mrfixiter
Everything posted by mrfixiter
  1. With a fortunate pull in the right place, I finally got the panel off. I took me a while to figure out how pop the connector out but it wasn't too bad. From there I was able to release the individual wires and then crimp the ends just enough so that now there's a solid connection to the pins of the scan tool. I used this video to figure out how to remove the wires from the plug. Thanks for your reply. mrfixiter
  2. I'm not sure which direction, "back," is and how do you get access to the plastic clips? It would really be helpful if I could figure out how to pull out that lower panel. This video shows the panel already removed.but it's difficult to tell what was holding it in place: yours may be similar.. I have honestly never had the need to actually pull one, so not positive on how. That article you quoted is identical to the page I linked to in my opening post, https://mechanics.stackexchange.com/questions/51253/how-do-i-disconnect-my-obd-port-from-my-lower-dashboard .It's quite a reach to be able to locate the back of the OBDII connector under the dash and then attempt to pinch the ends to release the connector. Thanks for your replies. 🙂 mrfixiter
  3. I have a 1997 Legacy GT wagon whose OBDII port is getting very temperamental. I have to hold the end of the scanner cable in a certain position or the display goes blank. The scanner works fine on other cars so I know the fault is in the car's port. I've watched several videos on how to repair/replace the pins but I could only find one description on how to remove the connector from the lower dashboard. I was wondering if there was a simpler way to access the port. This photo of the port shows one of the two Philips screws which I removed on either side of the panel thinking the panel might easily pop out but that didn't happen. Do I have to remove other pieces of the dash before the lower panel will pop out or do I just need to pull harder on the panel to release it? Thanks for your reply. mrfixiter
  4. I bought the fuel pump assembly from the salvage yard, swapped out the pumps and purchased a new fuel strainer. Car is running again. I do have some other problems which are a prior, failed smog test (before the pump failed) and an intermittent OBDII connector which I will ask about in a new topic. Thanks for all your help. 😃 mrfixiter
  5. When I took out the pump assembly to bench test it, I thought the tank looked very clean. I'll have another look to make sure. Thanks for your reply. mrfixiter
  6. Thanks for your input about used and new aftermarket fuel pumps. I have a couple of questions: I've seen this posted in many places that sell fuel pumps: In your opinion, how accurate is that statement? If I decide against buying from the salvage yard, what aftermarket brand(s) would you suggest? Thanks for your reply. mrfixiter
  7. Yesterday, I reinstalled the old fuel pump assembly in an attempt to see what, if anything, was coming out of the fuel pump right at the pump's output. I thought I had the correct diameter hose to connect the pump's output line to my gas can but it was too narrow and I didn't want to take an hour out of the day hunting down the correct hose. Instead, I removed the hoses from the fuel filter and connected them to the fuel pump pressure gauge. Then I connected my bench power supply to the input plug of the fuel pump assembly. I turned up the voltage slowly and when it got to about 5 volts I could hear the pump chattering. I hadn't heard that sound before when the car wouldn't start or when the key was turned to on during the priming process. It was at that point that the current draw on my power supply had maxed out (2 amps) so I shut off the bench power and checked the fuel pressure gauge. I was a bit surprised to find that the gauge was registering about 10 psi when such a low voltage was applied. Then I removed my bench supply and reconnected the plug from the car to the fuel pump assembly and turned the key on and off several times. With each cycle, the pressure kept increasing. Next, I cranked the engine and after a few seconds, it started up. I let it run for a few minutes and then turned it off.The fuel pressure went from about 28 psi to 20 psi with the car off and held that pressure for about 20 minutes. That seemed quite good to me. I then removed the fuel pump gauge, reconnected the fuel filter and when I cranked it up again, it started right away. In summary, I think there was a dead spot in the motor that may have been cleared up when I tested the pump outside of the car. When the pump has no gas to pump, it is much easier for the pump motor to spin as indicated by the current readings, 12 volts, 1 amp outside the tank, 5 volts, 2 amps, inside the tank. I'm happy that the pump is working now but I'm sure it won't be long before it fails again so I'd like to replace it. I contacted the local salvage yard whose website said they have the part and asked about a warranty. I was told the part can be returned within 7 days. Does that sound like the industry standard? Should I pay a few extra bucks for an extended warranty? Thanks for your reply. mrfixiter
  8. Hi again. 😀 I finally had a chance to do some more troubleshooting. I pulled the connector to the fuel pump assembly and monitored the voltage (open circuit) at the plug. My helper turned the key to on and my meter peaked at the battery voltage and then quickly went back to zero as expected. I repeated the test but this time I added a 20 ohm load resistor across the same plug. The voltage dropped ever so so slightly. It was very hard to tell the difference because my meter doesn't have a peak hold feature. I believe whatever the difference was, it was negligible. Next, I removed the fuel pump from the tank and connected it directly to my 12 volt bench power supply. My bench supply has a 2 amp current limiter so when I applied voltage to it, the overload circuit on the power supply kicked in however when I brought up the voltage slowly, the current flow was a bit erratic at first but when it finally reached 12 volts, the current leveled off to about 1 amp. The only complaint that I could report was that the motor seemed a little noisy. Since this is the only fuel pump I've ever tested, I don't know how much noise is too much, what the average input current should be or what the input resistance of the motor is. It also occurred to me that even if the motor is spinning, that doesn't mean the pump is working properly. From here, I'll reinstall the same pump and attach a long hose to it and see if it is able to pump out gas into a gas can. Thanks for your reply. mrfixter
  9. Hi jonathan, Thanks for sharing your picker/wrecker experiences. I have a question about viewing these forum posts. Recently, the left frame of my screen has been overtaken with viewing stats. It lists who the top posters are, the most popular days, etc. I can't find any way to remove that from the display. In other words, is it possible to see the posts full screen without them being scrunched to one side by the stats? Thanks for your reply. mrfixiter
  10. I like your advice: "And I’d pull it from a vehicle with the most amount of dirt etc around the fuel pump plate." 😀 I suppose I should ask the proprietor of the salvage yard what the warranty is on a 25 year old fuel pump. The price quoted to me over the phone was $100. I think that price should include some implied warranty with it. I mean if it works at all, then it's probably in good shape, right? Thanks for your reply. mrfixiter
  11. I'll keep that in mind when I go shopping. Thanks for your reply. 😀 mrfixiter
  12. Now I'm really wondering if they're that reliable, I'd better make sure that the old one is defective! Thanks for your reply. mrfixiter
  13. No Pick 'n' Pulls nearby but I did search for salvage yards in my area and found one 30 minutes away which does have the part. The next question is, how can I make sure the fuel pump in the salvaged car is an OEM pump? Thanks for your reply. mrfixiter
  14. While I'm waiting for another opportunity to resume my troubleshooting, I was wondering, where do you go looking for a reliable, used, OEM Subaru fuel pump? Thanks for your reply. mrfixiter
  15. It is a lot of money to pay for a load resistor but if you do this for a living and charge top dollar for your time, then you're paying for the convenience. For most of us DIY'ers, we do this at our leisure and the extra time spent doesn't matter much. I think a 12V light bulb tester would work well for the weekend mechanic. mrfixiter
  16. Yes sirree! It's right there on page 2. Thanks for your reply. mrfixiter
  17. I think my previous post was too long and it was displaying improperly so I'll keep this short: Years ago, I remember seeing something like that in the manual but I've been searching through all the pdf's in my library and I've not been able to locate it. Any ideas which pdf contains this info? Most excellent. Thank you. Let's hope it doesn't come down to that! In other words, "Keep it simple." I have to remember that. Thanks for your replies. mrfixiter
  18. Well ladies and gentlemen, there seems to be some issue with me copying and pasting quotes from pg 1 to pg 2. All the formatting is messed up. I will try to reconstruct the content ASAP mrfixiter
  19. Yes, the schematics do show the connectors and their numbering but it would have been helpful to indicate which end of the connector is being shown. Is it the view from the end that plugs into its companion connector or is it the view from where the wires are inserted? I think CH could also stand for charcoal but that's not very close to brown. Thanks for your reply. mrfixiter
  20. Thanks for the warning about the plastic tabs. See the rest of my comments at the bottom of this post. The car has 189k miles on it and it's only been sitting for two weeks. I don't see any evidence that anyone has ever taken out the fuel pump assembly. Under the top panel, there is lots of dust which of course I will vacuum before I start removing the nuts. I already performed a fuel pressure test before this whole adventure began and the gauge didn't budge so if there is 12 V going to the plug at the fuel pump, the mystery will be solved. By the way, here is a picture of the plug that goes into the fuel pump assembly. Have I correctly identified pin numbers 1 and 4 as the test points for the 12 volt input? (See page 20 of the manual for reference) One other tidbit of information I'd like to share regarding the wiring diagrams and the abbreviations that are used for identifying the wires by color. This chart displays the abbreviations for each color. Who knew that "L" was the abbreviation for Blue? Thanks for all the helpful information and replies. mrfixiter
  21. Yes, you are both correct. I was working on it a few hours ago and realized that I had to lift off the carpet/panel in the cargo area and then I found it. Here is what was under the bench seat that confused me earlier: https://app.box.com/s/2ba0lyu86mzqgkzg2ac2blo6i2rsw9wo What I'd like to try next is to connect 12V via an external power supply to the pump before I remove the eight nuts. Would I be able to hear the pump if it's running? Any idea what the current draw is on the pump? Thanks for your help. mrfixiter
  22. My station wagon's rear seat is a bench seat which has a looped piece of fabric in the center. When you pull up on this "handle," the bench seat rotates 90 degrees into its up position. Directly underneath the passenger side of the vacated bench seat, is some sticky material (it did seem like the material was OEM) covering the spot where I saw fuel lines going down into what I believe now is the gas tank. Is that how your '95 was? Thanks very much for the detailed explanation about the sub-chapters, headings, and line numbers. Now it makes sense to me. 😀 If the 8mm nuts give me any resistance, I'm going to use PB blaster and then leave the vicinity for a while because those fumes are powerful. Regarding the replacement fuel pump, I hold off on that discussion until I determine the old one is defective. Thanks to all you for your replies. mrfixiter
  23. I would think a cover plate would be one of those essential items you'd want to reinstall especially since there is a gas tank located a few inches below it. I agree that there is much "overdo" about nothing in the service manual but sometimes those links point to more essential information that has left me scratching my head when those links are nowhere to be found. Thanks for your reply. 😀 mrfixiter
  24. Thanks for that info. I just had another look at the service manual (link below) and the sketch at the bottom page 10 is pretty much what I saw under the bench seat. Another interesting fact is that the R1 connector had been labeled "R1" with a sharpie like someone who previously fixed the car needed to remember that. Getting back to the sketch, how is it possible that I was able to see the fuel lines and the connector without removing an access panel? Maybe it's missing? I also looked for the 8mm nuts that secure everything in place but didn't see those either. There must be something I'm not seeing here. I'm going to snap some photos of all this when I go visit the car tomorrow and post it here if I can't figure it out. Link to sketch in service manual: https://app.box.com/s/wm7eg83tt11hsmt0c85rmrdway12g822 See page 10 Excellent idea. Why didn't I think of that? 😀 Yes, I did peruse the service manuals for my particular year however your prompting persuaded me to look again (see my reply above to Imdew). I will say that those online service manuals seem to be incomplete. For example these are the instructions for releasing the fuel pressure: I can't find anything in the fuel section of the manual that is labeled, "W1A0" Thanks for all of your very helpful replies. 👍 mrfixiter
