Mixture too rich with weber.
both fuel filters are fresh and clean. It progresses pretty well. But there is a little hesitance if I go from idle and mash to WOT.. hardly noticeable. Not my problem. If you drag ea82's... well.. Been neglecting the soob:-\ but today I did figure out the problem.. But I don't understand why. The choke opens nicely until it's all the way open. It'll Idle there for as long as you'd like it too. Go for a rough drive (exhaust noise is ). And then I died.. 10 ft from my parking space. Opened it up and the choke is 100% closed. It did seem to be slowly losing power so at some point it must have decided to slowly close the choke (over ~ a 30 seconds to 1 minute period). Wtf? I looked at the electric choke wire and crimped new connections on. It looks fine though. Really seems to be related to moving though. I'll go look at it some more.
I think I'm going to have to just pull it and go through the whole thing and maybe rejet it some. One thing I noticed is the accelerator pump seems too active. Slowly opening the throttle (as slow as possible) a good bit of fuel runs out. I saw adjustments for this on other carbs but from looking at the weber diagram the only variable is the size of the accel. pump jet?? Thanks
1. Nope. Came from markjw sedan. It did run on the ea82 wagon pretty well. decided to tune it a bit. idled kinda low. Messed with the mixture screw/idle screw.. mixture screw seemed sorta responsive. Pitch changed at about 1 turn out and then started to want to die. Didn't really do anything up to about 3 or 4 turns out (didn't go further). Next time I started or tried to start it was hard to start. Pulled plugs.. got new ones. Started a bit better. Ran really rough. Then ran only on the secondary (weird...). Then boom and exhaust coming out by the rear tire. 2. jetted for the ea81 I'd suppose. Should be similar? identical? Yup. The fuel return line is fitted.
on a carbed ea82. regular pump/no regulator. Plugs were fouled. Got new ones. they fouled pretty instantly. very black. I also blew a hole in my exhaust.. needed a new one as muffler was broke and cat might have been clogged. But I'd like to know why it's running so rich b4 I shell out money I don't really have. Mixture screw was anywhere from 1 to 3 turns out. Didn't seem to make a whole lot of difference. Hard to start.. had to rev a bit. Then idled fine. Instant I touched throttle she died. Very finicky... Choke works. Thanks for any help. David P.S. If you've got a full ea82 exhaust or just the Y-pipe that's good I might be interested.
Coolant Oil Milkshake
Thanks GD Also realized that some rainwater might have went into the pcv when it was without a hose (fixed that). After I flushed (wow.. atf stinks) and refilled there is still a TOD on the Passenger side. Kind of goes in/out at idle but is pretty noticeable. What might that mean? Car runs pretty good with the new weber otherwise.
it sat for a little while with the coolant there and I'm pretty sure it leaked past the rings...
^^^ as above. Didn't drain coolant before removing intake... (that's a bad idea for future reference). So I figure... no big deal. New Oil/Filter just had the crap oil and fram that i used to get it running. Guy at parts store says i need to flush with new oil filter and THEN get new filter and oil. Something about coolant being very bad for rod bearings... So. I've got a 2 oil filters but do I really need to flush with 4 quarts of oil?
New to USMB, 1992 Legacy L owner since 2006.
http://www.endwrench.com/pdf/engine/FtCamBeltReplaceW01.pdf here's the endwrench article for timing belt replacement. Certainly possible (and MUCH cheaper) to do it yourself with the help of friends. Much easier on a manual transmission to remove crank pulley (5th gear/assistant on brakes). A torque wrench and a (? 22mm) socket and you're good to go.
Tires
Hmmh. that's weird. If they're earlier white spokes they might not be clearing the front brake calipers. But you think that would be clear. If the calipers are ground down a bit or have short pads on the 4wd car then they'd be clearing the caliper on this car. Only possible thing i can think of... still unlikely.
Newer Legacy Question. 90-94 or 95-99
Scooby17 replied to The Dude Abides's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs I understand it there is two main things that seperate those generations. Or 1.5 90-94 OBDI less wires/electrical gizmos. 95-99 OBDII More of that good stuff.. (which then might fail) 90-96 ej22 is non-interferance. New timing belt = 97-98 ej22 is interferance Timing belt boom = a 95 or 96 would prob. be ideal for your needs/wants. I drive a 98. quite reliable. 30k in the last year. never let me down. Many are available here with well over 200K. So that should say they're at least decent unlike 2.5s which are bad for HG reasons (obviously).
New Prospect W/ PICS
Hmmh. I got pulled over for driving with no windshield just last month. Although, I didn't get a ticket. Just a "You shouldn't drive you vee-hick-L around like that". Lol. such a funny look on his face. was driving to the glass shop after a deer tried to come through the windshield.
How much is it worth?
Not really. 1800$ is quite alot for a car with an ea82 in it. even with low miles the engine is somewhat unreliable due to Timing belts and it is very gutless. You can get a 1st gen legacy for that kind of money. much more car that requires less maintenance. and that would be AWD (not sure how much it matters) or maybe a FWD but those are few.
Speedo Problem
Scooby17 replied to Hocrest's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen the speed sensor was out on 98 legacy it threw code P0420 I think. ECU went to limp mode and no revving over about 4000 rpm (ecu would cut engine out then would work again after a few seconds). Revving in lower rpms was fine though.
EA82 radio install...
yup. It looks fine with the black and black stereo. although if a person cared enough they could paint it.
Using metra kit part number 99-8900 a standard din fits quite well into any ea82. still some pains wiring it all though. Here's a good write-up. http://www.ultimatesubaru.org/forum/showthread.php?t=50840 and a pic. It isn't in the way of the shifter either and a much larger version... (don't know why that's so small) http://picasaweb.google.com/SnowScooby17/RandomPics#5415942117686253730 Good luck.
Scooby17
