Blacky
Posts posted by Blacky
If it is a different gear ratio you will need to swap the rear differential as well, just in case you didn't know that already.
You say no fuel is pumping. Is the fuel pump fuctional?
I'm thinking the ECM is not compatable with the motor. 92 was way before OBDII and a 97 engine would definately be OBDII. They just aren't communicating with each other properly.
Check the sway bar bushings too. Mine were worn and caused a clunking sound over bumps. It's a cheap fix too, about $15.00 a pair.
SVX bore size: 56.1mm Toyota 2WD bore size: 60.1mm
You just need hub-centric rings...56.1 id 60.1 od
Scroll down to matching vehicles.
Hot and really friggin' hot!
It is non-interference.
There are no real issues with the engine other than Subaru style oil leaks. The biggest problem is the tranny. They are prone to overheating and early death. Install a good tranny cooler, one with a thermostat and fan is best.
Check out: http://www.subaru-svx.net
As of Saturday, I now own 2 of them.
Rear diff failures are quite rare, if you keep fluid in them. I wouldn't hesitate to buy a used one. I'd replace the 2 axle oil seals just to be safe.
Sounds like classic head gasket symptoms to me also. Sad to say.
The Cosmo CAI goes into the fender. No more chance of hydrolock than the stock intake.
I've used a CAI from Cosmo Racing on other vehicles and they are excellent, cheap too. Here's a link for ya:http://www.cosmoracing.com/search.asp?searchstring=subaru
They have short ram (hot air) and real CAI.
Bosch makes Subaru OEM O2 sensors.
Alrighty then, thanks for the help. I'm definately looking for an easy swap not a Frankenstein experiment.
Maybe I'll go to plan B. Buy a second SVX I've had my eye on which has a blown front diff and swap in the 4.44 tranny and rear diff from the Outback. I know that can be done.
This has probably been covered but I couldn't find anything when I did a search. I have a '97 Outback with a dead engine and have a lead on a 2000 EJ22 for a great price. Is it a straight plug and play or are there other issues to deal with?
Was the new battery fully charged when you bought it? Often they aren't.
Could be the new battery is defective, have it checked.
My thoughts exactly on the whirring noise. When mine jumped the timing belt and bent the valves on 2 cylinders reducing their compressoin to zero and 15lbs, the engine cranked over extra fast and made a different whirring, whining sound. The cylinders may be scuffed to the point of nearly no compression.
I think your engine is probably toast.
If you go one plug hotter, a 6 instead of 5, I've been told they will work better in high mileage cars where compression may be down slightly.
Thanks. Had the guy look at the car today. He's gonna do my valve cover gaskets, grommets, plugs, tubes, wires and replace my battery clips (corroded) for $75 labor (parts cost $100, all Subaru parts). I am happy with this!! Will look over the car more when we do the work and see what is next.
Thanks for the heads up!
That's a great deal on the labour and parts.
I believe 96-mid-99 will fit. In late '99 they changed over wth the 2.5 SOHC.
They can also be rebuilt cheaply and easily.
The raw power and roar of the engine was terrifying.
I really, really want one of those, they're great.
I had this same problem on my SVX. It was the universals on the steering shaft. I sprayed them liberally with WD40 and they loosened up immediately.
I'm about to do a JDM swap into one of my '97s as well. The Japanese owner of the local JDM importer says to swap intake stuff, do the timing belt , water pump etc. Also replace the spark plugs while they're easy to reach.
The JDM engine does not have an EGR system. He mentioned drilling and tapping a hole for it.
I'll probably get him to do the swap because he gave me a price of $300.00 to install it if it's one of his engines. This should also help with any warranty issues should they occur.
P.S. The engine he has has the coil on top.
Check Engine Light
Posted · Edited by Blacky
PO420 is "THE" most common code. There's a multitude of things which will trigger it. I just clear it with my code reader and it usually does not come on again for many, many months.
Definately do not get sucked into replacing your cats. It will not stop the code from coming up and it will cost you a small fortune.
