jdlmodelt
Everything posted by jdlmodelt
  1. Okay, but after replacing the thermostat, and connecting the lower radiator hose, disconnect the upper radiator hose at the radiator, fill with coolant till it takes no more, reconnect hose to radiator, fill radiator till it takes no more, remove burping valve on top of radiator located oposite to the filler cap, pour coolant into little hole until it takes no more. Oh yeah, do all of this with the heater temperature controller on your dash turned to the high temp side. Do all of this before starting engine. Also, since your brother just changed the timing belt, make sure he didn't disconnect the radiator fan control wires and forget to reconnect them This worked for me after swapping a 2.5l engine. James
  2. I'm curious, I haven't read anything about the 90 degrees of rotation of each head bolt times two? Are you guys just torquing to 50 ft-lbs and not doing any of the 90 degrees of rotation after that? I'm putting one of these back together this weekend and don't want to fudge it up. Thanks, james
