Everything posted by Subaru Newbie
Me again..
Well ************ it, Somehow the car locked up and now all the transmission fluid is on the ground and where the bolt that holds it all in, theres a crack across the transmission. Its just one problem after Another.
Me again..
Ok so its my right front cv, Does anyone have any "How to" video's on how to uninstall and reinstall a new one?
Me again..
I moved here from new jersey, so im not sure of distances around here, but i live in Centralia
Me again..
Ok the clunking stops when shifting a gear, does that cancel out it being a transmission problem?
Me again..
its front wheel drive, but has 4x4, if its a cv or w/e can i dmg it more by driving it?
Me again..
i cant hear it at the moment, but i had the hood up and pulled the accelerater alot and it sounds good, i only hear it when im in gear in motion
Me again..
I did some testing on the way home, going about 15mph i put it in 3rd, it got higher and hollower, 4th even hollower, and 5th it sounded like a baseball card on a bike wheel
Me again..
It litterally sounds like a fan hitting something, but its coming from idk right on the other side of the firewall
Me again..
Wouldent i have problems with the clutch pedal if it was the clutch? or?
Me again..
uhh.. 35yrs old? maybe? idk
Me again..
by the way, whats a eu and why is grease leaving it lol Sigh nvm, im a little slow, i see wut u did there
Me again..
It's a 1985 Subaru Gl wagon, Recent work, i got instructions from a post and re-timed the belts, i doubt its the problem its been running fine for weeks, And the car is at normal temperature, oh the engine is a 1.8l i believe, And with increase of gas is dulls, but then gets louder when i back off the gas some, But stops all-together when the pedal is untouched, downshifting, or just idling.
Me again..
You guys were great last time i had a problem, hopefully you can help me again, I'm getting a knocking, not sure where its from, But i can have it at an idol and rev it, and it sounds great, but when its in a gear, and i give it light gas, i get a pretty loud knocking.. Remember i don't know much so please explain in child terms lol
Please Help.
Thank you everyone, she's up and running again, First time timing an engine and belts, I gave it about 4 goes, and she would not start or even crank over, then i noticed that i never turned the right cam 180 degrees before timing the left belt, i did that and she started right up, Thank you everyone, WOOT, time to go cruisin again
Please Help.
Is there a way to "check" if the timing belts are off?
Please Help.
Hi, i have a 1985 subaru gl wagon, I was doing a little mudding a few days ago, then yestarday i went over a speed bump, The engine got real deep, rattled alot, and died, I dont know much of anything about cars, its my first subaru, I looked under the hood, And found the left tensioner on the ground, I tried to put it back on, and it looks right, but the car wont start, and by chance it starts, it runs Really bad and dies unless the petal is to the floor, and then it only goes to 3k rpms, i have a vacuum gauge, and the pressure is reading zero. Any idea's? =\ Sorry for duplicate post, my last title might not get the point across
New here, Hello
I dont see any damadge to the oil pan, But upon closer inspection, the right head where the belt connects to, behind that is a shaft going into the engine, and on the shaft is a black seal just hanging there, im not sure if it was there before, but is it possible that came from inside the engine?
New here, Hello
