Posts posted by Bbob
I was able to get the alarm dash lamp to stop flashing by holding the under dash reset button down for a while.
Now if I can find my clicker......
YES ! .....That worked Perfectly.
What do they say about busy fingers?
As usual, after buying a used 98 Legacy Outback and repairing head gaskets, I thought it would be nice to have the keyless entry working. I bought an ebay keyless clicker, then noticed the fuses had been pulled from the KE harness. Also the anti theft Ignition 2 pin plug was disconnected and bridged. The 4 pin plug next to it was also disconnected.
Put fuses in KE harness which made the tiny dealer installed dash lamp flash and click an under radio area relay. Under dash reset button did nothing.
Check Engine light is now FLASHING and rad. fan is cycling with clicking of many relays under hood and under radio.
Cleared codes ;
P0500, P1120, P1121, P1130, P1131, (don't know what these are) and both O2 Sensor Codes
Nuts....
I'm probably lucky that it's still running.
Left front wheel speed sensor shows continuity.
Front wheels pulling all & chirping was the first indicator we had to the problem.
Please, what would wet grass tell me?
No code on the "front wheel speed sensor" either
Never lit the CEL
No code for transmission
Turned both back wheels at once - drive shaft did turn
Turned left and right independently with other wheel stopped - drive shaft did turn
I'll check the back wheels turning.
Every AWD clutch pack I've ever seen had grooves cut into it.
I thought since it worked the day before that pressure and vibration pushed them over anyway.
When I had the tail cone off I didn't see any chamber that would hold air.
No, I checked the main fuse under dash.
Axles will pop out?
Let me see.
Where exactly is the "front speed sensor"?
By "busted rear axle" did you mean the main carrier or an axle shaft?
'95 Subaru Legacy
Doing this myself.....Need Help
Good fuse
Click test (good?) duty C solenoid
Passable AWD clutch pack installed (Pick a Part)
Had "KG" Marked TCU
Tried 1996 "PC" TCU.....still no RWD
Any suggestions?
I have 1995 Legacy L wagon 175,000 miles. Always loaded, it's driven very hard and treated rough. Never had struts replaced. Tires on orig. steel wheels & tires are 185 70 X 14. The alloy wheels to go on are 15in. diameter 6in. wide. Interchange book says they will fit the car. What is the largest tire that I can purchase without rubbing?
Thanks in Advance!
I have used the Honda type Synthetic trans Fluid for the last 70K in my
'95 Legacy Transmission . This year I lost my rear wheel drive.
Saturday at 60mph on the interstate, "D" gear selection became neutral for 30 min. and then returned. "3" gear got me home. Been OK since.
Futures?
Realize, this is Jersey. I'd be suprised to hear "I don't know" from any sales person.
There is a 1 year part & labor guarantee.
I wonder why they want to sell me a '95 when so many other years will interchange? (mine is a '95)
I have almost bought a Legacy Transmission from New Jersey Junkyard that was said to be only 45K miles.
It's too good to believe. Can anyone tell me how to check this mileage without buying a carfax report?
Junk Trans from; VIN: 4S3BD6556S7232732
Year/Make/Model: 1995 SUBARU LEGACY LS/LSI AWD
I have priced a Legacy Transmission from New Jersey Junkyard at 45K miles.
Thank you.........Bob
Please, what is EJ25?
What is Duty C ?
This trans does not slip at all after the first start in the morning.
I have changed out a few transmissions.
The problem is finding one with this narrow of an interchange.
As I understand not many trans will fit this car....and all ebay transmissions come with fantasy mileage.
What is Duty C?. Special tools needed for clutches in the tailshaft?
Parts from the dealer cost more than a Mercedes.
I need this to pull up a 28 degree driveway so FWD is not my option.
Fuse was put in 3 days in 2007 out of confusion.
Car has been run HARD the last 90K miles.
Yes fluid changed 3 times. (pan off)
New set of tires.
1995 Legacy L 162,000 miles
All operates OK - Trans slips until it pumps up (20 sec) then does well.
Changed trans fluid to Honda like synthetic in 2007.
Have noticed through 2008 that the front tires squeal when signals change to green.
This didn't seem right for AWD to me.
<img src=http://i725.photobucket.com/albums/ww257/buillder/00JSubaruAWD001.jpg><p>
<p>
Now it won't hardly pull my boat out of the driveway. (14ft. 40hp)
Almost burned a tire up at the lowest RPM. (would barely inch up)
I had it in "L" at the time.
We do not have an independent Subaru shop here in Nashville.
There is a fuse missing in a single receptical near rt. hood hinge in AWD circuit.
What is a possible fix?
Check Engine FLASHING After Putting Fuses in Keyless Entry
Posted
KE is now working as advertised.
Thank You
