jazzmandolin
Everything posted by jazzmandolin
Hello, my 92 loyale wagon has not been warming up to normal operating temp no big deal until now it is getting cold. I pulled the thermostat housing to replace the old thermostat and LOW AND BEHOLD no thermostat!!!!!!! So my problem now is I have no old tstat to see the correct position for the new tstat. Can someone tell me how the new tstat should be positioned in the housing? My almost useless haynes manual just says to install exactly the way the old came out OH WELL. Please HELP. and THanks
Best method engine flush? I drained old super black quart low oil, form my new old loyale and put in 10 30 castrol syntec with a K&N filter, seems to have deminished the tick but it is still constant. Which is the best flush and how long should I leave additives in the motor? Is atf or marvins best and how long should each stay in? I think I read somewhere that someone fills full with atf runs only at idle for bout thirty minutes then replaces with new oil and filter. I am sure I will end up doing the oil pump seals possible oil pump and possibly the lifters later down the line but want to do a really good engine flush and clean before I start pulling parts! Also 400 miles after my initial oil change the level is still full and the oil is still clear, wondering if the oil is staying clean should I still do more flushing. 194,500 miles runs great but has pretty constant fairly loud lifter tap! Thanks for all your good input.
