A little more information. Daughter (yah, I know) drove the car said it just started to run rough. I confirmed and found the #1 cyl was not firing. There was spark, but I am unsure about fuel. I threw in a set of plugs, no change. So I lept to the assumsion of a timing belt , orginal 88K no history of this ever being done. Thought it couldn't hurt. So it was kind of running when I took it apart. I tried to be very careful about timing marks, making sure the piston was fully TDC by removing the sparkplug and using a pencil. After installing Timing belt, I manually turned the engine over several times to make sure everything moved. When I turned the key, the engine kind of caught ( I mean like when the timing is bad) then cranked smoothly, when I held the throtle to the floor it would kind of fire but no pops.
Today, I will check spark, gas and do a compression check. My thoughts is that the computer shut down the #1 cyl. and I need to eval the check engine light. Any resource is welcome.
