Everything posted by ystrdyisgone
87 GL Wagon (picture heavy)
Thanks for the link sosubme. I went and got all of the materials for the slab planing. Got a piece of 14x14 granite countertop for free. Couple packs of sandpaper and two bottles of pb blaster for just over ten bucks. Subruise, I would like to put in the spfi pistons, but I don't trust myself splitting open the case. I'm pretty comfortable right now just doing all the outer gaskets. I'd hate to F something up at this point. Just placed an order on RockAuto for all of my gaskets, new pilot bearing, water pump, etc.. Should be here in 5 days:headbang:
My current ea82 had a hitachi carb originally. So would the pistons be SPFI? I was assuming no.. And yeah its a 5sp d/r. Tried out the Lo range in the mountains last week, pretty frackin awesome, now I just need bigger tires. I'm really digging the color too. Thinking about bedlining everything below the trim panels. I will search for GD's thread. Any kind souls care to link it for me?
Weber carb for my 87 gl?
I purchased this car from moosen a couple weeks ago. Wish I had read this thread first.. She's struggling. I don't think he ever hooked up the egr. This thing burns through oil like no other. Prob a quart a week, maybe more. Significant leaking from the driver head gasket, and valve cover. The car doesn't like to stay running after a cold start. May just be a matter of idle speed.. Gas mpg is good, ~27 around town. Any savings in gas I spend on oil though.. Got an ea81 I'm dropping in as soon as the gaskets get here.
Thought I would move from the meet and greet and start my build thread. So here goes. A little repeat info.. got this 87 GL a few weeks ago, paid waay too much, but I plan on having her for a while. I picked up an ea81 off of CL for $150. To do list: Reseal ea81 Swap ea81 in 2" suspension lift from BOSS 6-lug hub and drum redrill Replace front seats Took the ea81 apart tonight, got her all shiny Before After
Got myself a Subaru
So I took the heads off tonight, there was some oil residue on the block around the head gaskets. So I went for it. Gaskets are fine, but there was obviously some sort of leakage going on. The oil pump... is so damn stuck on there... I hit it with some PB blaster, hopefully that will do the trick. If the engine does indeed have only 80000 miles, should I still be getting a new water pump, and maybe a new oil pump? The rear main seal: The engine currently has bellhousing, flywheel and clutch still attached. I'm guessing I would have to remove all of these to get at the rear main? edit-ignore last question.. did some reading
Got myself a Subaru
Well how about that.. haha this whole swap just got 5 times easier. Thanks guys. About the heads.. like I said earlier, I don't have access to a good shop, cherry picker, etc.. So my thought was just reseal as much as possible while the engine is out, so I won't have to pull it back out down the road when/if something goes. Logically it makes sense, but if you guys who know your ea81s say I don't have to, I am willing to listen to reason/experience.
Got myself a Subaru
Alright, starting to take it apart tonight. Is it worth getting the heads planed/shaved while I have them off? Also, as far as the carb goes, there's a (32/36 dgev?) weber on my current ea82. I was planning on just swapping that over. Will that be a direct fit onto the ea81 intake mani?
Got myself a Subaru
Thanks subruise, I wasn't having much luck with the search on usmb. The google searching is working much better. I brought home this little beauty today. An EA81 I picked up for $150. It allegedly has 80000 miles, and was pulled out of a wrecked car a few years back. Look pretty clean to me. My original plan was to do a complete rebuild. But I am leery about splitting the case open. Is it worth checking the main bearings and cam with such low miles? Or do you guys think I will be fine just resealing all of the outer gaskets?
Got myself a Subaru
Thanks for the input. For the ea81 swap is there anything as far as the wiring goes that might give me some troubles? Also will I have to modify anything to make it fit my current 5spd D/R tranny? This info may be on the forum, and I plan on doing some more digging, but figured it wouldn't hurt to ask.
Got myself a Subaru
Hello everyone, I purchased my first subaru about a week ago.:cool: I got it from some kid who knew little to nothing about it. It's in decent shape, other than drinking about a quart of oil every 4 or 5 days. Rear diff was bone dry when I got it home, who knows how long it was driven that way :-\. There's also a mystery clunk/knocking in front drivetrain somewhere, sounds like c/v's but they look fine. So I've got a little work ahead of me. Looking closer at the engine, I noticed there is oil leaking from the oil pan gasket, drivers side head gasket and valve cover, and who knows where else.. So my question is, with no access to a real garage of any sort, is it worth it to try to reseal the current engine? Or I've found an early 80s pushrod style ea(81?) on CL for 200. I'm thinking about picking that up, rebuilding/resealing that one then renting an engine hoist when it's all ready to go. Any opinions here would be greatly appreciated. Plans for the car: I'd like to keep it as my daily driver(for now). So I'm going to start small, probably going to get the 2" lift from BOSS, 6-lug redrill swap, some bigger rims and tires. I would like to put an EJ22 into it at some point, just don't know if it is something that is within my abilities to do. I have read a lot about the swaps. Mechanically, I think I've got it, but electrical kinda scares me. Thanks guys Here she is cooling off at the top of our first trip into the woods.
