how I cleaned up foggy legacy lenses
Both my son and daughter had foggy headlight lenses on their Legacy (1990). Junk yard units were all funky yellow. New was real costly. ($200 + per side) After a search on this site found a fellow recommending wiping lenses with a rag soaked in brake fluid. Real good improvement. You'll wonder where the yellow went. Still left something to be desired though. Found 30 micron silicon carbide paper. Real smooth. 3000 grit or so maybe. Wet sanded front surface and it got sort of hazy. Then got Ultra Brite tooth paste on damp rag and went after each lenses for about 15 minutes. Great results. Prior to this never had anyone flash me with those high beams locked on. Now oncoming drivers are p.o.'ed if we don't dim 'em. Cheap and easy. rick w mi
can foggy headlight lens be cleaned?
This has probably been asked before. Is there any way to clean the haze from 90 legacy lens? Now that long nights are here it is becoming a real issue. They seem hard to find in salvadge yards and new prices are very painful. I've even considered cobbing some all glass jobs from some non soob but am afraid no one in the family but me would drive it. Also windshield seems to have been cleaned with a scotch brite or somehting and approaching traffic leaves multiple glowing circles that combined with bad lens is a recipe for disaster. I am thinking of polishing just the drivers straight down the road view area. Does any one have insight/experience? tnx rick
xt heater controls dead
It is getting cold here in w. mi. My sort of newly acquired 85 xt non turbo auto is more fun to drive then anything but my old long departed 1964 austin healey sprite. But those charming controls on the steering colume that set the air to defrost, heat, bilevel or vent, do nothing. My schematic makes refernece to a mode control and mode actuator. They are black boxes in the print. Should I suspect here or are there some other common failure items? Fortunately it is stuck on defrost so I can at least dump the dew. tnx rick
how hot is too hot (bearings ok?)
just bought a old 89 xt ea 82 auto 2 wd. found a broken cam shaft on the drivers side. upon pulling heads off found discoloration of head bolts. lots of blue. = overheating. right? no obvious cracking between intake and exhaust ports. i am for sure redoing heads, gaskets, valve guides, etc. how likely is it that the lower end has seen significant damage? Pistons and cylinder walls suspect? I want to avoid a total rebuild $$ if possible. suggestions? btw, this sure is a great web site. we should all buy the administrators a good cold beer or three. tnx rick in west michigan
pulled xt motor. didn't disconnect torque converter
tnx for all the data folks. this is a great site. would be lost without it. appreciate your time. will pay more attention next time a motor comes out.. rick
Only 2nd or third time I have pulled an engine on a Soob. I didn't remove four bolts from torque converter. Center shaft slide out of tranny about 4-5 inches before I could do anything about it. Didn't hear anything falling out of place. Slid back in ok but being a huge pessimist I am thinking the worst. Any insight? rick w mi
89 xt busted cam swap with gl question
tnx alot for the help. will indeed swap both sides now that motor is on garage floor. btw xt is non turbo and putting in spfi cams. rick
found drivers side cam busted on 1989 ea 82 xt I just bought. Pulled cam box bolts out and saw obvious heat discolorization. S'pose need to pull motor and do a set of head gaskets. Will cam from ea82 spfi work ok? Lobes way different or close enough to for general service? rick w michigan.
oil pump rebuild questions
Low oil pressure on my ea 82 xt. How difficult / costly to rebuild oil pump? Is it a likely problem. What is involved? tnx rick w mi
what's a crank angle sensor???
The crank angle sensor actually has 2 outputs. One sends 360 pulses per disty rev to the ecu. The other I believe sends 4 p per rev. The sig level is 0 volts low and +5 volts high. If you know any electronic geek have them back probe the connector and observe the pulses on an oscilloscope. (very fast voltmeter sort of.) Should show missing or erratic pulses if it at fault. Cold beer says it is the wiring and not the sensor. rick w mi
SPFI ea82, engine sputters on R/H turns only
Had a smoking problem going around corners with my 88 gl. 4 wd auto. found the modulator valve leaky, sucking xmsn fluid in intake. Just one more data point. rick w mi
port head on starboard side
tnx all. will plug lines and try it out. I owe you all a beer. rick
Man I hope this not the first time this has happened. Some one else must have been this unattentive. Son #3 and I have just put an ea 82 back in 93 Loyale. Shot head gaskets. All things going good until it comes to the egr 90 deg elbow. Heads are reversed. #$%@!**&^ etc. and then some. Can I plug passages and run this way? Any other uniqueness from right to left that will screw me up. Will it run at all? Let's just keep this one a secret eh boys? rick and phil
88 gl dies, restarts, dies, etc.
Just an update. Darned car is still running fine. Didn't find a culprit. Maybe removing, reconnecting, the crank angle position sensor quite a few times has temporarliy resolved the trble. Also checked the fusable links and all appears ok. If and when reoocurs, will completely rewire the sensor to ecu with new fully sheilded cable. tnx all rick
Thanks for all info and suggestions. Did nothing this morning except drive to work and back. -16 miles Ran fine. For now. Have decided to wire from crankshaft position sensor direct to ecu connnector with brand new shileded wiring. Will ground shield on ecu end only. Float the other end of shield to eliminate gnd loop noise. Should be easier then looking for funky old wiring. Will update. rick
aa8jz
