Recommended Seattle area Rebuild shop for a EA82
Try All wheel Drive Auto. They have been around a long time.
Low Idle Speed
Jim Ma replied to zedhead's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck the EGR valve and check all the hoses for leaks. Check all hoses going to intake manifold for carbon block. there is a small pipe going from the EGR valve to the intake check it.
Timing belt change question...
Jim Ma replied to Mjez's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFirst, get a service manual. You need a chain wrench to hold the crank pulley to loosen the crank pulley bolt. Buy a timing belt kit,Gates or AC Delco are good The 2.2 is a clearance engine ,meaning if the belt fails the pistons won't hit the valves. I use . autopartsgeek.com, bmaautoparts.com, Rockauto.com Etc. I would replace the cam and crank seals ,water pump ,timing belt kit. The tensioner should be ok for 300k. use torque wrench on everything(In Lb), (Ft Lb). Don't touch the oil pump unless it is leaking. If you work on BMW this is a piece of cake. JM
What else to replace with timing belt?
Jim Ma replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI found some good Info. and photos for , timing belt ,oil pump.oil pan.water pump etc Beergarage.com
Power Steering Reservoir O-ring?
Jim Ma replied to Legback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPower steering pump repair kit Subaru # 34419AA150 list $35
Jim Ma replied to Legback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs it a gasket or a o ring on the back of the pump? Is it available at dealer?
timing belt
Check out this website,there is an article on timing belt allwheeldriveauto.com
timing belt
A note on timing belt change. To loosen the crankshaft pulley bolt I use a bought a chain wrench (Harbor Freight) it goes all the way around the crank pulley and stops it from turning. There is a great site that shows timing belt replacement and other tips ,check it out. allwheeldriveauto.com or Beergarage.com good photos
Jim Ma
