Everything posted by kinasabi
99 tt GT motor into 94tt GT
kinasabi replied to kinasabi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhi yea its R/H drive new zealand
swapping a 99 legacy ej20TT auto motor into a 94 legacy,any help out there,already noticed the heads are different was going to use my manifold maybe i can bolt the 94 heads on to the 99 block:eek:
torque settings
kinasabi replied to kinasabi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX89 rs single turbo ej 20 i think
torque settings
hi im looking 4 the torque settings 4 the head and camshaft bolts any help appriciated
2wks@still no go re-mixed atf @front diff oil
kinasabi replied to kinasabi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks i think thats wat i did installing the first one it made a pinging noise asi was tightening the bolts but i thought it just was just going on 2 the locater tabs thanks again:burnout:
kinasabi replied to kinasabi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhi i decided on putting another auto trans back on jus took old 1 off with mtr in and noticed dots on axle gear and andtrans drive gear wat is the importance of lining these back up;)
kinasabi replied to kinasabi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXswt jus got trans out do the dots on the axle gear and the cog on the trans have to line up wat are they for
kinasabi replied to kinasabi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwill i b able 2 put 5speed off 96RS on to a 95GT auto is there a bearing?looks like a lot more room on the rs do i hav to take mtr[mtrs] out.....again
2 weeks and still no go
kinasabi replied to kinasabi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXno no flow
kinasabi replied to kinasabi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanx m8:grin:
kinasabi replied to kinasabi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXna no flow is that the pump is it will i have 2 drop mtr again 2 fix and how:dead:
thought the prob was mixing the oil up but i have no flow from the hoses that go 2 radiator wat would cause this could it b the oil or the pump in the trans would i have 2 take mtr out again 2 fix pump and how new 2 this so finding it a bit hard 2 reply so thanks 4 any input if i cant get back may b i should jus put 5speed on and do away with the auto::-\ should b fun
kinasabi replied to kinasabi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthank s 4 all the advice every 1 wat i did was use donor moter as old 1 was cooked the tras was fine if nothing wrks i have 5 speed out of 96 rs i could use any probs that u know of apart from the obvious
kinasabi replied to kinasabi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhavent checked have jus started draining
mixed transaxle oil with atf after rebuild and stupidly still used it in the auto transmission on95 gt wagon motors goin but no drive will this cause the problem the power light comes on at start up and shut down theres no drive or reverse what so ever how do i get the mixed oil out of torque converter:lol:
