Everything posted by darthsoob
My Brat is dying on the road
Well, I fill it with gas treatment and hose the bejesus out of the rest of it and it ran great. However the same problem did come back. It only seems to do it after it has warmed up. Hhmmm. Anyone?
While driving down the highway when I have to slow down for say getting off at the offramp or stop and go traffic I put in the clutch to take it out of gear and the RPMs just drop out and the engine dies. It will start up with no problem but as you can imagine it'a a pain you know where! If I can keep the gas going without rear ending the car in front of me I'm good to go. Don't think it's the filter cause I replaced that a few months back, no sign of vacumn line leak or unplug. Anyone have any hints? Thanks All! PS. 87 Brat hitachi carb
Coughing Brat...Update
Well I was finally able to replace the two filters and it did the trick. Thanks to all who took the time to help!
Looking for a Good Source for EA82 Brush Guard
I do have one of the EA81 long style pushbars but like everyone is saying you would have to adapt it. I had a guy interested in buying it earlier, problem is it would cost more to ship it than the cost of the pushbar itself. I would have to agree that your best bet overall is to have one fabed. Good luck!
My little Brat has picked up a cough. It runs just great all through town and on the highway, however when I try to up a hill it starts to miss. The steeper the hill the more it coughs. I looked for vacuum leaks and found the vac advance was bad and replaced it. Still coughing up on the hills though. This weekend I am going to replace all the old vacuum lines, new plugs, cap and rotor and do the timing. My question to the board is this; is there anything else I should look for? Any typical problems this might fit? Thanks to all who take the time to look!
Easy BRAT heater core clean?
Wel, l I can open one of the ducts and fish out some of the needles with a homemade vacumn attachment, too narrow to get a hand in, but it won't get the needles that have already plugged the core. Was just curious if someone had a trick.
87 BRAT with a fully functional heater however pine needles have invaded. Anyone out there have an easy fix that does not involve pulling the core? Thanks all!
87 Brat Shifter Poser
Well another life lesson learned. Maybe a board member in the area can use it.
OK, still bummed but at least now I know better. I'll probably junk the idea of fixing the slop in the shifter, at least for now. I almost wonder if drilling out the trans shifter rod and inserting a stainless steel drilled plug would do any good. Just an idea. Kudos on the tranny mount! Of course now I'll be spooked to look at my trans and discover its mounts have pancaked as well. By the way, what did the yard charge you for the 82 mounts?
Well now I'm bummed. I was hoping to do that fix and I find out from the author or the text no less it wears out. Don't you think the set screw thing will wear out as well? Wonder how much a new shifter is? By the way, went to Lowes and got sections of tubing at various diameters. When the rest of my parts come in, I should be able to make one of them work. Spent about a buck versus the $30 Subaru wanted.
GD, Did you already try this shifter fix? <http://www.ultimatesubaru.org/80s/mi...hifterFix.html> I a hoping not because I was going to try it after I found all the parts for the bushing repairs. I would hate to find out it didn't do any good. Maybe I'll have to see if it's possible to order a new shifter. I wonder if it's possible to find some sort of sleeve to fit between the two. Maybe use a drill press to reem out the shifter so that a sleeve could be used.
Actually I was planning on going through the plumbing department this weekend to see if I could find something similar. So far the shifter is working well enough but I thought I still might try to find some sort of void filler and I also read on the board last night how to tighten up the bracket. Hit the gold mine....well almost!
GD, Did find out that I have in fact identified the part. Bad news is on the Subaruparts.com it lists as no longer available. "Good" news, the cheapest is $30. Got any more of those sleeves? Thanks for the input! I knew I could count on the board! Darth
Hi all, went to replace all the shifter bushings, etc on my 87 Brat, 4 spd, dual range, and when I finally got near the end, of course, I noticed I didn't have a replacement piece. The one missing was a white nylon sleeve, about 1" tall, that sat down in the socket joint of the tranny that held the bottom of the shifter lever. Guess it acted as a spacer for the shifter. Went to two dealers and it doesn't even show up in their books, at least not on the shifter page. I did happen to see something that MIGHT be what I'm looking for on the page that showed the transmission extension for the 4wd models but I was hoping to get feedback from any of you that may have run accross this. By chance does anyone know what the part number is or where to find it? Second, the U fork that is roll-pinned to the transmission shifter rod, should that have a spacer or bushing of some kind? Mine seems to be a bit sloppy. Or is this an intended thing? Thanks to anyone who can help!
transaxle seal question
To all those who would venture an opinion, I think I have a leak from the driveshaft end of the transaxle (2nd Gen Brat, EA81 manual trans/ 4WD). My question is simply, is this an easy fix? Can I drop the driveshaft and get at the bad seal to replace it or will it require any special tools, tricks or new Four Letter Words? Thanks, Brian
For the trivia minded
If a Subaru model was a Brat in the US, a Brumby in Australia, what was it called in Japan? (no, I don't know)
For Those with a short style pushbar...
I finally managed to get my hands on a pushbar but I have no idea what the foward hanger supports are supposed to look like. Rather than waste two whole weekends and any other parts of my anatomy, I would like to ask those of you out there who already have a short style if you could send me a drawing with all the appropriate measurements, etc. Here's hoping to hear from you! Thanks, Brian
part number?
Thanks, Shawn. I looked it up on Subaruparts.com and they wanted $57 for it. 1st Soob didn't even have a listing for it. Any other sources you know of? Thanks!
part number?
Does anyone out there know the part number for the stop light checker for an 87 Brat? I don't have access to any part sheets. Thanks!
Opinions wanted: Best parts place
I just saw a listing for <http://www.newsubaru.com> that someone on the board highly recommended. I also know about <subaruparts.com> and <1stsubaruparts.com>. I have tried all three and was just curious if anyone knew of any others. The thing that bothers me about all three of the aforementioned is the fact that you have to know the part number, but they do not have anyway for a person to look it up themselves.
online parts sheets?
my interest is in an 87 Brat.
Just looked but didn't see any diagrams. Did I miss something?
Does anyone out there know of any sites that a soob owner can look up the appropriate part for their cars? You know, like the exploded views that the dealers have?
brat failed smog (but not the second time)
First time I went in Brat blew a 1.65 for the CO in idle mode (1.2 is the limit. This time it was a 0.06! Now for the fun bit; while sitting in the little booth while the "tech" runs the car, I notice coolant flowing out of the Brat. I run over, look at the dash and he has revved it up past 6K! After telling him to shift he says "I thought I had it in 5th." To bad my brat only has 4! Ah, state emplyoees....
I suppose you are funny...in your version of reality. Just Kidding! As far as my brat is concerned, I fixed the exhaust leak, installed new plugs, new PCV and reemed out all the hoses and kicked up the idle just a bit. Didn't find any vacumn leaks, timing was on, air filter clean,and did the oil change last week. I expect to take it back for smogging on Wednesday. If you hear of someone going postal at an emissions station you all know NOTHING! Anonymous
