97preza
Posts posted by 97preza
So my 97 impreza OBS has started leaking oil from the passenger side cam seal. I am gonna go ahead and do the timing belt, water pump, and idler pulleys while i am in there, but my question is about the cam seals. i wanna go ahead and do both sides, but is it as simple as removing the cam gears, removing the old seals and popping in the new seals??? Am i missing something? Dont wanna expect to do this and something else pop up. Any help and info is greatly appreciated. Thanks in advance.
I have the same year/car with manual trans also. Mine makes the groaning noise in neutral off the clutch and driving off the clutch. i have owned the car for 1 1/2 years and its done this since i bought it. I drive it every day and even take it trailing every chance i get. I would like to figure out what it is so when something does give, i guess i can be that much more prepared. Let me know if you figure anything out.
NICE!!!!! I didnt even think to check ebay. The cheapest ones i had found were $220. This helps out. After installing the taller struts and springs, i need to center my rear wheels for taller tires Thanks Guys!!
I have a 97 impreza OBS and i am looking for some inexpenive adjustable trailing arms to set my rear wheels back center of my fender wells. Any ideas???
So after a trip to the local junkyard, i found a 97 legacy with the 2.2 and grabbed the TPS. I installed it in the driveway at home and "adjusted it by ear" and the idle has been fine ever since. Then i was having the problem of being able to push down the gas pedal about 1 inch with no changes in RPMs. So finally at work today, i adjusted it properly and the car runs like new I am glad to have this thing running good again!! Thanks to all who threw in there comments and helpful info to help out. Thanks again everyone!!!
Ok, so after all of this, i finally get a "check engine" light. The code reads "PO122, throttle/pedal position sensor switch A circuit low." Would this suggest that the TPS sensor is bad and make my car idle high sometimes??? I know i can just buy a new sensor, but then i am not sure how to calibrate it. ANy info would be great.
it has the 2.2. And it only happens sometimes.
It will run fine for a couple days or so. Then just show up on the way to work on most occasions. I went to mess with it on lunch today and to my surprise it was idling good as soon as i started it up. It ran good on the way home. It sat for about 2 hrs, then drove to the store and half way to the store(4 or 5 miles), it was idling high again when i came to a stop at the traffic light. Went into the store for about 15 mins and when i started it to leave, it idled fine all the way home. It seems very puzzling to me as well (and very annoying) Thanks to everyone for all the info so far!!! I would love to have this fixed in the near future;)
so it started acting up again. i changed the MAF and it didnt change anything. now i am leaning more towards the IAC valve. i have pulled this off before and cleaned it with no improvements. i dont want to run out and start buying parts, but this is driving me crazy when it happens!!!!
Thanks everyone for your info. I believe it has some thing to do with the MAF. So i bought some brake clean and when the idle starts to act up, i spray the brake clean through the air box and the idle drops imediately, like the MAF is dirty. so if/when it acts up again, i will try this again and see if it helps. If so, i guess i will be buying a new sensor. Thanks again for all you info. Its great to have people on here who can help in times of need.
So, i have cleaned my MAF sensor, changed my MAF, run cleaner through the Idle Air Control Valve, and cleaned my throttle body and still my idle stays around 1500rpm at traffic lights. Sometimes it doesnt happen and sometimes it does. i have checked for vaccum leaks and found nothing. I have no "check engine" lights. This is getting pretty annoying and difficult to drive. Any help is GREATLY appreciated!!!!!
Nice impreza!!! What suspension setup are you running?? I really wish i had trails like that around here.
haha!! thanks for the advice! i HOPE somehow i get lucky and can find some that someone already has off the car and hopefully i can get mine off :-\
so i picked up some struts/springs from a 1998 outback limited today. they are going on my 1997 impreza OBS in hopes of achieving some lift. hopefully i can get at least an inch and a half with just these parts. i will post some pics soon!! they came from the local pick n save junkyard. i tried to get the trailing arm brackets to set the rear tires back in place but couldnt get them off the donar car. hopefully i can find someone on one of these forums that has them for sale. any ideas or may have some?? thanks everyone.
Hey Adventure, are you selling strut top spacers??? if so, how tall and what price? and how much lift am i looking at with just the struts/springs of the legacy outback? this car will still be a DD so i need it to still be road worthy.
Bump!!
well my goal is a little lift. maybe 1 to 2 inches or a little more the local junkyard has a 1996 legacy outback and i didnt want to waste time and $80 for nothing. thanks for the fast response!!
i was wondering if the struts/spring swap from an 1996 legacy outback limited will work on my 1997 impreza OBS? i am sure this has been answered before so sorry for asking again. thanks for any responses.
I LIKE IT!!! I have the same plans for my 97 OBS. forester struts/springs but minus the spacers. i see you said it still handles good. i still plan to drive mine every day. GREAT LOOKING CAR!!
thanks everyone for all the info!!!!
the horn still works fine. i dont have cruise control. does anyone have any pictures of the location of the clock spring?
1997 ej22 cam seals?
in NA Fuel Injection Engine Tech
Posted
Thanks Torx!! Thats the answer i was looking for. Easy enough!! Found some part numbers for the cam seals and the crank seal. I guess i will buy the timing belt kit to while i have everything apart. Thanks everyone for the info.
