bigpimpinben
Everything posted by bigpimpinben
  1. I'm at work prob can't call till its too lat to call east coast people, do the numbers start at the top front bolt, then work to the back and then the bottom?
  2. Sorry to bring up such an old thread, but what is the the sequence? I'm about to do this in a couple hours.
  3. The pads are ceramic, and they look brand new except for where there is a little mark in the same place that there is a line on the rotor. I will have to check the bearings later this week. I have three non mobile cars in my garage right now. I noticed on the way home from school that it make a noise like its warped when I am driving slow and it stops when I press the brake pedal. One other thing that i did was delete the hill holder, not that it would effect this.
  4. I replaced both rotors up front, pads, ball joints, wheel bearings and one caliper, car drove great for a month then grinding. I noticed a line down the middle of the rotor, so I bought the most expensive pads and rotors autozone would sell me, two days later the same thing, I waranteed them out and now a couple days later the same thing. It also feels warped, the caliper is not siezed and the line is down the middle of the rotor.
  5. How does yr fluid look? And is the pedal firm? If not id flush it all and bleed it starting in the back.
  6. She aid that he replaced the battery, I would still pop the cover and go through it with a multimeter, as far as the not starting, I would start with a bottle of heat, after that it is going to be an electrical issue, with the shifter not working id check all of your fuses and relays.
  7. Don't always have mixed fluids with a blown head gasket, I'm changing on that just dumped water out from between the head and block.
  8. Ok thanks guys here are another couple parts. I think this is a turbo management system the brand is turbo xs, there are no markings on the box that everything plugs into. Also what might have been done by rallitek on this ecu? I was told that this downpipe is from a sti. Can anyone tell what this pipe is?
  9. I recently got a motor it is an ej22 I was told that it is a rare turbo block. Any help identifying this motor would be great!!!!!
  10. does any one know how the dimentions of a 2000 legacy gt spoiler match up with a 1995? does anyone have the measurment for the width of a 2000 legacy trunk lid or the spoiler? thanks, ben
  11. I went to change the timing belt on my 2.2 1995 legacy and I lost where the cam was, how can I find tdc?
