Everything posted by Kyoung
4EAT Auto Trans?????????Shifts too early!!
I asked on another thread about this, they said to start a new one so here goes. I got this 88 GL10T AWD with a 4EAT that shifts under 4000 rpm when at WOT. I was wondering if this is the nature of this tranny or if there is something I could check? Thanks, Kevin
Impreza 4EAT into a 1990 Loyale Turbo?
While talking about 4EAT, is it possible to make it shift at higher RPM? My 88 GL10T shifts @ about 3000-3300 when floored, just about the time it starts running good. Or do I just need to shift it manually?
1990 loyale died and won't restart
Need to get a Noid light and see if the injector is getting a signal from the cpu..........if it is than check the injector with an olm meter to see if its any good!!:Flame::Flame:
EJ22 swap with existing 4EAT
So my 88 GL 10 Turbo would be direct bolt in to an EJ swap? What does the wiring harness cost? Thanks, Kevin
EJ-22 swap, Project Loyale
I am interested in doing this on my 88 GL10. Has any body done it with an Auto AWD, thats what my Gl10 is. Any input would be appreciated!!! Thanks, Kevin:grin:
87 gl10 turbo
GD , thanks for the quick response, I am considering this option because my 88 only has 96K on it, but the trouble codes and the occasional NO STARTS are drving me craZy...I am just interested in a reliable daily driver, got a 65 mile daily commute... Kevin
87 gl10 turbo
Hey GD, what is this EJ22 ? Where do you get the adapter plate?Does it work with an auto AWD? What do you do about an ECM? Thanks, Kevin:popcorn:
Air bag shocks
I have a set of air shocks that are probably good, removed because of compressor issues...might be into selling them.
Fuel vapor separator--maintenance item?
What happens when you top off your tank???????? Mine has done a NO START twice after I filled the tank 88 GL-10 Turbo wagon:popcorn:
wHAT KIND OF MUFFLER ON MY 88 TURBO WAGON
Are the stock mufflers real restricted? My 88 doesnt seem to run good til its wound up over 4k... What kind of gas mileage can i expect??????
