Crazy_man_subie
  1. tire mis match will make it stick. i had my wagon stick on me but i had a bigger tire on the rear.
  2. ok we just had a big flood where i live i found an 88 XT MPFI 2WD 5Speed for $100. after $100 in parts (motor flush, oil, filters, cap, rotor, plugs, Heat, fuel ) car runs good (idles at 2k but it runs). well now that it runs i want to have some fun with it. i have as a donor car a 86 gl Wagon with a 4WD DR 5Speed. what i need to know is 1. Will it Fit? 2. Do i need a drive line from an XT or will a sedan work 3. is the clutch the same?
  3. had this problem with my 86/87/88 (all one car. 86 body, 87 spfi motor, 88 sedan inter.) the disty has a ir pick up if you get ANY water in ther if fogs the ir lens and you get a Missfire. clean out Under the metel plate under the roter with Starting fluid and caned air (computer air duster) and that should work.
  4. the best thing is to get a 280Z alt and put that in all it taks is a little filling on the alt bracket and you got a 100 Amp alt (works with the L brace on the slider side of the alt most likely not with any a/c)
  5. pics pix we want pics
  6. i used standard 3/8 on my ea82
