New Suby Question
Just leased a new Forester and I love it! I have a question that I don't want the dealer to screw me (more) on. Can I do the oil changes myself on my car even though it's leased?
00 OBW Disc Brake Diameter
legacyak replied to legacyak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust for the record, it is 10.9 inches.
Does anybody know the diameter for the front discs on a 2000 OBW? I have had several sets of rotors that have not been the correct diameter. This causes a ridge to build up on the pads and vibrations when braking. Does anybody know the factory diameter of the front discs???
Piston Slap Redux
legacyak replied to fleming442's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPeople who buy Fords probably buy their car at Walmart!
2000 outback, rough idle, check engine light, bad mpg
legacyak replied to xbrandonedgex's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds possible that it is the coolant temperature sensor.
Im baaaaack
legacyak replied to Crawlerdan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have the exact same 00 OBW, same color, same 5 spd, but 176,000 miles. As far as I know the struts for foresters are the same height. Just out of curiosity, have the head gaskets gone out yet on your car? I didn't have any problems with mine till 150,000 or so.
Where to find OEM plug wires?
legacyak replied to etc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.subarupartsforyou.com Great service.
hey guys. anyone have an alternator?
legacyak replied to EA82Loyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXebay
ABS light
Living through the wonderful Northern Indiana winters full of lake effect snow really makes me appreciate my 00 OBW. This morning was pretty slick and I slid a little bit at a stop sign and my ABS light came on. It stayed on for a while, but once I restarted my car up again it was gone and has stayed off. Could this be normal? I also have a torn rack and pinion boot that I noticed the other week that I need to get fixed. Could that have any effect on it?
legacyak replied to screwbaru2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes I agree, I've spent a lot of money with them. They have always been great to deal with and send the correct things. My personal favorite parts place!
Changing CV joint
I am going to replace the drivers side CV joint on my 00 Outback this weekend. Last year I replaced the passenger side one and the pinch bolt that holds the steering knuckle to the ball joint was an absolute **** to get off. When the car was built they did not put anti-seize or anything on the bolts so they are exteremly easy to strip and can be a huge problem to get out. Anybody else have similar experiences? I've been spraying it down with PB blast for the past couple of days in hopes that it may make it easier. Any other ideas?
Synthetic Lucas Oil Stablilzer
What are your guys' thoughts on the SYNTHETIC Lucas Oil Stabilizer. It's way way way way less thick than the regular stuff. I've heard it pretty much eliminates dry starts. I think it may be a good thing to add. Should I or Should I not?
Oil Change Interval
I have a 2000 Outback with 165,000. I just changed the oil on Saturday with Valvoline Maxlife FULL synthetic and a bottle of the new Lucas Synthetic Oil Stabilizer. Can I go 5,000 miles easily before changing oil? Is it safe?
Advice on looking for a Sube
legacyak replied to drew and not u's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHi Drew. Welcome to the Subaru world! You will be very happy! The things to definitely look out for on the years and models you specified would be head gasket repairs and timing belt changes. The 2.5 is a good engine, but unfortunately the head gaskets are the most notorious enemies for this engine. Check to see if the head gaskets have been replaced. Also make SURE if you find a Sub with over 100,000 miles the timing belt has been replaced. If you can find a Subaru within those years that has not had head gaskets replaced, I would haggle the seller down and use the savings to replace the head gaskets and various other components. You can easily find a good mechanic and OEM parts for under 1,500 to do the job. Or you can jump in and do the job yourself! Changing timing belts every 100k and regular oil changes are the keys to keeping a Subaru long running.
Oxygen Sensor Project
I'm going to tackle the front oxygen sensor tommorow. I have a 22 mm wrench and a can of PB blast. Is that all i need?
legacyak
