steve56
2
Everything posted by steve56
While RandR timing belts on Subaru engines I'm always struggling to get the toothed idler pulley back in. There never seems to be quite enough slack in the Tbelt . I can fight it for a hour, walk away, come back and somtimes it goes right on or not. Ive done enough belts that I know this has got to be a common problem. Have no idea what the solution is.
On 2005 OBW, swapped in a Jdm ej2.0 engne and used the original 2005 OBW ej25 intake. Get check engine light with p0340 dtc for (camshaft positionin sensor a circuit bank one).When I erase the code with car running it will immediatel shut off, then stumble for a minute on restart,then run apparently smoothly with the same p0340 check engine light comming back on. The Actron meters Freq Reported Fixes are: 1) Replace the crankshaft positioning sensor reluctor and 2) Replace timing belt tensioner. I did have to splice in the camshaft positioning sensor connector from the 2005 OBW because the JDMs cps connector was crushed. It was a two wire connector so I dont think it matters wich wire on the connector goes to which wire on the wiring harness. Looking for trouble shooting steps to get the p0340 dtc resolved.
Bring your car to shop that has an electronic HC gas tester. Car needs to be hot with bubbles in the overflow tank. Most importantly, you need to watch technition do the HC gas test. If the HC testers numbers increase you defindately have HCs in your cooling system.
- 35 replies
- Overheating
- coolant bubbling
(and 2 more)
Tagged with:
I found that I have tool you mentioned in Plan - C. It has the the thick bolts for the crank pulley with large holes. I need the thinner set of bolts for crank pulley with small holes. Don't seem to have the right size bolts to turn into the tool. Anybody know what size and thread pitch they are. I will call Company 23 in the morning if I dont come up with the correct ones tonight.
Just received the Beck/Arnley boot clamp kit. The instructions are:always thorougly clean out the CV joint before repacking with grease. Clean off excess gresse with rag then remove the remainder with warm soapy water. Dry thoroughly. Do not clean with any parts cleaner or petroleum based product. These will leave a deposit incompatible with the new supplied litium based grease.
Before reinstalling the engine, is it a good idea tube the two flywheel aligment dowles and the center "nub" on flywheel, to make the engine and transmission slide together easier. Ive heard that it helps the engine and trans slide back together, but never seen it listed in the FSM. This is going to be a on person install, so I'm trying to make it as easy as possible.
Im a little foggy on a few details, but the 07 Impreza has variable valve timing so I need to use those heads so the ecm will be compatable . According to my supplier in the Seattle area I can use a jdm 2.0 or 2.5 shortblock with the 07 heads. My supplier doesnt have any ej20 or ej25s newer than 2005 so none of them have the variable valve timing heads. I already have a jdm ej20 from them that I'm getting ready to install in a different 2005 OBW. That one is a direct swap with just using the 2005 OBWs intake.
Here is a picture of the different tooth profiles on T304(AA230) and T307(AA21B) timing belts. I'm rebuilding both a Legacy and Impreza. Legacy has two metal cam gears.Impreza has one metal and one plastic cam gear. I think they both engines use the same crank sprocket and toothed timing belt idler.I'm assuming the different Tbelt tooth profiles are due to the cam pulleys. If anyone knows please ad to post.
My new Snapon Tech Angle torque wrench only goes down to 12.5 ft/lbs. The head gasket torque instructions have a 11 ft/lbs torquing step. Is it okay to torque to 12.5ft/ lbs. when instructions call for 11ft/lbs. Its the final step of instructions before the final 80 to 90 degree then another 80 to 90 degree tightening step.
