Everything posted by darthsoob
Baja engine Surge
In my 2005 Baja Turbo Automatic; i was stopped waiting to turn into traffic from a parking lot, my foot on the brake when the engine surged from 800 to somewhere around 6,000 rpm. did not see any idiot lights come on, so I tried to put in in neutral, the rpm went down very briefly but shot right back up. I then had the presence of mind to shut off the engine, waiting a few seconds and restarted. Car ran just fine then. Good thing I had my foot on the brake when it surged. Has anyone else had this happen to them? Anyone hear of a cause? Thanks.
Question for the Masses
darthsoob replied to darthsoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust approaching 100k. Car is entrirely clean, now wrecks and I do my best on regular maintanance. I sat for 4 months while I was working out of state but it is back to regualr commuting. I have been looking all around but it only seems to put out small amounts of steam. Don't believe it is the front of the car. If it would dribble fluid, I'm sure I could track it down.
darthsoob replied to darthsoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave not been able to see any drips that is what is making it so difficult. All I get is faint steam and I have been unable to trace the leak. As a result, I have been having to keep to coolant level topped off. It doesn't leak alot, but this is something I want to stop before it becomes a big problem.
I have an 05 Baja Turbo that has developed a minor coolant leak while it sat for a few months. Once the engine get up to running temp, especially if I have started driving, it will have a bit of steam coming from under the hood on the passenger's side. Of course I have looked for the obvious leak but have been unable to track it down. Get really annoying when I run the cabin fan and smell the stuff. Anyone out there run across any likely spots to check? Thanks All!
Remote starter location???
darthsoob replied to darthsoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFound it! It was shoved way up above the fuse block. Thanks.
I have asked this before so sorry if it seems redundant. In a 2003 Legacy/Baja does anyone know where a remote starter module(?) is tied in? I have looked underneath the dash for anything out of the ordinary and no luck. Just hoping someone out there has had some experience with them. Thanks to all for looking!
Baja Turbo vs. Sport
darthsoob replied to darthsoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnyone? Banjo bolt...
Baja tonneau covers- How many kinds
darthsoob replied to darthsoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXActually I already have an ARE topper on my current Baja. It makes visibility bad and hard to see out the back in the rearview mirror because of the tint in both the rear windshield and topper liftgate glass. I also have a soft tonneau but want something I can lock.
Anyonw know how many different tonneau hard covers there are for a Baja? I am looking to get one (Tacoma, WA area) and would like to know the different makers and features. Any opinions on the different styles voice them here.Thanks!
darthsoob replied to darthsoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo where exactly does one find the Banjo Bolt? I am assuming it does in fact resemble a banjo.
darthsoob replied to darthsoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for the input!
darthsoob replied to darthsoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGood to know. Anyone know of anything in particular to watch out for?
darthsoob replied to darthsoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnyone know how long you can expect a descently maintained turbo engine to last?
Opinions please. I understand that the Baja turbo models don't get as good gas mileage as the non-turbo models. I understand they are more peppy but wonder if they are more prone to needing maitanence/repairs than non-tubos. Any thought/considerations pro or con. I have a sport model but looking into buying a turbo model. Thanks All!
Baja component location
darthsoob replied to darthsoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbump.
Anyone out there know where to find the module for the remote starter on an 03 Baja? I assume it is somewhere under the dash.
03 Baja Remote Starter
darthsoob replied to darthsoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI was under the hood for other reasons. I thought I may have disconnected a wire but I tried it in the garage this morning and the remote starter worked. However I tried it later in the afternoon and it didn't work again. Usually when I push the button twice, the running lights flash before the stater kicks in. They didn't this afternoon. I do think that direct sunlight interferes with the signal, but I pulled it back into the garage, closed the door and tried it again. No luck. And yes, the LED on the fob does light up when I push the button.
Had to change the battery in the Remote Starter keyfob and unless I managed to disconnect something while under the hood it still doesn't work. Does anyone know if there is a procedure to "reset" the system? I bought the car used so it didn't come with any info for the Remote Starter. Thanks ALL!
Anyone replaced a Baja Fuel Filter?
darthsoob replied to darthsoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs it turns out I should have looked before asking. The manual I was looking at was for a Legacy-there are none specific to Bajas. The filter is in the engine compartment and pretty easy to get to. Good luck to all!
Wondering if replacing the Fuel Filter in an 03 Baja is worth doing at home or better as a shop job. Opinions? Any tips or tricks? Any Gaskets or O-rings to watch out for? Thanks, All!
Is there a Baja Service manual?
darthsoob replied to darthsoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks to the both of you!
I have been trying to find a service manual for an 03 Baja either paper or CD but haven't had any luck. Anyone out there found any source? Thanks!
Where is the carb model number?
Much as I would like to Webberize I don't know that the car would pass emissions, the cost of conversion vs. kit rebuild and what to do will all the vacumn lines kinda has me going toward rebuild. Sorry. As for the model number I saw something on the back of the float bowl but the three digits I saw didn't match any kit numbers. I will have to pull off the air cleaner and take a better look at the front of the bowl. Thanks!
I have to to a rebuild on my hitachi 2 barrel carb for my 87 brat but I for the life of me can't find the carb model number. I saw something on the back side of the float bowl that appeared to be silkscreened but I thought the model number would have been engraved. Where should I look?
To Weber or not to Weber?
Just got my 87 Brat back from the shop and they said I need to have the carb (Hitachi) rebuilt. So If I were to go all through that I was wondering about swapping over to a Weber. 1). Would it pass WA state emissions? 2). Would it work with a factory cruise control or would I have to junk that? 3). Is there a SIMPLE guide out there to show me how all the vacumn lines and crap have to be either rerouted or capped? Anyone with an opinion please chime in!
