Everything posted by Blacky
Check Engine Light
Blacky replied to Roger Stokes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPO420 is "THE" most common code. There's a multitude of things which will trigger it. I just clear it with my code reader and it usually does not come on again for many, many months. Definately do not get sucked into replacing your cats. It will not stop the code from coming up and it will cost you a small fortune.
1999 2.2L into 2001 Outback?
Blacky replied to etc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it is a different gear ratio you will need to swap the rear differential as well, just in case you didn't know that already.
EJ swap -> fried ECM?
You say no fuel is pumping. Is the fuel pump fuctional?
I'm thinking the ECM is not compatable with the motor. 92 was way before OBDII and a 97 engine would definately be OBDII. They just aren't communicating with each other properly.
Strange front end clunk, need help diagnosing.
Blacky replied to Gsir08's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck the sway bar bushings too. Mine were worn and caused a clunking sound over bumps. It's a cheap fix too, about $15.00 a pair.
SVX wheels on 78 toyota 1/2 ton?
SVX bore size: 56.1mm Toyota 2WD bore size: 60.1mm You just need hub-centric rings...56.1 id 60.1 od http://www.roadkillcustoms.com/hot-rods-rat-rods/Wheel-Bolt-Pattern-Cross-Reference-Database.asp?Makes=TOYOTA&Models=PICKUP+2WD Scroll down to matching vehicles.
Heated seats, whats with the switch?
Blacky replied to Gsir08's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHot and really friggin' hot!
EG33 curious...any "common" problems?
Blacky replied to robert_the_sane's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt is non-interference. There are no real issues with the engine other than Subaru style oil leaks. The biggest problem is the tranny. They are prone to overheating and early death. Install a good tranny cooler, one with a thermostat and fan is best. Check out: http://www.subaru-svx.net As of Saturday, I now own 2 of them.
1996 OWB Differential Compatibility
Blacky replied to fiddilin jay's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRear diff failures are quite rare, if you keep fluid in them. I wouldn't hesitate to buy a used one. I'd replace the 2 axle oil seals just to be safe.
Strange cooling system issue under certain conditions: 97 OBW
Blacky replied to v8volvo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like classic head gasket symptoms to me also. Sad to say.
'98 Legacy Outback Cold Air Intake
Blacky replied to subaruzane's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe Cosmo CAI goes into the fender. No more chance of hydrolock than the stock intake.
Blacky replied to subaruzane's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've used a CAI from Cosmo Racing on other vehicles and they are excellent, cheap too. Here's a link for ya:http://www.cosmoracing.com/search.asp?searchstring=subaru They have short ram (hot air) and real CAI.
Front O2 Sensor--OEM?
Blacky replied to Olnick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBosch makes Subaru OEM O2 sensors.
2000 EJ22 swap to 1997 EJ25 Outback
Alrighty then, thanks for the help. I'm definately looking for an easy swap not a Frankenstein experiment. Maybe I'll go to plan B. Buy a second SVX I've had my eye on which has a blown front diff and swap in the 4.44 tranny and rear diff from the Outback. I know that can be done.
This has probably been covered but I couldn't find anything when I did a search. I have a '97 Outback with a dead engine and have a lead on a 2000 EJ22 for a great price. Is it a straight plug and play or are there other issues to deal with?
Car dies overnight, possibly alternator??
Blacky replied to eventoday's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWas the new battery fully charged when you bought it? Often they aren't.
Blacky replied to eventoday's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCould be the new battery is defective, have it checked.
No oil but crank still turns
Blacky replied to mguy04's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy thoughts exactly on the whirring noise. When mine jumped the timing belt and bent the valves on 2 cylinders reducing their compressoin to zero and 15lbs, the engine cranked over extra fast and made a different whirring, whining sound. The cylinders may be scuffed to the point of nearly no compression. I think your engine is probably toast.
98 OBW spark plug question
Blacky replied to vic622's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you go one plug hotter, a 6 instead of 5, I've been told they will work better in high mileage cars where compression may be down slightly.
Pulleys and seals question (missing anything?)
Blacky replied to yesyeah's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's a great deal on the labour and parts.
97 outback trany
Blacky replied to flyfishnm01's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI believe 96-mid-99 will fit. In late '99 they changed over wth the 2.5 SOHC.
noisey steering pump while idling
Blacky replied to raybo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey can also be rebuilt cheaply and easily.
Gymkhana Subaru 360
The raw power and roar of the engine was terrifying. I really, really want one of those, they're great.
Power steering issues
Blacky replied to nuteeter's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had this same problem on my SVX. It was the universals on the steering shaft. I sprayed them liberally with WD40 and they loosened up immediately.
JDM EJ25 has coil behind intake, mines up top will it work??
Blacky replied to themoneypit's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm about to do a JDM swap into one of my '97s as well. The Japanese owner of the local JDM importer says to swap intake stuff, do the timing belt , water pump etc. Also replace the spark plugs while they're easy to reach. The JDM engine does not have an EGR system. He mentioned drilling and tapping a hole for it. I'll probably get him to do the swap because he gave me a price of $300.00 to install it if it's one of his engines. This should also help with any warranty issues should they occur. P.S. The engine he has has the coil on top.
