vagonan
  1. Thanks for the info. That high altitude sensor was nowhere to be found. Still investigating for code 22.
  2. Thanks for the information. Hmm... So where exactly is the high altitude sensor and what would it look like?
  3. I recently picked up a 1983 Brat in California and trying to fix diagnostic code 22. According to my factory manual it's a problem with the high altitude sensor but the manual tells me to check instructions included in that kit. Also would like to know the part number of the ECU that should be on a '83 brat with CA emissions. Any information helps. Thanks.
  4. Thanks for the info:) I took a tap/die set and tapped the holes just a bit. 6x1.0 10mm worked great!!
  5. I've got a '83 Brat with loose fender liners (held on with duct tape). Tried out some generic trim clips but no luck. Does anyone know what type of clips are used and where I can get them?
  6. Just installed a set for my '83 Brat. Great service, excellent quality. Highly recommended!!
  7. MWE has a great reputation - His axles have excellent quality, and he's a great guy, easy to work with. He's got remanufactured axles for $75. For an additional $20 per axle, he'll build them with new CV joints.
