing this.
I didn't realize my lowly ej18 had vtec, lol. I kid, I kid.
Are you looking to get real summer tires, or all season tires?
Maybe I'm thinking of the wrong header design. If it's the equal length header, though, those do NOT contain a cat. Maybe a borla style unequal length header would bolt up to the existing cat.
I've got obx headers on my 2.5RS, and while I like them, keep in mind that they'll make your car louder by virtue of their thinner walled steel, as compared to the stock headers. Wrapping helps mitigate this. Also, expect a p0420, since they don't come with a cat.
Yeah, the 13's are 5 lug. Does anybody know the rim width off-hand?
I currently have 165/80/13 tires mounted on them, as per manufacturer's spec. Will these rims accept a slightly larger, more easily find-able size, like 175/70/13?
kp
Also, on the EJ25, when it slaps on startup, it's very rhythmic, like it's happening on say, one cylinder. On the EJ18, it sounds like popcorn popping inside the motor when it's under load.
Well, if it is piston slap, how long should I expect it to last, I mean as the car warms up? Also, I've had the car for the last year, during which I've put 17k miles on it, and it's done it since day one, so I figure if it was something catastrophic it might have happened by now. I've just begun noticing it again, because it's getting cold outside in the mornings again (PA). Also, I've noticed that putting in higher octane does not make a discernible difference in the knocking...
It's got plenty of oil. This has been an ongoing chronic issue since I got the car a year ago. I've got a car with an EJ25 so I know what piston slap sounds like there, and it's not nearly as bad. Piston slap on THAT car goes away literally within 60 seconds of starting it on cold days, whereas this lasts for probably nearly 10 mins.
The ej18 does have HLA's. Any chance it's that?
Ok folks -- I've got an EJ18 motor with 107k, it seems to knock like a mo-fo under heavy load when it's cold outside (<40F) and before the car is warmed up. If it's warm outside, or after it's warmed up, it goes away. Any ideas?
Also, can someone verify if a 96 legacy seat will work in a 93 impreza?
As a result of searching, I'm pretty confident of this, but can someone please verify for me that a front seat from a '98 Impreza will fit in a '93? Both seats are manual, although I have a 4 door and the prospective donor is 2 door.
Just wanted to get some confirmation on this -- it IS possible to do an EJ swap into a 2WD car, right? I just want to make sure that I'm not overlooking anything. Can the stock 2WD clutch handle the power? Also, I know this isn't exactly the right forum, but are the springs interchangeable among all the EA82 series cars, i.e. can I put RX springs into a DL?
Kevin
Just wondering -- does anyone still make struts for the RX (coupe) anymore? I've searched through the forum, and through KYB's catalog, but that just left me confused.
Kevin
Don't know if anyone has posted these before. They're translated via Babelfish, and the translations are a bit nonsensical.
Delta Cam roll call
in Products for your Subaru
Posted
1000 Grind 'torque' cams, SOHC EJ253, no probs, work well.
