DWM650
Everything posted by DWM650
  1. How to use SeaFoam :-p DaveyMac 2002 Accord EX
  2. Yea I compressed mine for kicks, but i had already bought a new one. Just because it came highly recomended by a Subie Mechanic that does this for a local deaership. He said its not worth the risk, What to say after 100k of use that it won't fail after disturbing it.:-\ The damage would cost more than the piece of mine.
  3. Tues. I traded my 99 OBW for a 2003 Honda Accord EX with 58000 on it. I'll still be lurking around here, I love Subies but couldn't pass on this Deal. Thanks to all who help me & I'll helping Others. DaveyMac
  4. Looking at Drivers side, Cams are loaded (spring pressure) THEY WILL ROTATE as you release the belt. I used a buddy to hold with wrenches and slowly release spring pressure. they will go in opposite directions about 1/4 to 1/3 of a turn. Just allow them to move SLOWLY:eek:. Check out this article It fully explains this. One last Item Are ya replacing the Tensioner ? Because its a hydo piston that if you try to RECOPPRESS it most likely will Bend the rod. No tension on the belt, Belt jumps time, Wipes out evey Vavle in the engine:slobber:. Might as well do Water pump and Check Oil pump bolts while your in there!!! DaveMac:brow:
  5. New Problem as of Last Night, When I turn key off all my doors lock. Other than that my keyless entry works ok, drivers door switch works (can't remember if its suppose to work with ING off,but it doesn't now.) Anybody else seen this before? I'm afraid of getting Locked out! Dave
  6. DITTO... OEM only on the T/stat. Factory ones are 3 stage. Same goes for the Waterpump use OEM only, or ya be doing it agian soon.
  7. Had the same issue, did all of the simple stuff first. replaced coil pack wires NGK lazer tips @ $12.00 a plug Rear O2 sensor seafomed the IACV Then adjusted the Vavles, 7 out of 8 ex. Way over tight this at 102000 mi. No more CEL po301 & po303, + 25mpg.
  8. Problem fixed, Fuse for lighter was out, wich is also power for control side of one of the Main fan relays ??? WTF. Anyway ECM saw that M. fan circuit, inop & defaults to sub run low speed all the time to protect engine. Once fuse was replaced :grin: . Everthings COOL.
  9. No??? Ithought I was on the right track. I had a Subaru Tech. put Select Monitor on it, which showed FI temp sensor well in spec (it should new and replaced a week ago). But engine temp way too cool, He felt Lower hose it was cool to touch. So I went after Water Pump and T/stat, (found rt side timing marks off 1 tooth, Car never idled & ran better now) Also I moved around relays, 2of them when put into Sub Fan Control would turn Kill always running Fan & other 2 would let fan run all the time. Well fan would cycle on after repair but never really cycle off. As of last night, After car sat for 8hrs. Fan came on at start up, bottom hose Cold to luke Warm. BTW Tech Look for the infamous HG, NO obvious signs of that.
  10. I think I have it solved.I will post back with what I find:banghead: So that everone can benfit.
  11. Thanks for replys, but NO_ONE is reading the First Post. Fans are ALWAYS ON! Yes its having cooling Issues, Its to cool. main fan NEVER Turns Off. Anybody got any Ideas? Its Not the relays, and its not the Coolant Temp Switch. Dave
  12. Main fan runs all the time,right side fan (engine running) other, left side fan will Cycle with A/C compressor or Defroster. Main was running this AM at start up 5 deg. D.
  13. Help Please, 99 OBW m/t Cooling Fan allways on ? with engine running.(even ice cold engine) Things Ive done are : Tested and swaped around Relays under the hood, changed and tested before I installed new CTS, Good engine and body grounds. Tested Main Fan relay above fuse box inside car. Fan will quit when Sub Control Relay is pulled. I fear ECU is going to lunch ? NO codes or CEL yet. Dave in Upstate NY
  14. Thanks Josh, Metal plate is under hood on left shock tower. Anyway I'll look agian Ser#, paint code other info is there . Dave
  15. Im looking for the prodution Date on my 99 OBW. Looked at the Metal plate on the left shock tower & Drivers door Jamb, but I don't see the date. Dave
  16. Pleiades, thats what I narrowed it down to "an injector going to lunch". I Checked with a copule of shops and my Dealer. going rate for cleaning services are $99. to $150. Any way Im thinking cleaning just because of mileage & age. Ive done 3 techron treatments already with some positive results, but because I bought car with 87k in Sept. 03 (now 96k) who knows what the previous owner did or didn't do? Some times it runs GREAT. Dave
  17. Well After through Checks & Inspection of electrical connections,hoses, vacum lines I have made the car run 90% better. Still I minor occasional skip at idle, But not like it was and so far NO CEL. Fuel milage up to 24.5 from 21, but this is winter time here in the Northeast, So I don't expect a lot. When I clean the throttle body, it was preaty gummy (96K). So I belive Injectors and Combustion chambers are also. Im toying with the Idea of "Air induction and Fuel cleaning service. Like BG services. Any one want to offer Pro or Cons on this? I've done a couple of Techron treatments Dave
  18. Seven Sisters thanks for the Larry Carley Site! Ive, preaty much rule out mechanical issues with a strong compression test, in my 1st post. But a fuel injector maybe, DTC's are for Cyl's 1&3 or fuel supply problem for that side of the engine ??? Both are on the same bank. Anyone know how to ck the spray of an injector. Or the strengh Dave
  19. Here's what Ive Done or replaced for code(s) po301 & po303: Replaced: Plugs, Wires, Coil Pack, now have NGK BKR5E-11 took out PFR5B-11 gaped .044 O2 sensor upstream (front) PCV, Air Filter,Gas filter Tested: MAF TPS Igntion timing Compression Happens hot and idleing randomly almost after engine runs, shutdown & restarted & allowed to idle for a short period. What am I missing? Plugs look Lean . you can almost here it miss at the tailpipe, when it does it:banghead: Thanks for any Input Dave
  20. PO301, CYL 1 MISFIRE DETECTED PO303, CYL 3 MISFIRE DETECTED Warmed up engine after it sits for 5min, and then restarted and allowed to idle. You feel the engine skip and shake just before it produces codes and CEL comes on. Ya also can here it miss at the tail pipe. Daveymac ":cornfuzz: ps, this is random "not all the time"
  21. Already replaced wires with plugs. Ordered coil pack today. will have it Wed. 12/30 I'l post back with results. BTW how do I know what Generation Motor do I have??? DaveyMac
  22. Thanx's for the reply. It defiantly has an interment skip at idle, more when cold. also a bit of a hesataion if you snap the throttle quick anytime. DaveyMac:eh:
  23. Hello everone Im new to your board. Glad I found it ! I have a 99 OBW, 95K on it. 5 speed trans. About every 3-4 weeks I keep getting CK. engine light, fault code(s) Misfire on Cyl 1 & 3? New plugs NGK and wires were replaced. Power and performace are good, fuel milage is around 21- 22 mpg. I think it this poor? Anyone have a suggestion were to start? DaveyMac
