wont start when warm
desdinova replied to desdinova's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo it happened again. I tapped the starter a couple times with a tire iron and it started. It's definitely the starter. Thanks for all of your responses. I love the site.
I bought a 2001 outback about a hundred miles from my house. Half way home I stopped for gas and it wouldn't start again. Plenty of voltage and tried it in neutral also. Nothing. No click or anything. After letting it sit for about 20 minutes it started right back up. Hasn't done it since. Any suggestions ?
15/16 compatibility
desdinova replied to desdinova's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthank you. i found them on craigslist and she swears they had 15's on them so i drove to spokane and got them. i should have looked for a stamp. i got home and was cleaning them before i saw the 16 on the inside. she says she had them on an outback so i should be okay. unfortunately i have fairly new tires on mine and wanted to simply put my rubber on them. now if i use them i'll have to buy new tires also.
- 15/16 compatibility
replaced water pump, car wont start
desdinova replied to desdinova's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdisconnected and replugged the two large clips and the horn works, but still no nuttin.
desdinova replied to desdinova's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi've done something else. bumped a wire or something. got the timing marks correct but there is nothing. no lights, no radio, no turn over.
desdinova replied to desdinova's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthank you. would that prevent the car from turning over ?
I have a 98 impreza wagon. i replaced the water pump which obviously entails removing the timing belt. i took off the alternator for convenience also. I lined the paint marks on the cams and the arrow on the crank gear to 12:00 o'clock when putting it all back. the car doesn't turn over at all. nothing electrical no turn over, no radio, no nuttin. is there a sensor that detects that is so out off time that it wont allow it to turn over at all ?
where to mount speakers in ea81 hatchback
i just went to wal-mart and got some "put it together yourself " speaker boxes. i left some slack coiled up and if i had to haul something i could slide them around and also set them on top of the car for outdoor events. they also have those quick release clips for fast removal if you have to . my brat quit to where i had to leave it over night and it was a small relief to be able to take my expensive speakers with me . just a thought .
weber idle down question
thank you ... both .
i have a weber on an 86 brat . when i come to a stoplight it idles at 2000 until i give the throttle a tiny blip and it drops back down to between 700-800. so far i have only carb cleaned eveything and got a new throttle cable . i also lubed the new cable in case they didn't . what next ?
empi axles
i purchased some axles off of ebay thru a place in las vegas called meyers automotive supplies . they were $57 each with free shipping . i don't have any connection to them in fact i live in washington state . i just thought that was an awful good price and their ebay guru jeff went out of his way to be helpful . the store name on ebay is - your_import_parts_people7
ea 81 axles lengths
i put a 4 speed tranny from a 81 hatchback in an 86 brat . i ordered new axles from empi an used the 86 brat as my vehichle locator . the ones they sent are subaru but they are about 2 inches too long . do they make different lenghts or am i missing something obvious ?
largest tire size on an ea81?
185/80/13 but they are hard to find . try firestone . they sometimes carry it in their fr380 series .
push bar question
is the second generation short bar the only one that will bolt directly on to an 84 brat ? i have a long one that does not fit .
desdinova
