Posts posted by DRFVDR
been on here for ages this is my second or maybe third username
The body shell is totally gone so I gets the engine for a 3rd back for the RX,and sell the best bits off, I have already recouped what it cost me
Just to add to this old thread
LPG is really only good for cutting as it does not get hot enough for a good welding flame...
the torch has handle should have 2 valves one for O2 and one for Fuel( LPG in this case) then their will be a connection for either Cutting or welding tip,the cutting tip will have another adjustable valve and a cutting lever...
there will also be 2 regulators one on the Oxy cylinder and one on the fuel cylinder,these will have either one or two guages on them,if 2 guages then one is cylinder pressure,and the other is delivery pressure which is adjustable,I am not sure on the fuel adjustment for LPG as I have always used Acteylene,the O2 pressure will vary as to fuel,tip size,and whether you are welding or cutting ( typically a higher pressure when cutting )...
The torch handle valves are used differently depending on if you are cutting or welding, both are used for the fuel/oxy mix when welding,only the fuel is used for adjusment when cutting and the O2 should be fully open then back 1/4 turn,the oxy adjusment for flame while cutting is adjusted via the valve on the cutting head...
adjusment of the flame is a science/dark art best bet would be to watch some one or maybe see if there is any Youtube videos
with cleaning the tips,get tip cleaners and use the appropriate cleaner for the size of the hole, the cutting tips will have a larger centre hole surrounded by smaller holes,the smaller holes are the ones for the flame the larger centre is for the blast of oxygen..
Wow it's been awhile
Update
The RX as it looks now
I have also picked up a vortex that I am scrapping
Ok well here is the RX
when I got it about a year ago
with the new 13" rims and after I removed rust from the bottom of the "A" pillars
After I lowered it but it was to hard and to low so up it went
the new exhaust 2.5" straight thru with a cannon muffler(yes it is loud)
I had a BOV lying around so thought oh wot the hell
My brumby on its way to see me
eeekkkkk Naked
On her way
will be here next week then the restoration can begin
it is a 1990
it has had work done on the engine
and that all I know
Gidday
I have a couple of Old Gen Subarus
1986 Omega/Leone RX2 coupe
and
I have just got a
1990 Brumby/Brat targa top
Introducing the Subercoupe Now with 50% more cyl’s and 100% more RWD!
in Members Rides
Posted
Thanks for this dave,it proves that what I am thinking of doing is actually doable,it will be very very similair EXCEPT the shell will be my brumby and the engine maybe a EZ30r oh and maybe no super charger for starters
