zedhead
Everything posted by zedhead
	The conditioner will do nothing if the gaskets are leaking. More than likely they are. As a matter of fact, the conditioner is really a stop leak. Not like Bars, or similar. Most, if not all new engines are treated with some type of stop leak from the factory. It's cheap insurance for the manufacturers. They need to keep the coolant level IN THE RADIATOR full. Just filling the expansion tank won't cut it. They could make it home if they keep the rad full. But a HG job is in Their imediate future.
	It sound like You have a combination of problems. First: the O2 sensor bung. Second: the O2 sensor wiring. If the O2 sensor bung came out. You need to get it sealed. They are normally welded to the pipe. O2 sensors are VERY sensitive devices. Very sensitive to resistance. Any added resistance can knock the sensor out of its acceptable operating range. If the wiring is compromised. It could very well be adding resistance, and be causing Your problem.
	Personally, I've never had good luck with after market O2 sensors. Have You tried replacing the secondary O2 sensor? It tells the ECU if the cats are operating efficiently. IC that You have changed both sensors. Some guys have had good luck running these, when a free flow, or catless exhaust is installed http://www.energeticforum.com/renewable-energy/1387-o2-sensor-modification-using-spark-plug-non-foulers.html http://www.scoobymods.com/forums/showthread.php?t=5468
	With the mileage on Your engine, I'd say that 3-4 MPG drop in the winter is prolly about right. It's a combination of many variables that is eating up Your fuel economy. Prolly the biggest culprit is the very poor performing fuel that We are forced to burn in the USA. Not only does the Ethanol content go up in the winter mo's, but they add other performance robbing chemmies also. Can You elaborate on the "exhaust seeming loud at times"?
Head gasket?
zedhead replied to floater's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
It IS a tell tale sign. There's a difference between radiator sealers, additives,etc, and the oily mess that phase 1 EJ25's deposit inside the reservoir. Also, if the car has seen any kind of decent maintainence, there should be nothing but clean coolant in the reservoir. Another tell tale sign is if the gunk smells like fuel/exhaust. Cold starts will allow the unburned fuel/exhaust gasses into the coolant. So, Smell the gunk! -
Head gasket?
If the overflow tank is all gunked up, it's a telltale sign of head gasket failure. You can do a coolant pressure test to confirm that the pressure is over 10 psi. Also, the Exhaust test kits will tell You if exhaust gasses are present in the coolant
