Everything posted by raging squirrel
5 lug swap?
I am looking at various wheel options for my 79 Brat. I have considered finding rare alloy wheels with the 4x140 pattern, redrilling 6 lugs ( hard to find 13" or 14" alloys), or doing the 5 lug conversion. The 5 lug seems to have the most appeal since used 5 luggers are pretty common. I searched a little and was treated to an overload of non related information and some related info, but not much specific to these older cars. What is the most simple way of going about this? Is it mostly a bolt on swap of hubs, spindles and brakes? What about hub spline counts?
79 Brat conversion: you may question my sanity
I suppose I should put this here, we will see if I can figure out how to post the pics. I am taking my 1979 Brat and converting it to rear drive only with a Metro 1.0 3cyl. engine and Suzuki Samurai transmission. I love the mileage of the Metro, but prefer the style and utility of the Brat. After serious number crunching and research, the project is feasible. I will need to shed a few hundred pounds to have a power to weight ratio acceptable for the engine. Half of this will occur as a mere bi-product of the swap itself. Some of it will come from the removal of non-essential parts and parts that are not compatible with the new power plant. This includes the original jumpseat assembly, in case anyone needs that for a restoration. After that, further weight loss will come from a variety of hand built parts as time and fishing allow. Some numbers: My current 95 Metro has a factory curb weight of 1880 lbs. The 79 Brat has an official weight of 2175. The Metro and Samurai transmissions share similar gear ratios. The Metro has a final drive ratio of 4.10:1, XFI versions (the ultimate fuel saver version) has a final drive of 3.52:1. The Brat, I believe, is about 3.70:1. The optional Limited slip is a 3.90:1. All in all, a pretty good match for my goals. My two big obstacles are weight reduction and fitting a speedometer drive since the trans has no provision. A simple drive from a motorcycle hub mounted to the back of one of the front hubs (remember, the half shafts will no longer be there) will likely be the solution since the magnetic rotor in the speedo unit doesn't care what is turning it and they really are all the same from my research. The front tire on a street bike has roughly the same diameter as the tires on the brat, so it should be accurate enough. I will be using the Metro speedo unit most likely, since I believe that the fuel injection ECU does get input from a VSS (vehicle speed sensor) in the speedo. I am awaiting my diagrams to confirm this. I am using the simpler harness and more fuel efficient management system from a 91 Metro. Depending on how this version works, the ECU and camshaft from the XFI version may get swapped in later for an increase in fuel efficiency. The XFI stuff will cost HP, but the torque rating is the same. A few enhancements to build a little more torque would get me a power to weight ratio at 2000 lbs. curb equal to my current car at 1880lbs. Three ft/lbs. is all it would take. Still no rocket, but a great little runabout for a man who commonly racks up 120-300 miles in a single day. Anyway, time for photos.
Difficult to locate items?
I actually be removing my ea71 and certain other parts. The car seems to run fine, but I have other things in mind. I am building a high MPG unit with my 79 Brat. I love my Geo Metro for it's mileage, but desperately need something with a bed. I need the mileage too. So by means of a Metro 3cyl., a Samurai transmission (this will be rear wheel drive only), and a serious diet plan; this is what I shall have. I hope the purists are not excessively enraged. I love the Subaru Brat, however, 40mpg (or better) is an absolute must for my lifestyle. Why not have both? I am considering using the Metro's hvac system also, since it would adapt easily and provide much better parts availability. As far as welding thin body panels is concerned, I have cut a Suzuki Samurai and a Geo Tracker completely in half and welded them back together. One was a hot rod cab build and the other was a stretch job. I recently completed a 1/2 cab conversion on my current Samurai. If you think 20 ga. is thin, start working with Suzuki stuff! Thanks for the replies. I will have to start "rat holing" spare parts! I know where there is a real nice wagon...
Axle question.
A note on CV boots: be sure to apply plenty of grease inside of the lobes(grooves) or premature wear/failure may result. Don't assume that the grease will fling out from the joint and take care of it automatically. This applies to any CV boot, even ATV's.
I need advice concerning replacement items with this generation of Subies. Which items are difficult to obtain when replacement is needed? I have heard that heater cores and front struts are not easy to find. What else? A heads up on other items would be most appreciated. Feel free to make as long a response as necessary. Thank you in advance.
Body part match up?
Thanks, I knew there were folks here who would be up on this stuff. Subaru's are relatively new ground to me. Most of my experience has been with classic American pickups, Suzuki products, and severe duty offroad rigs.
Gas tank vent tube
If you find 3/8 vinyl, it can be heat formed to surprising dimensions. A standard size fired case from any rifle like a 22-250, .243, .308, 30-06, etc. works great as a forming shaft. This goes without saying, but since you never know who will read this, DO NOT use a loaded round! Any spent case with the .473 case head will work. Heat the vinyl tubing till it is fairly soft and slide it up the tapered case. Then cool it in cold water. The vinyl will take this size permanently now. It's that easy. This should provide a snug fit for a 7/16" fitting.
Body part match up?
Gee, it's sure nice that absolutely nobody is in possession of such knowledge here. Seriously, not one answer? This would be useful information (for myself and others) in the event of a collision.
5speed d/r weight?
My plans are MUCH different than that. So here goes: Remove Subaru engine, transaxle/t-case assembly, half shafts, and radiator. Remove Jump seat assembly if still there. Replace parts using Metro radiator and engine, and Suzuki Samurai 5speed transmission. The Metro 3cyl. bolts directly to the Samurai transmission. Required items: custom engine mounts, radiator mounts, and transmission crossmember. I will also need to build a stand alone efi harness and modify the gas tank for the fuel pump. This will be rear drive only. No need for four wheel drive, I have a custom built Samurai for serious offroad use. It was a complete frame up build and vastly more complicated and labor intensive than this. This is more of a weekend project at best (outside of the wiring harness which will take a few days to do right). Metros? I have owned four of them and still drive one. I know about the valves, not as big of a problem as most think, if properly addressed. Bottom line is that I need something with a pickup box to haul baitfish and other malodorous or bulky items while maintaining economy. The Brat is the lightest platform to start with other than the VW rabbit truck. The Brat makes for an easy rear drive conversion, the VW does not. With proper weight distribution, rear drive is better in the snow or on sand trails. My 64 Ranchero was proof of that. Then there is the limited slip option too. I do intend to use the Metro XFI ecu and camshaft. This is what gave that model a 58mpg rating (along with gearing). The weight figures: the Metro I currently drive is the heavier 95 model with a factory curb weight of 1880 lbs. The FSM specs for non turbo Brat models range from 2175-2245 lbs. After doing the math, The lighter drive components along with ditching the jumpseats and all non Metro underhood items will get me very close to Metro weight. I can easily keep the weight of the few hand fabbed conversion items to less than 10 lbs total. The thinwall 4130 tube crossmember will weigh less than 2 lbs. The factory engine/transaxle mounts are aluminum and will be reused. Remember, the engine only produces 60 lb/ft of torque, no need to us 1/4" plate for the mounting tabs. There are many other items than can be replaced with parts of my own manufacture to get me well below that 1880 mark. Non structural parts. I can later address those in my spare time. Not my first trip around the block with altering a car or truck. A tremendous amount of thought has gone into this over the past several months. I cannot, however, reach the early Metro model's weight of 1650 lbs. So it will not be a ball of fire for sure. Merely adequate transport at a minimum of operating expense...and much cooler than my Metro!
5speed d/r weight?
$100 or 100 lbs.?
5speed d/r weight?
5 speed hi/lo. I am looking into a Metro 3 cyl conversion and am calculating finished vehicle weight to see if it is feasible. Always wanted a 50mpg Brat! I have found a reasonable way to build it, but overall weight will decide if it will work. Thanks.
5speed d/r weight?
Does anyone here know what the 5 speed d/r transmission weighs? Anyone shipped one? I need to know for a project I am planning. Anyone got one laying around that they could toss on the old bathroom scale? Thanks in advance.
Body part match up?
I am wondering which body panels, doors etc. that the 78-81 Brat shares in common with the sedans and wagons. With old Ford Rancheros, I know that the rear quarters are the same as the wagon, but not the sedan. I am wondering if there is similar interchanges now that I am in the Subaru game and needing spare parts. I do know that the front fenders and hood interchange, but don't know about doors, glass, tailgates, or rear quarters. Info would be greatly appreciated. Thanks!
pistons
No numbers yet, I think it would be fairly simple to find those through any parts supplier that carries soobie parts. I plan to look up a few vehicles that came with the EA 82 engine. Loyales seem to be one of the common models.
brat body on toyota frame with 350 engine?
A couple of recommendations here from someone who has actually built things crazier than what you are considering (honestly). Chevy fan or otherwise (I know how vicious brand loyalties grow), I would ditch the 350 in favor of something else. I made similar comments in another thread recently. Physical dimensions are the reason. The Chevy small block weighs between 525-575lbs. depending on configuration. A Ford 5.0 runs about 435lbs. and is noticeably shorter, narrower, and has the distributor in the front where it won't have clearance issues with the Brat firewall. The Ford trannies are usually shorter too to help with driveshaft issues that arise with short wheelbase rigs. Other options are the 4.3 Chevy (only 10 lbs. lighter than than the Ford v-8 though), Buick 3.8 v-6 (some came with superchargers!), the Ford 3.8 v-6 (only 300 lbs.), and the 62-64 Buick/Olds. 215 aluminum v-8. For some reason the Buick 215 weighs 318 lbs. and the Olds. weighs in at 350 lbs. All of these engines will fit easier than the 350 and can be built to power levels ranging from good to outstanding. If you want a mud/sand racer and sheer horsepower is a must, guys have got into the 1000+ hp realm with turboed 5.0's running as little as 11 psi. But that gets real spendy and destroys trannies, t-cases, and axles! I like the idea of a Samurai frame. I currently have a project involving a stretched Samurai frame. If you wish to see photos of the frame modifications and a description I posted it on Pirate 4x4 and Zuwharrie bbs. Search "Project Scrat" on either site. You will need to be in Suzuki section on Pirate though. Just one more project I need to finish if the snow ever lets me finish building a shop! The early Bronco frame would be great if you go with Ford running gear. You would be looking at very little modification. Mostly a body swap and wiring, the wheelbase may even match (haven't checked). The Ford axles will take much more abuse than the competition too. The front axles had the "reverse cut" ring and pinion. The reverse cut, commonly known as "high pinion", is about 30% stronger as a front axle application. There is a benefit in terms of driveshaft angle too. Ford also spec'ed higher grade alloy in their axle shafts. But beware that early Bronco stuff is getting expensive. I have done several 4x4's where I either lengthened or shortened the frame and body both. If you have any questions, send me a PM and I will try to answer them in a timely manner. I don't access the internet every day, but do check my messages when I do. I will be glad to help.
pistons
I just discussed this via PM with another member. It seems that the EA 71 pistons and EA 82 pistons will fit. I have been convinced that EA 82's are the way to go since they will start me out at around 9.5:1.
CV carbs?
After discussion with my carb tech buddy, it seems that I was correct in believing that the "pulse issue" was not a big deal. He did, however, point out something that I overlooked. How am I going to play with needle profiles when I can not tell how far open the slide is? A simple response is to tune with the air box, filter, and duct work disconnected. Problem is that this affects air flow and vacuum at the throttle valve. Hmmm...it may get me close enough to be at the "fine tuning" point though. Especially if my filter system is very free flowing. I may have to lean things out a bit to compensate for heavier engine loads afterwards, but the CV system should prevent the need for most of that. Since the throttle valve only opens enough to feed the amount of air the engine can actually use, "over throttling" under heavy loads should not be possible. I will post up some results when the time comes, assuming that I actually go through with this. I will first use a Weber to establish a good baseline for comparison.
Gen 1 5speed D/R differences?
The vehicle in question is a 1981 brat with the EA81 engine. I have heard that a custom shaft is only needed for the wagon, but if I must cross that hurdle, it's no biggie. I was aware of the possibility of trans tunnel mods, bellhousing clearance issues, and possibly shifter location issues. Nothing scary so far. I have studied the gear ratio charts and decided the 5 speed will be worthwhile since the difference in the gear splits will be handy for tackling our mountain passes or light towing. It looks like I need to find an EA82 donor car...
I may have to do that. Thanks.
CV carbs?
I will be studying this some more, a good friend of mine is an expert with carb tuning and theories. He makes part of his living doing it, so he may have some very useful input. I may try this and the Weber and see which works best. I have given some thought to flat slide carburetion as well since it responds to the pulse so much quicker, but this may not help me with mileage. If raw acceleration was the goal, I feel that flat slides would offer potential. Just one more thing to wonder about...
Ok folks, I have searched and searched, so please no "search you (insert demeaning reference here)" comments. I found a good deal of info about this, but almost everything was performed in gen 2 cars. I found no buildups with any real details on the differences of putting the 5spd. D/R in the gen 1 vs. the gen 2. So, the crux of the matter is, I need to know what to look out for. What additional items must I tend to when the time comes? I believe there is some sort of crossmember issue. I have made several custom tubular crossmembers for various swaps, so that is no biggie if I know what I am working with. Any experts?
CV carbs?
Understood. I do realize the differences in needle tapers, etc. Been down that road before. I was referring to the fact that all carbs require vacuum to draw in air and pull fuel through the jets and past the needle. As long as the air flow requirements are sufficient, the carb mixes air and fuel. An O2 meter would greatly aid me in finding that perfect taper. I got thinking about the pulsing intake/vacuum theory. Kawasaki atv's ran single cyl. 4-strokes with CV's and they worked well. A single gives about as much start and stop to the charge as possible. The common plenum intake with a pair of CV's setup as a progressive two barrel (like the Weber) may provide the most consistent vac and flow. The goal of which is to improve fuel atomization, thereby making the charge easier to ignite and burn more thoroughly (more power from the same amount of fuel).
Exhausting topics:single, dual, or dual with"X"
There are similarities with what you have and what I plan. I have a few questions, most of which depend on if you ran your car stock before modifying it. Before and after impression of cam change? Torque and mileage comparison? Any idea what your compression is with the O/S pistons? Big valve heads-before and after? I have pondered the big valve heads since I have 3 engines to choose from. I was wondering at what rpm level they become an improvement and what the trade off in low end, vacuum, and mileage will be.
CV carbs?
Smoothing the air flow was kind of the idea. It can help fuel mileage without hurting horsepower. Acceleration potential is higher with a non CV carb, but in reality, most people can't truly control the throttle well enough to do it. But we are not talking performance bikes, this is a long range cruiser Brat. I had intended to dedicate 1 carb for each pair of cylinders, which should nullify some of the pulsing vacuum draw. The other option was to run all 4 cylinders off of a pair of carbs attached to a common intake plenum. The second option would tend to have less vacuum than a short runner at each head though, and would tune the engine for a higher rpm range, not what I am after. The most common source for CV carbs in our neck of the woods is actually ATV's. Not sure about converting for 4 stroke use, I didn't realize that they were ever used on 2-strokes. I do know that there is a difference between gravity fed and pressure fed applications. A smaller fuel inlet orifice is required when using a fuel pump. Other than that, a carb doesn't really care or know what it is feeding. Anyone actually try the CV's?
Pulse velocity is likely to be the most important factor with the goals I have. I will be starting with a fresh engine and am leaning toward a carb setup. Not the factory carb though. I understand that efi systems are best with a little more intake and exhaust volume, but that can always be changed later. I live in Wyoming, cats are something with four paws and wiskers. A small diameter dual system may be the best, probably 1 3/4". I can't help but wonder if a single would create a stronger vacuum at the cylinders. It should, but having to split that vacuum between two cylinders (the timing order thing) may negate that and then some.
