General chaos
Posts posted by General chaos
thank you i will check that as soon a the car gets home. i cant see both elements buring out at the same tiem. but i will check that also.
oh. thank you. the wagon engine is a single cam. the cover looks just like my car does.
93 legacy 4 dr sedan. we have low beams but no high beams. is this the turn signal switch or is there a relay that controls it instead not in the turn signal switch?
thanks for that info. then i am guessing it was amid year change or this engine has been changed before the wagon hit that deer.
how do you tell a 2.2 from a 2.5 by just looking at it? is there a code on the fender tag i should look at to tell? mine has a 2.2. the one i'm looking at i thought was a 2.2. but it may be a 2.5. the power steering bracket is different and the cars are both the same year. 93 mine is a legacy sedan. the other is a legacy wagon.
no high beams
Posted
fixed. thank you again. the relay must have not been making a good connection. i swapped them. the two closest to the shock tower and i had both bright and dim. i then switched them back to where they were and i still have bright and dim. so once again thank you.
