ca95965
Posts posted by ca95965
Thanks, you're obviously right. Hey, should I take the tensioner into town when I go tomorrow and ask an auto parts person if it should be replaced? Is there a way to tell by looking at it?
Mary
now the cr.shaft pully bolt won't come off
While taking things apart in order to get at the broken bolt holing the tensioner on we got stuck because the cranshaft pully bolt won't come off.
There must be some creative solution - we don't have a 21mm socket and don't have an impact wrench. We have tried open-ended wrenches, pipe wrenches, and even found a lug wrench that fit, but even with the radiator off there's just no room for turn or torque. None of the wrenches we have will fit down in there so that the tool is able to slide over the nut.
Is THIS something I should consider drilling out too? My friend thinks not, but we're many many miles from stores and if there's some oddball way to make it work I would love to hear of one.
Thanks in advance,
Mary
Thanks in advance,
Mary
Oh, thank you thank you SO much. It's a bit recessed. I wondered why we weren't removing the radiator in the first place, cuz it sure does seem to be in the way.I am happy for the information you gave. I'll be very careful with the drilling.
Thanks again.
Mary
Thanks again.
Mary
okay, two possibilities1: there is still some of the bolt protruding out of the hole
2: the bolt has sheared off flush with the block, or recessed inside it
Secnario 1: easiest way is to remove the radiator for better access (not an incredibly big deal, the hardest part is likely to be removing the hoses that are on the thing) Then your friend could use a pair of vise grips to remove the bolt. If needs be, take a dremel or grinder of some sort and grind two flat spots on it for the vise grips to hold onto better...
Scenario 2: also, remove the radiator for easier access, and get your friend to try drilling it out. do NOT let him use an easy-out, these things are BAD JUJU.. its just that these "easy-outs" frequently bind up, and snap off inside the bolt.. have him center punch the remains of the bolt as best he can, drill it with a small bit first, then gradually step up to larger bits. Worst case scenario in this situation, he cannot successfully get a hole cenetered, and winds up slightly stripping out the threads. In that case, he will need to go get something called a Heli-coil set, which is used to drill an oversized hole, tap it and thread a small insert in there that has thread on the inside of it for your new tensioner bolt.
This is a crummy situation, but these are the best ways to proceed in either scenario.
Hope this helps...
I have a guy over working on my '87 GL. We thought that it needed a driver's side belt. He just found that the bolt holding the tensioner on had broken. We wonder if maybe that's why the belt had a problem in the first place (the belt's not broken, but is worn).
He's not a Suburu expert and is reluctant to continue. When I asked him if the end of the bolt could be drilled out he said that he's worried that it might strip the thread or that the bolt end might fall into the block.
It's a big deal that after many months I finally found someone to come up here and work on my car, but I don't want to proceed if it's dangerous to do so. We decided to ask you experts about this. My options are to find a way to proceed or leave the car sitting for an indefinite period of time. I really need the car but my remote location and finances prohibit me from calling a master mechanic in to do the job.
Should we proceed? If so, how can we do that safely?
Any help greatly appreciated.
Mary
Yes, whoopee, it sure is! Thanks, Dave.
Mary
Hi, All,
I was last here in November when my '87 timing belt broke. At that time I got lots of wonderful help from you folks, including a link that showed great photos of an engine like mine getting a belt replaced. I saved the link in a folder on my computer but now find that the link isn't good any longer. I finally have someone coming up to replace the belt tomorrow, but since he's not a Sub. guy I want to be able to provide him with anything helpful so I am eager to find that photo set again.
Any ideas?
Mary
The belts are not extremely difficult to replace. I would first remove the two outside belt covers and inspect them closer. They should be accesible with a small 10mm wrench or a ratchet and shallow 10mm socket. It can sometimes be hard to feel the belt through the inspection holes, as the belt is above the hole, and you have to use a good amount of finger to feel it. Even if the belt is still on, it's still a good idea to remove the cover and see if any of the teeth have stripped off the belt. That happens sometimes.
GD
Well, I'm delighted that no one shrieked when I said I was going to take i on myself. That gives me great hope.
Mary
Ok, thanks again to all of you. After reading more of what you wrote I was able to figure out my problem.
I removed the "oval" on the passenger's side first, and couldn't feel any belt, but since there was so little space for my hand between the cover and the fan I wasn't sure if I didn't just feel around incorrectly. So I put the oval back on then took off the one on the driver's side. This time I definitely felt the belt and it was not at all taut. I pulled on it just a little, thinking that if it was broken it might pull out, but it didn't seem to budge so I figured it was best to leave it alone.
Before posting I decided to do some searching on this site. The first bunch of stuff I read had me horrified - it sounded like a very expensive proposition and definitely for professionals only. Then I read Miles Fox's instructions for replacing the belt and now it actually seems like something reasonable for me to take on myself.
I don't kid myself that it will be easy - just doing what I've done so far made me totally understand why mechanics cuss all the time (like how do you guys with big man hands feel around for the belt behind the fan? and I got out a 10mm but after I found what contortions would be needed to remove those cover bolts I felt sure that if got the thing off I'd have a heck of a time getting it back on, and it didn't seem worth it just to check something), but it seems like the right thing to do to try it myself.
I'm really not sure just how many things I intend to replace, though, and from some things I read it's almost a given that when replacing that belt that you also replace tons of other things. We'll see, I only just now found out what was wrong and I need to think about it.
I really can't tell all of you how much I appreciate your patience with me. It's obvious that you took a great deal of time and care to help me with this.
Thanks again.
Mary
GD, I tried your suggestions. The fuses were fine, and for some weird reason I had apparently connected those two green things the other night (but I didn't mess with other parts), so the noise I mentioned was the fuel pump, so it's fine too.
Now, the whole belt thing is confusing to me. I don't know where the passenger side timing belt cover is, and though I looked all over for something oval I just couldn't figure out where it was. My manual doesn't list either timing or belts. I am reluctant to remove anything like that unless I'm sure it's the right thing, in case whatever it is needs a gap or something to work properly and I put it back in wrong.
I started this quest asking about pictures. I think I need something like that more than ever now, so if anyone does know of a place where there's a diagram with identifying text that shows clearer views that my little manual does I would love to know how to find it. It seems like most of the pictures in my book are schematics identified in drawings that don't match in shape, show such closeups that I can't find the part because there's no context, or the view is not the view I see when I look under the hood. I think I must have a VERY non-mechanical brain, because it's very frustrating and confusing.
Maybe the belt is the answer, so I'd be grateful for any help figuring out where it is.
Oh, forgot to answer one of your questions - it does sound like it wants to start but just doesn't. I left a trickle charger on it yesterday and charged it well just in case my many attempts had drawn it down.
One other thing - I keep isopropol alcohol in the car and put some in the tank in case there was perhaps some moisture, because when it first broke down there were two backfires (but none after that, and with the ether I had been able to start it up many times, but the it only seemed to burn up the ether then die, I floored it to try to rev it but that had no effect whatsoever). I didn't know what the backfires meant, but figured it might be from moisture or something.
Thanks so much again.
Mary
\Thanks!Ok - you say it starts on ether - does it sound like it wants to run and then stops or does it sound like maybe it's only running on two cylinders?
There's a couple options here - it sounds like either it's fuel related, or you may have broken the passenger side timing belt and it's trying to run on two cylinders.
Please try this: Connect the two green "test" connectors behind the drivers side strut tower, and turn the key to the "ON" posistion. Listen for the fuel pump. It will cycle every 2 seconds when it's in test mode. If you don't hear it you may need to take a look under the car and test for power at the fuel pump connector with either a multi-meter or a test light. The pump is on a shelf near the gas tank. There's only two wires in the connector - just put the tester on each one and see if you get 12v with the ignition ON, and the green guys connected.
Also check all the fuses. If the pump doesn't run then it could be either the fuse, the pump relay under the dash, or the pump itself.
If the pump runs normally, there is a black oval shaped plug in the front of the passenger side timing belt cover that you can remove to check the belt tension with your finger. Reach a finger in there and see if the belt is intact or not. If you can't feel the belt or you feel shredded belt with no tension you have found the problem. It is also possible for some of the teeth to strip off the belts and the engine to jump out of time.
I wish I were closer - I would come take a look at it for you
GD
Wow, I'm totally excited after reading this - I actually know where the green things are, where the fuses are (and just bought some last month!) and even where the fuel pump is.
I also have one of those tester things but need to look for it. I'm writing first before I go look just in case you see this and can describe what it sounds like where it's running on two cylinders. There is one other thing - when the key is in the on position I do hear a sound (without the green guys hooked together) that's kind of like a hum, in case that means anything.
Thanks a whole lot for all these suggestions. I'll get right on it.
Mary
When it broke down I was travelling very slowly in 2nd gear, in low 4WD, maybe 7 mph. There was a slower car in front of me so I had to brake slightly. It died when I took my foot off the gas.
I just went down and tried to start it again and it tries but just won't turn over. I did get it started numerous times yesterday by spraying ether in near the carb, but each time no matter what I did to the accellerator it seemed not to have any effect whatsoever, it would run a bit, I presume just long enough to burn up the starting fluid, then would die again.
I am out of fluid and in a remote location, so I won't be using more of that for now.
I finally got a great picture of the parts in question but so far haven't been able to get them in a reply. I'll try once more before submitting this.
Thank you very much for taking the time and guiding me with your questions.
Oh, I found out that I almost certainly have an EA82 engine. It's definitely not a turbo, in case I need to add that.
In case the image does show in this reply, I propped the white unattached connection so it was visible, but it was down under the green connector. The two pieces I have shown off to the right are flexible rubber and were sitting on top of the white connector.
Mary
shoot, I don't know why it didn't appear attached. By the way, I love your name!
Mary
Most likely the plug in question was for something your car didn't come with. Most cars have lots of things like this - cars are generally equipped to *be* installed with things like AC, even if they don't come with it from the factory. So you will see lots of plugs that just go nowhere.
Can you describe exactly what happened when it broke down, and what it does now when you try to start it?
GD
Mary
Red goes to positive. Black goes to negative. I connect the charger's cables to the battery and then plug the charger into the wall socket.
BB
Thank you very much!
Mary
there are two completely different motors available in 1987...the EA81 and EA82....and there are turbo, non-turbo, SPFI, MPFI variants as well. if you tell us what vehicle it is we can tell which motor it has and someone can post a picture.
if you can post a picture we'd be able to help immediately.
Oh boy, I didn't know that and don't know how to tell. This manual I have came with the car, it's just that little blue one. I'll look for numbers on the engine. I am aware that some information is printed on the doors but in my car those plates are all worn down.
I will see what I can find out. Thanks very much for pointing out this specific aspect.
Mary
Hey Mary:
Might be helpful to take a pic & post it here - I'll bet there are a ton of people who can probably spot it in a jiffy
I'm thinking it's probably a little rough to post a pic and then add a bunch of lines & text that might not be too confusing.
Thanks, I can't take a picture. I haven't been here for a very long time and I've forgotten some of the etiquette - is it acceptable to thank each person who replies even though I have the same thing to say to each? (No camera.) I don't like to take up the time and space but wish to thank.
I appreciate your reply.
Mary
Would help to know what fuel system and such you have.
Under the hood of my 87 is a turbo and intercooler among other things.. But that probably isn't very helpful. But here's a pic anyway.
This is an older pic, but it shows the area you are asking about. Is your car auto or 5 speed? 2wd or 4wd?
You will get the best answers if you actually give info
Sorry! It's a 5-speed 4WD, and some paperwork from a shop says fuel-injected. That's all I know.
Great picture, and thanks for the speedy reply. I've spent the last hour trying to install a camera with no luck, writing the manufacturer next.
I forgot to say that I was hoping to find a picture that had text and arrows also, because I don't know the names of the parts.
Next time I go down to where my car is parked I'll take notes so that I won't come here with half-baked questions. Thanks again.
Mary
I hope it's ok to post this since it's not Sub-specific (and so incredibly simple a question. I feel kind of dumb.).
I want to charge my battery with a trickle charger I was given. I did not recieve a box or manual.
I really only need one very simple question answered - it's red on postive, right? If so, please let me know and you have my thanks. Everything below would be superflluous but I'm typing it all out just in case it's not as simple as I think it is or should be.
I've only charged batteries with jumper cables and know that it really doesn't matter with those as long as both cars are attached similarly to the jumper cables, but since this is new to me I read the back of the charger.
The instructions read:
1.) connect or disconnect battery clips only when supply cord is disconnected or arcing or burning may result.
2.) for a battery installed in a vehicle, first connect charger output lead to ungrounded battery post-not connected to automobile chassis - in accordance with polarity identification (nowhere on the clips or the charger were + or - signs!) and then opposite polarity lead to chassis away from battery: do not connect to carburetor or fuel lines. Disconnect chassis lead first.
Etc. The way it was written seemed very complicated to me and I had no idea what it even meant. I looked on the manufacturer's site but no instructions were available.
I decided to just do it, so I attached the the black alligator clip to the the negative post and plugged in the charger. Then I touched the red clip to the positive post to make sure there was a spark and there was, so I attached it. Nothing sputtered or blew up so I thought I had done it properly.
Then I became a bit uncertain because of the lights on the charger - the red light indicating "power on" was lit and stable, but the yellow indicating "charging" and the green indicating "charged" both kept flashing. Is that how it's supposed to be? I disconnected it all, thinking I should make absolutely sure before I continue.
Red on positve or not? And who the heck WRITES those product instructions???
Much thanks for help.
Mary
Today my car broke down a very short time after I left home, and it was a real surprise. I'm interested in finding a diagram that clearly shows what is what under there - it appears that I may have a part missing because there's a rubber housing thing but nothing being housed.
It located right by those two green things and those two amber-colored things that you hook together for something diagnostic. There is a single round (larger) white connector right there next to those and the rubber thing. If something IS missing it's round and I think the size of the fuel filter, if I know what that is. The pictures that came with my Sub in the manual don't make any sense to me at all, when there is text next to a picture the picture angle generally seems to be such that I can't find the part they mean - when I look under my hood to compare I see nothing similar.
Thanks for any help, I hope to be able to rule out a missing part as the problem (especially as the car started up and ran for a brief time!) and look into other causes.
Mary
Yes, sorry, it was a mouthful. I think that it might always be for a Virgo with ADD. I spend a great deal of my life apologizing for this. It's why I live in the woods.
It's a GL, a 4x4 wagon, '87.
Thank you so much for all your helpful input. I did neglect one potentially important aspect - the radiator water, when I checked it today, was full. We didn't want to pull that cap off when hot. But, I forgot to put the cap back on that water resevore... how the heck to you spell that?? thing right next to the battery recently when filling it, and have left a plastic bag in to plug the hole. The bag was totally intact and that thing was not full, the water level is way down. Unless that's for winshield fluid it could matter.
Darnit, as usual I am having problems here. This time I am unable to bring up your letter to refer to it. I see why you commented as you did, aside from the obvious. Now I can't remember all the stuff, so I will submit this in case it has something important in it then will go back to your letter. I do remember you said something about pulling codes, and I know my guy has access to total repair manuals online, but in case that's extraordinarily unlikely to find do you have the info or a link to it on this site?
I'm going to send him your post and tell him there might be more forthcoming. You were really great, thanks for taking the time!
Mary
I can put in a digital phote here if anyone needs me to take a shot of something I described or perhaps suggests a problem in my car. I'm fairly desperate and SOL if I can't figure this out and FAST.
Mary
I apologize to you all for putting this in the wrong forum first.
You guys were so helpful before that I am here again to get your impressions.
My distributor was replaced a few days ago. Since then I have noticed some things that are different and one of them is serious enough that I am afraid to drive it like this.
1) the "check engine" light comes on now and I do not notice that it happens with any predictability. It flashes on and off a lot on the dirt road here that is the first mile of my journey to anywhere. The way this happens I thought it must be some loose wire. It does the same on the paved road beyond that, just not as often. I told the mechanic about that one right away and he said that 9 times out of 10 that's smog stuff, and he said it like it isn't important. Ok, if that was the only thing, or maybe the only thing aside from:
2) when I first pressed the button on the dash to put my side mirrors back to my height there was a sound so distinctly like a duck quacking that I stopped the car and turned down the radio so I could hear it more clearly. I mean, I could have sworn it was a duck but I didn't know where one could be, and after all it had come from that button being pushed.
3) I noticed after the repair that it had a new putt putt sound, like a VW, coming from the engine area. I figured that since Subs. are so connected to VW's that that wasn't a problem necessarily, but on any other car I would have reported it as something that sounded like a hole in the exhaust symptom somewhere. Since I used to own and operate a taxi and my living depended on that being right I got pretty good at reporting things so that our maintenance mechanic would get a clue to what was wrong and fix it pronto. It was identical to sounds I had heard in other vehicle, sounds that were helpful to my mechanics then that turned out to be exhaust things (these were about the American cabs I had). It really does sound like that in my Suburu.
4) on the way to the grocery store in town last night I saw that the temp. gauge wasn't working at all, so I called the mechanic, my neighbor, and said I was coming back and that I needed this looked into and fixed before I could go anywhere, it was that serious to me.
My deceased partner was a master mechanic, and he told me that he got really fed up with fixing the cars of acquaintences and friends because regardless of the cause they would pester him with everything that went awry after that, even things that he knew were clearly not related. It put him in a very bad position, so he would help people on the side of the road but beyond that he did everything possible to stick to only working in his shop.
So I need to say here that I definitely do NOT suspect that these things were created by the mechanic, at least not out of any possible error he made, thoughI really hope that some inadvertent bump might have been responsible. I totally trust him and at the same time I need this rectified, for that 3-hour round trip to town to get food and also for a funeral that will require about a 300-mile round trip.
When the mechanic looked at things last night I very much assumed that he would find some dumb little thing, like wires loose or not connected (the check engine light had come on only once before, about 6 weeks ago coming out of my smog guy's repair lot, and he apologized as he reconnected two green wires with translucent green ends and said he'd neglected to reconnect the timing. I am 99% sure that that was what he did, but he did reconnect something and say that, and after that there was no light on.).
Then I hoped it was a fuse thing, since the cover to that compartment had been removed during the repair or diagnostic process, which I knew because it hadn't been replaced. He looked at those and said that nothing was wrong.
I looked at stuff today so I could report more accurately, and in the fuse compartment all had regular-looking clear middles except 3, which were yellow. These were translucent.
There were two that were recessed, one of which was yellow, and those were just to the left of a square thing, also yellow, but opaque and like the yellow of the happy face icon below. It had a place on top where it kind of looked like the female end of a phone cord, empty. It was square and larger than the regular fuses.
Anyway, he'd said that those were all good, so I expect that these empty and yellow fuses are like they should be????
I then asked him if it could be the thermostat, and he showed me a flap/lever-type thing, just to the left of a housing, where he said that the thermostat is. I guess that the impression I got was that it was a pretty big thing to check that, with much to remove. I'm willing if that's needed, but of course would like to check every simple thing first.
The trip to get food is also very important because there have been a weird number of deaths lately, and one is my father's sister-in-law, and I have to get down for that funeral and to also take food. I also have to get food for a local pastor here, who has been so inundated with other people's needs due to a fatal crash here of an 18-year-old that he's not getting what he and his family need, due to his own lack of resources and death of his cousin, another minister, in an accident on that same night.
Worst of all, I had already told people I would bring things, and I sure don't want to not do that. I'm committed.
I would greatly appreciated any help with this.
Mary
Well, I am stumped here. After losing my whole message one due to some key I hit I copied it in sections then pasted it when it happened two other times. Then I put it in the wrong forum, I put it in new generation before I noticed it, after I submitted it. Now I can't find a way to copy and paste the thing here in the correct forum. It's definitely long enough that it would be a bear to retype, but I need it in here. If anyone knows how to place that post here instead I would love to hear about it. Meanwhile, while I begin typing it again I hope that anyone who is interested in this thread will check the posting with the same title in the new generation section.
Mary
oops, wrong forum, I will go to the right one and submit it there. Sorry
Posted
Thanks, everybody, all great advice. My car repair friend did manage to fine a 22mm socket, so that's great. He's resuming work on it in a few days.
