Brat topper value?
I have a Gen 2 in Wichita (fiberglass) that I would give up very cheep if someone wants to pick it up.
Topper weatherstrips
I have the same topper and was going to try one of these but haven't gotten around to it yet. Let me know what you think http://www.cleanseal.com/information-04.htm https://www.custompickup.com/shop/index.php?action=category&id=6 http://www.extrudedsolutions.com/index.htm between the 3 there should be one good one. Good Luck:burnout:
Happy B day Mick!!!!
Happy birthday dude! Glad you had a good day off:clap:
I cant fix my brat
Mine did the same thing, it had sat for 2 years. it also had sat with almost no gas in it... after 2 tanks of gas and 2 cans of Berrymans (my personal favorate) and a pair of new filters, I ran it low on gas, put a 5 gal. can under the drain with a paint strainer and drained the tank. then took the line off comeing to the filter with the cap loosend and used short blasts of air (wach the pressure!) I couldn't believe how much varnish I got out. it came out like snot the dried in the filter. it was enought to float around and restrict the tube that feeds the pump. the cleaner probably would have desolved it eventually, but this really seemed to take care of mine. It just dropped the fuel pressure enough that it couldn't keep up in the upper gears. Works great now. good luck!
Vacume restrictors?
Is my 86 Brat suppose to have vacume restrictors going to the vacume control valve? From what I have found they go in line to the air cleaner. any pics or part numbers would help greatly! It sat for 2 years before I got it and have it running pretty good but still chasing a few bugs and I think this is one. Thanks!
Can't Find Replacement Tail Light Socket (Pigtail)
My 86 Brat had a front turn signal bulb stuck in the socket and had to distroy the socket to get it out. got a genaric pigtail from local Autozone, it didn't fit of coarse, but I found out if i put it in from the inside the flange held it. Put a good bead of silicone on it (was going to epoxy it but my luck I will need to do this again) and put in for good. Worked great. good luck:burnout:
pics of my 80 what yall think?
I like it, I think I need to take the pics of my brat in the tunnel untill I get it painted!!. Looks good:clap:
bucking problem...almost completely gone..but still there :(
My 86 brat is doing this, but mine is fuel problem. anyone know if there is a strainer in the tank before I take it down????? Only has 185,000 miles, can't believe it might be the fuel pump already. yes I changed the filters already
Lhand1900
