Well I've followed a bunch of different threads about this Torque binding problem as I am experiencing it in my 97 outback legacy 4EAT. I've posted in a couple, but no answer so far, so I'm attempting to make my own thread.
Here's what I have done so far.
Got the code 24 and went ahead and did a duty-c change. The only thing I think could have been done wrong was putting the spring it its correct location as it sprung out when I took the casing off. If anybody thinks that could be an issue let me know. I'm not sure it is in the correct location.
The fwd fuse has never done anything. I've done several atf changes.
The lastest that I've done is going thru the diagnostice manual for the code 24 as follows it failed 1.4) and 3. It did pass the other ones.
1. CHECK HARNESS AND CONNECTORS BETWEEN
TCM AND DUTY SOLENOID C.
1) Turn ignition switch to OFF.
2) Disconnect connectors from TCM and transmission.
3) Measure resistance of harness connector between
Connector & terminal / Specified resistance:
(B52) No. 3 — (B9) No. 11 / 1 Ω, or less
4) Measure resistance of harness connector between
TCM and body to make sure that circuit does not short.
(B52) No. 3 — Body / 1 MΩ, or more
2. CHECK DUTY SOLENOID C’s GROUND LINE.
Measure resistance between transmission connector
receptacle and transmission case.
(T4) No. 4 — Transmission / 1 Ω, or less
3. CHECK DUTY SOLENOID C.
receptacle’s terminals.
(T4) No. 11 — No. 4 / 9 — 17 Ω
I am now at a loss, as I think that there is a short circuit issue and I don't know how to go about fixing it. Let me know what you guys think. I also did just go out and pulled the code again got 24, but what I did notice is that when I restarted the car after pulling the code, the fwd light was one for about 1 sec, but only after pulling the code (this is of course with a fuse in) not sure if this means anything.
