Everything posted by mdryan
Easy Spark Plug Change?
mdryan replied to mdryan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNippon Denso are the best but some times hard to find. Their electrode alloy contains tungsten and they seem to hold their gap longer than other brands. MDR
Where to find TSBs?
Hello, Can anybody direct me to a site to find Subaru TSB for 1998 Forester? Thanx Mark
Frosted Headlights: 96 Outback
mdryan replied to wrongturninwv's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEasy Off oven cleaner will remove the yellow. Don't get any on the paint and rinse well before coating with an exterior grade clear gloss finish, acrylic or aliphatic urethane.
mdryan replied to mdryan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for the response. I'm gonna try my Subaru supplied tool. A few other pointers; 1. Warm motor before unscrewing plugs, the heat expands the alloy head so the threads won't gall. 2. I always use anti-sieze on the sparkplug threads for reinstall. Locktite now offers anti-sieze in a glue stick typr push up sleeve - less messy. Mark
Howdy, Does anyone know an easy way to change spark plugs on 1998 Forester w/ 2.5 motor? It sure was a bear with ratchet and 3" extension. Thanks Mark
2 Gasket Kits for 96 Outback?
The Subaru dealer shows 2 different engine gasket kits offered for the 1996 Outback w/ 2.5 liter twin cam. There's a $100 price difference between the two. Does anybody know how these 2 kits differ? Thanks
Engine Gasket Kit - 1996 Outback 2.5
Does anyone know a good source for engine gasket kits for the 2,5l twin cam? I'm getting sticker shock from what I've found so far. $250.00 for a 34 item kit which is mostly rubber O Rings. Jeez.
Wrist Pin removal - Ideas?
mdryan replied to mdryan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'll say they can get stuck. I spent a few hours using various hooked devices then I went to the local rental place and got a slide hammer with an internally expanding jaw and whack whack, I'm done. Thanks for the post.
two technical questions
mdryan replied to nu2subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSpark plugs can feel that way, and you're probably okay. With an aluminum head it's best to remove the plugs when the engine is warm. Reinstall in cold engine. I would also use anti-seize on the spark plugs when reinstalling. Good Luck
Does anyone have any good ideas for removing wrist pins on a EJ25 motor? I gotta believe there's a better way than what's shown in Haynes. Thanks Mark
getting Subaru Tech documents
mdryan replied to tubaman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds interesting. Can you send a .pdf? Thanks mark
mdryan replied to tubaman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCan somebody post an example of the Subaru Tech Info .pdf? I tried to sample the product from the web site. Tha 72hr pass sounds like a good idea, but I'd like to preview the product. Thanks Mark
