Everything posted by martimus919
EJ22 Conversion with NO SPARK!!
OK gave that a try and... Back up power supply has 12v while cranking (expected) ECU Power supply drops well below while cranking
Did not rebuild the engine, it's in great condition pulled it out of the car with 90k on it.
I followed your diagram on your write up to a T. That's when the fuel pump started working. The fuel pump is ECU controlled. The engine is out of a wrecked 90 leg, pretty sure it was standard I feel like there's more I can tell but I can't think right now.
Yes and they are, the only things that aren't hooked up are the, knock sensor and oxygen sensor.
I have an EJ22 in my Brat all ready to go wiring is almost complete other than i have no spark. Fuel pump relay works, ignition relay works and I even have power to the coil. It's driving me nuts as to why it's not firing. Any help would be very very appreciated... very
- Jibs' EJ Brat
Project EJ22 Hatch continues
I couldn't quite make out what model it was but i could see another Electra, you've got good taste in cruisers.
That's a nice Electra Betty you've got there;)
Whose idea was it for your brat again?
Will you just get your axles done already I'm dying with anticipation here!! My Brat needs axles and I'm running off your experience with this
ej25d into my 1986 lifted brat
keep the drive shaft from your RX! I just put the RX AWD Dual Range in my brat and the drive line is the perfect length, all I had to do was mount the carrier bearing.
Jibs' EJ Brat
Ya i pulled the front axles from the XT6 i took my 5 lug stuff from and they go right on to the trans I still have the brat in the air in my garage and haven't had a chance to see if i need to cut down the axles though (I'm afraid I will have to). How do I get that kit? Just e-mail him? and how much does it usually run?
Jibs' EJ Brat
Crazy I'm doing the exact same swap right now in my brat. How was putting the shifting linkage together? I just got my trans to fit in last night after hours of pounding on the tunnel to give the trans clearance and notice i don't have alot of room for the linkage.
5 lug swap complete...notes etc
What are the chances of taking the tie rods from a XT6 and putting it on a Brats power steering rack? Looking at the 2 it seems like it would work but I'm not entirely sure. Or am i going to have to cut them down also?
Ya sorry I was mistaken it's a AWD Dual Range out of an RX
I guess these ones are pretty seased, i hammered for a while and nothing i guess I'll get a torch and some penetrating oil. But I'm picking the suspension and brake off of a 91 AWD auto XT-6 with coil suspension all the way around. Any body know if they have an LSD rear on the autos i can't see anything on it that says? I've already got one with my trans I'm putting in but I'm thinking i could get this one for my friends brat.
Would there be a problem using the xt-6 strut and knuckle with this swap and just putting my top hats off of my brat onto them? I've got the whole front end and I'm planning on putting in an AWD Dual range as well, also how do you get the backing plate off of the rear i can't seem to do it.
Top speed on 94 legacy sport
martimus919 replied to martimus919's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAh right you did! For some reason i thought you were talking about the Autos still, and I completely forgot you guys said there was no speed limiter. Ha
martimus919 replied to martimus919's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWait that Brat that you're selling possibly? That Brat that also doesn't have a sweet cyclops light, like mine does, Glenn? But no I know the DP won't make it go any faster but it will give me about 15 to the wheels DP alone, I'm just trying to figure out if I'll need to get a diff trans/re-gear or get a speed limiter delete.
martimus919 replied to martimus919's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo I'll prob have to re-gear? I'm assuming when you guys topped out yours it just ran out of RPMs? Also Ericem what's the downside of not running you're bigger downpipe and Exhaust? I've got the downpipe but I just don't wanna put it on till I'm ready to put the rest of the exhaust on, but I want my car to run better than it is right now.
martimus919 replied to martimus919's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYa when i do it I'll be running the revtronix stage 2 chip with a TD04-16G, I've already put the turbo, intercooler, HKS filter in and it's running like crap. I'm just waiting for money for the chip so i can put on my exhaust and STI injectors.
Any one know the top speed of a 94 legacy sport in a manual? I'm aiming to enter the 130 club at the Bonneville Salt Flats. No use trying yet if the car won't do it.
