DJ_Kuehn
Everything posted by DJ_Kuehn
  1. Thanks for all the help guys! I'll try to respond to each of you here. Barracuda: I don't know if it's got hydraulic lifters or not. It's a 1980 motor, the first year for the ea-81, so probably not. I'll probably only mill off what's necessary to get things flat again. Crayola: Soobs are actually VERY common in hovercraft and aircraft. They can do anything CCRinc: When I say zero compression, I mean I can turn it over with my finger over the plug hole and feel some compression, but it's not enough to blow my finger off. It's probably like 15psi or so. Does that make any difference? And yeah, I know both bobby and billy very well, I'm friends with both of them. Are they getting motors from you now? I know they have some bad feelings towards another subaru rebuilder so I figure they've found a new source by now. If they're buying off you, I'm sure you got to hear a good story about a timing gear. 4x4 welder: Thanks, but that's a bit more creative than I plan on getting LOL I REALLY REALLY hope its the head gasket. I'm glad to hear that the valves are as tough as everyone claims, I was afraid I'd be buying new heads and valves. HOwever, I never thought of the sleeve issue. I'll probably cry if those came loose. I may have to send some money CCRinc's way It will probably be a couple weeks before I can tear it down and I really hate not knowing! If anyone else has any suggestions or ideas, please feel free to jump in. Thanks, Jason
  2. Awesome, I hope that's all it is. If I do mill it down, how much can come off? Also, I've considered doing that before, but I've been told that increasing compression doesn't do any good unless you change cam profiles. Is that true?
  3. Hey guys, I race hovercraft and have an ea-81 powerplant. The motor is all stock except for a holley 5200 carb and tuned exhaust headers. It WAS a low milage motor with only 27,000 when I put it in, but that's shot now. Here's the short version of what happened: I was racing, doing quite well actually, and was really putting the heat on the first place guy trying to pass. Well, he had to turn to avoid hitting someone, which caused me to turn to avoid hitting him, but it didn't work so well. We hit hard, but when youre racing and everything is still running, you keep going and hope for the best :cool:. Turns out, my radiator got punctured in that accident. I went about 4 more laps (this is non-stop full throttle, btw) at about 1:45 per lap, finally passed and got into first place then my engine started sounding wierd and went to idle. About 30 seconds later it backfired a couple times and died. I then turned around and found out that I had no coolant whatsoever. SO, I have what was a great running ea-81 that went around 5-7 minutes at full throttle with no coolant. I've tested the compression and here's what I found. Cylinder 2 had 150psi and 4 has 135psi (drivers side) Cylinders 1 and 3 have nothing. Here's my question... I know these are very tough motors and I might not need to do a full rebuild. What is your suggestion for fixing this up? Could it just be a head gasket issue since both right side cylinders have no compression, or did I burn my valves up? I haven't had time to tear it all down yet, but would prefer to have parts ordered so that I can put it back together right away (that way I'm less likely to forget how it came apart!). How should I proceed? Thanks guys! And, since I know someone will ask, here are the pictures of race. I'm the orange #23. http://prophotoproductions.exposuremanager.com/g/Sunday5&gallery_page=&gallery_all=&view=1&photo_page=3
  4. If you are concerned with weight, the 81's are quite a bit lighter than the 82's well. I use a soob in my hovercraft, so weight is a big issue there.
  5. Alright, got all my issues worked out finally. Here is the good news... for those of you who have an older model ea81 with the external ignition module, here is a way to save about $340. Get a GP Sorensen model EL102 ignition. It is used on tons of GM cars from chevettes to camaros and only cost $14.88. It works great and I like the price much better than the $358 stock module.
  6. Thanks for the response, I've got it figured out now. I had it running all weekend and had a blast. There were several reasons I had so much trouble, one being the wiring diagram was wrong, and second, I have an external ignition module and everyone kept telling me it was built into the distributor. I guess 1980 is an oddball year where everything is external (volt reg and ign mod).
  7. Went to the auto parts store over lunch and learned a few things. In order for the MSD or any aftermarket performance ignition to work, you still have to have the stock ignition module installed so that the MSD gets a pulsing signal. All the MSD does is boost the signal to the coil. So, the guy there (advance auto parts) helped me find a generic module that we think might work in place of stock. It is the standard ignition for tons of different GM cars from chevettes to v8 camaros. If it doesn't work I'm out $15 instead of the $358 it costs for the 'stock' module. I'll post an update tonight and let you all know if it works. Might save everyone some serious cash if you need a new one.:cool:
  8. So it IS an external piece from my distributor? In that case, I will buy an aftermarket 'performance' ignition. The 'stock' setup is over $350!! I can get any number of generics for way less than that. Here is a question... are they all pretty much the same? Would something like this work? http://www.partsamerica.com/ProductDetail.aspx?categorycode=4013F&mfrcode=PRF&mfrpartnumber=66944C It's cheap and has two terminals on each side, like the original. Does it work the same way? Thanks so much for all the help guys.
  9. Ok, just found another manual online. Now i have one manual (the chilton 1970-1984) which says there is a "transistor ignition unit" mounted on a fender by the coil. The other manual, Gregorys 1970-94, says the control unit is inside the distributor under the rotor on Nippon Denso distributors (which I have). Do I have an oddball year motor where the control unit is separate (like the voltage regulator). If so, I think I'm seriously going to go bang my head on a wall cause that thing costs almost as much as I paid for the entire motor.
  10. Well, I'm just starting to learn these motors, so I don't know that much really. I know there is a reluctor that sits where the breaker points would be, and there is a pickup coil which generates the high voltage. The ignition control unit supposedly controls the flow of current to the pickup. Now, I don't know what this control unit looks like, but I've been told it's a small box inside of the distributor under the rotor. However, the wiring diagrams always show it as a separate box. I know this will sound really ignorant, but is the control unit outside of the distributor or in? If it's a separate box, then I think I know my problem because I don't have one!
  11. Cool, thanks man. Would you happen to have any idea what an ignition control unit would do with the polarity reversed? Would I damage it, or would it simply not spark, like I have now?
  12. Cool, thanks ross. If you have factory manuals, you'll probably be able to find out alot more than I can with this POS chilton book. Yes, my hindsight is 20/20 and I REALLY wish I would've got an internal reg alternator. I bought the "stock" alternator off ebay for dirt cheap ($20 new and shipped) not realizing that an external VR was needed. I found that out after the fact. Now I have a new alternator and a new VR, so I'd rather not spend more money unless I have to.
  13. Yes, this is sort-of a new problem in the same general nightmare. Here is what I've discovered so far, and it all boils down to external voltage regulators are a pain in the arse. I have it turning over now, but it won't start. The wiring diagram WAS incorrect in that it is missing the wire from the switch to the starter solenoid. I believe the wire that goes from the voltage regulator to the starter actually goes to the same connection as the switch/solenoid. This charges the coil during cranking, but once the engine is running, the coil gets it's power from the alternator. That way, if the engine dies, the fuel pump power (also from the VR) gets cut off automatically. This is all just my theory, but it seems to make sense. It's got me to the point of a charged coil and the engine turning over, so I guess i'm farther along than i was! The issue with the shielded wire wasn't exactly what I thought. Turns out, there were two wires in the shielded wrapping all along, but one got sucked down into the wrap when it was cut by the salvage people. After I heard that there had to be two wires there, I cut another inch off what I had and then discovered that there was indeed another wire farther back. Now those two wires are my problem. The colors on them do not match the colors on the diagram. Every document I find keeps talking about a yellow and black/white wire, not the solid red and solid white i have.
  14. I'm not that familiar with the 82's but do open valves clear a piston at TDC? I know in some cars, if you break a timing belt it can bury the valve in the piston, which is why they recommend replacing them so often. If they don't clear, then it's possible that's why he's having blowback in the carb. One of the intake valves might not be sealing.
  15. This may be a simple question... I have a 1980 EA81. I bought it from a salvage yard, so, of course, all the wires were just snipped off instead of being unplugged. In my chilton wiring diagram, the two wires that come from the ignition control unit in the distributor are shown as yellow and black/white. Black/white ties into the lead from the voltage regulator to the resistor (then to + side of coil), and yellow goes to the negative side of the coil. However, on MY motor, these two wires are solid red and solid white. I looked through every wiring diagram for every year and they're all shown as yellow and black/white. Does anyone know which is which. Maybe being reversed doesn't even matter, but I don't want to take a chance on frying my ICU since it's like $350 for a new one. I'm wondering if the Chilton manual only shows the hitachi disty and maybe those are a different color. I have the ND disty. Thanks!
  16. As I said, I'm a noobie at this, so maybe i'm way off base, but i'm pretty sure there are no points in the disty, just an electronic control module.
  17. Thanks cougar, I think that wire must go to the negative side of the coil then. I have no points, but I still see what you're saying. Most people seem to have 2 wires coming from that lower part of the distributor, so i'm not sure what I'm missing, but I'll hook it up and see if it works, hopefully without frying anything. Regarding the starter, I never considered that being the charge point, but it's possible. I assumed since there are two connection points on the starter and two on the wiring diagram, one must be the big battery lead and the other the regulator to solenoid. But, if thats the charge circuit, then both of those wires must go to the same terminal (where the batt connects). That means the Chilton people must have forgotten to draw in the solenoid to switch connection.
  18. Cougar, 1. I don't know that anything ties to the neg side of the coil, that was just a guess. Are you saying that the wire from the bottom of the distributor is supposed to go to the neg side of the coil? It sounds like you are referring to two different wires coming out of the bottom of the dist, which I've heard before. I'll look again when i get home, maybe there are two but one is buried inside the insulation. 2. That's what I think should happen as well, but why does this not show on the wiring diagram? What is the point of the wire from the volt reg to the starter? Is that wire in ADDITION to the wire which goes to the start terminal on the key switch? Man, I should've got an alternator with the reg already built in!
  19. Thanks for the site, that engine manual will be pretty useful. I've been looking for a factory one. Unfortunately, the stuff he has posted doesn't have any electrical
  20. Won't let me repost images so here are the links: http://www.ultimatesubaru.org/forum/attachment.php?attachmentid=2440 http://www.ultimatesubaru.org/forum/attachment.php?attachmentid=2441
  21. I posted this in the "subaru transplants" forum, but it's not getting any traffic, so I'm asking here instead. I'm trying to get this going by the weekend... Hey guys, I have two questions regarding wiring on a 1980 EA81. I build and race hovercraft, so this is by no means an OEM installation (in other words, I can't simply hook up a wiring harness and be done!). I know there are alot of very knowledgeable people on here, so hopefully someone can help me out. 1. There are a total of 2 wires that go to the distributor. One obviously goes from the center of the coil to the center of the disty (high voltage to rotor). The other wire comes out of the bottom/side of the dist. It is a single, braided wire with a loose vinyl sleeve around it. Now, if power goes from the voltage regulator to the positive side of the coil, it seems that maybe this wire should go to the negative side of the coil. However, this isn't really shown on the wiring diagram i have. To make things more confusing, this wire's construction makes it look like some kind of grounding strap, but I don't see why you would need a grounding wire to something that is physically connected to the block! Since I'm a noob with auto wiring , can anyone tell me how this coil/distriubtor/voltage reg thing is supposed to work? 2. The attached diagram is from the Chilton book for early 80's soobs (yes, I know it sucks). I think the root of this problem and possibly the first problem is that the wiring diagram is not correct. Anyway, there is a wire on the voltage regulator that is labeled "starter". On my wiring diagram, there are two wires shown going to the starter; the main positive from the battery, and one going into the regulator. From the voltage regulator, two wires are shown going to the ignition switch. One is for the charge light, the other splits to both the positive side of the coil and the ignition switch. There is NO wire shown going from the ignition switch directly to the starter. My question is, how the the starter get a signal to crank? Am I just missing something, or is my diagram wrong? Thanks a ton for the help!
  22. You can also use a Holley 5200, which are very common, and can still be bought new (reman) at your auto parts store. It is very similar to the Weber 32/36. Holly licensed the design from Weber. It is used on pintos and late 70's style mustangs. the only catch is that you'll have to make an adapter plate because the bolt pattern is different. I went with this setup because it was WAY cheaper than a new weber and parts are easy to find.
  23. Here are the wiring diagrams I'm trying to use. Sorry the res is so low, I made them as high as the forum would allow.
  24. Hey guys, I have two questions regarding wiring on a 1980 EA81. I build and race hovercraft, so this is by no means an OEM installation (in other words, I can't simply hook up a wiring harness and be done!). I know there are alot of very knowledgeable people on here, so hopefully someone can help me out. 1. There are a total of 2 wires that go to the distributor. One obviously goes from the center of the coil to the center of the disty (high voltage to rotor). The other wire comes out of the bottom/side of the dist. It is a single, braided wire with a loose vinyl sleeve around it. Now, if power goes from the voltage regulator to the positive side of the coil, it seems that maybe this wire should go to the negative side of the coil. However, this isn't really shown on the wiring diagram i have. To make things more confusing, this wire's construction makes it look like some kind of grounding strap, but I don't see why you would need a grounding wire to something that is physically connected to the block! Since I'm a noob with auto wiring , can anyone tell me how this coil/distriubtor/voltage reg thing is supposed to work? 2. I will try to scan in the wiring diagram I'm working from tonight when I get home, but until then, I'll do my best to explain. The diagram is from the Chilton book for early 80's soobs (yes, I know it sucks). I think the root of this problem and possibly the first problem is that the wiring diagram is not correct. Anyway, there is a wire on the voltage regulator that is labeled "starter". On my wiring diagram, there are two wires shown going to the starter; the main positive from the battery, and one going into the regulator. From the voltage regulator, two wires are shown going to the ignition switch. One is for the charge light, the other splits to both the positive side of the coil and the ignition switch. There is NO wire shown going from the ignition switch directly to the starter. My question is, how the the starter get a signal to crank? Am I just missing something, or is my diagram wrong? Thanks in advance for the help guys. I'll upload a scan of the wiring diagram I'm using to clarify these questions. Don't have it with me now, so it will be this evening.
  25. A good company to work with is http://www.ramengines.com/ He primarily builds engines for aircraft, but I've used him for my hovercraft parts. He builds EA-81s with 100-160 horse.
