IdiotSavant
Everything posted by IdiotSavant
Thanks for the input Rooster2. I made a call to my local dealership this morning and ended up ordering the necessary parts directly from them. I was initially just looking to find out the correct part numbers, but was quoted $190 for everything I need, including valve assembly, filler pipe, gasket, ring and mounting screws. If there are fitment issues, I can just walk right over and exchange the parts instead of paying shipping. I was expecting minimum $400 ordering from the dealership, so it not too bad considering some US online vendors wanted $60-$80 just for shipping. To help other members with the repair, I'll update this with the correct part numbers on a 99 Legacy GT sedan once I can confirm that the parts ordered fit properly. Thanks again.
- 6 replies
- fuel filler neck
- 99 Legacy GT
(and 2 more)
Tagged with:
The car is my daily driver so I can't really wait too long. I've never had good experiences using car-part.com. Every time I call a salvage yard to inquire about the part I want, the people answering always seem clueless and/or half drunk. I'm going to stick to an online vendor. It's probably gonna cost around $200 for all new parts so it's not too bad.
- 6 replies
- fuel filler neck
- 99 Legacy GT
(and 2 more)
Tagged with:
Hey guys, I'm trying to gather the parts required to do a fuel filler pipe replacement on my 99 Legacy GT sedan. After scouring the internet and this forum for hours trying to find a clear answer, there seems to be a lot of confusion between the parts required for the 97,98 and 99 models, wagons, sedans and SUS. I want to be sure because I'm in Canada and ordering from the US. I wouldn't want to be stuck paying ridiculously high shipping fees to return parts due to fitment issues. Pretty sure I'm going to order from subarugeniuneparts, but if there's another one-stop-shop where I can order all the required parts, please share. Looking at their parts diagram(attached), I think I'm going to need: 1 x #8, Filler Pipe 2 x #9 Ring 1 x #10 Gasket 1 x #15 Filler Valve #2 1 x #17 Rollover Valve In addition to this, I read that I'm going to need: 3 x mounting screws Part #047105166 1 x Valve Assembly Part #42084FA100 2 x Nuts Part # 023705000 Does this seems correct? Also if anyone has any good resources to find Subaru part numbers, please share. Subarugenuineparts website is very confusing when it comes to searching by vehicle or part number. Your help is much appreciated. Cheers!
- 6 replies
- fuel filler neck
- 99 Legacy GT
(and 2 more)
Tagged with:
The reason I've been hesitant to switch to synthetic is because the engine has only ever known conventional oil. I remember reading that on these phase 1 EJ25D engines, it's not a good idea to suddenly switch to synthetic at such a high mileage. The head gaskets have never been done. Is that true or can I safely switch to synthetic without worry?
- 25 replies
- cold start
- rough start
(and 1 more)
Tagged with:
Thanks for all your insight, gentlemen. My car is already equipped with a block heater. I think it was included in the cold weather package. I have never used it before. Then again, I've never had problems starting the car in cold weather. Also, I don't have a driveway, so I'd have to run an extension cord across a busy sidewalk to plug it in. I had no problems starting the car this morning at about -18C. However, I did notice the oil level was rather low, so maybe a lack of oil prevented the engine from cranking properly. I still picked up a new battery today since it's due to be replaced anyway. I'm also going to try and find an oil pan heater to be better prepared for next deep freeze we get. I'm going to be testing the starter and alternator tomorrow to make sure they're still functioning properly. With busy holiday plans ahead, I sure don't want to be left stranded anywhere. Thanks again. You guys are a wealth of information. Cheers!
- 25 replies
- cold start
- rough start
(and 1 more)
Tagged with:
Hello gentlemen, The last few days have been brutal, temperature wise, hitting -30C to -40C. My 99 Legacy GT has been having problems starting. I first noticed the problem when using my remote starter. It didn't start up until about 3-4 minutes after I pressed the button. My Compustar system tries to start the car a few times before giving up. Usually, it starts up right away. I drove around for a while and the car seemed fine. The next day, I went to start the car manually and the engine cranked halfway, then stopped. There was no clicking from the starter and all the electrical components(radio, lights, etc) were still working fine. I eventually got it started after trying for about 5 minutes, but it was an extremely rough start. Once the engine warmed up, it sounded smoother. My first assumption is the battery, as it's about 4 years old. It's probably not sending enough current to start the engine. But wouldn't all the electrical components die after attempting to start the car? It could possibly be the starter as it's never been replaced since the car was manufactured. Same applies to the alternator. Last assumption is that it's just so cold that the oil is too thick to properly lubricate the engine. (using 5w30 mineral). I'm going to be buying a new battery this week, but is there anything else I should be looking at? After researching some related topics here, I read that fuel delivery could be a problem. The fuel pump has never been replaced, but I always replace the filters regularly. Spark plugs and wires were changed about 70k km's ago with OEM parts from the dealership. As always, your help and insight is well appreciated. Cheers
- 25 replies
- cold start
- rough start
(and 1 more)
Tagged with:
For the archives, I will post the diagnosis here. Turns out, part of the brake line came loose from the strut and was coming in contact with the backing plate(i believe). They were attached with a tie-wrap that gave way, allowing the brake line to freely move around near the brakes. Luckily, no damage was done to the brake line or any other part. Everything else on the car is in great shape, i.e. wheel bearing, tie rods, cv joint, brakes, etc. $25 and 30 minutes later, I was out of there. Thanks again for your insight, gentlemen.
Halfway to the shop this morning and the sound stopped. It was present when I left the house and probably woke up the neigborhood, and for no apparent reason while driving about 70km/h, it suddenly stopped. I'm still waiting for the shop to open so we can take a look with the car on the lift. Can this still suggest a bearing or more likely something lodged in the braking system; which seems quite common as well.
You may be correct about the wheel bearing. The noise is constant regardless of whether the brake is depressed. But, it does seem to quiet down a little when turning. I was under the impression wheel bearing failure produced more of a "whirring" sound rather than a loud metal screeching that makes my car sound a train pulling up to the station. I intend on bringing it to a shop in the morning to get a proper diagnosis. My Subaru shop is about 40km away and I'm afraid to drive it that far so instead I'm taking it to a different shop that's much closer to home, but they tend to employ young mechanics straight out of school. Should I be worried about having inexperienced mechanics work on such a problem? If it is indeed a bearing, am I looking at replacing the hub as well?
Hi guys, As I drove off in my car this afternoon I noticed a really loud metal on metal screeching sound coming from the front end of my 99 Legacy GT. The sound seems to move rhythmically with the speed of the car and definitely turned some heads as I drove. It was fine this morning and the car was parked indoors all day. I decided to record the sound as I drove and post it here to get some feedback before I bring it to the shop tomorrow. Any ideas on what this could be? Wheel bearing? Transmission? Would it be safe to drive it another 40km to the shop tomorrow or best to have it towed? Your insight, as always, is well appreciated. Cheers! http://www.wikiupload.com/FU13B51JA4V8SBG Voice0004.mp3
I can't seem to find a decent new spring/strut/mount setup that will cost less than $1000 installed. Now looking into used suspensions from a '02-'07 WRX. From reading up online, it appears that these would be a direct bolt-on fit. BTW, I own a BD 99 Legacy GT. Can anyone please confirm that the WRX setup would fit without any additional parts/modifications? The asking price for these suspensions around my area is between $100 - $300 and I'm guessing it shouldn't be more than 2-3 hours for installation at a shop. I think this is my best option for the time being. Thoughts?
The oil pan was rusted and causing a leak. Oil was seeping through there and also from the oil pressure switch. Upon closer inspection the spring seems to be from the rear passenger side as it's sitting lower than the rest of the car. Still doesn't explain the clunking I was feeling on my left foot while driving that day. I'm going to replace all the struts, springs and mounts this week. It's been an expensive year for the subaru so far. Timing belt and all related parts, CV axles, oil pan, brakes and now suspension. Now if only my head gaskets blow, I'm all set!
The pieces seem the same thickness as my springs but I checked both front springs and they seem ok. Maybe its from the rear. I was also able to drive home for about 2 minutes without any noticeable effects. I'm guessing its unsafe to keep driving like this. Gonna have to get it back to the shop real soon. Thanks guys. Here's another pic for perspective on size. http://img193.imageshack.us/img193/6993/imag0368hh.jpg I find it odd that the mechanic didn't notice this with the car on the lift and while replacing the axle. I had even asked that he inspect the front suspension for worn bushings, etc.
Hey guys, Just got my car serviced today. Oil pan and gasket replaced Driver side CV axle replaced Transmission fluid and filter On the drive home, I was feeling an occasional clunk under my left foot when going over bumps. Then while making a left turn, I hear the sound of steel against the concrete and it seemed to be from something that fell off my car. At first I thought it was a tool forgotten in my engine bay. But when I got out to inspect it, I found these 2 pieces of solid steel. Is this part of my car or am I an idiot who just rolled over this stuff? I appreciate your insight. Cheers! Link to pic http://img502.imageshack.us/img502/4852/imag0366o.jpg
Thanks for all the quick replies. They are not going to be removing the engine, but I assume that it wouldn't add too much to the cost of labor to remove it(4 hours total I'm guessing ). At the same time, it would make the timing belt and valve cover work much easier with the engine out. If I decide to pull the engine, I will definitely have them do the baffle plate. The P/S and brake fluids are also due, so I added those to my list. Thanks again.
Hey guys, The time has come to do the timing belt on my 99 legacy GT. I'm also taking this opportunity to do a bunch of other things such as: - Tensioner - Idler pulleys - Water Pump and thermostat - Cam and crank seals - Radiator hoses - Valve cover gaskets(leaking) - Replace oil pan(leaking) - Transmission and differential fluids - Fuel Filter - PCV Vale - Oil pump reseal My question is, are there are things I should be looking at, considering the timing covers will be off? The engine has 150 000 kilometers and has had nothing done besides routine maintenance. Another question, is it worth it to consider doing my head gaskets preemptively? I'm not experiencing any failing head gasket symptoms, but considering the age of the engine and the fact that a lot of labor is going into all the other work I'm having done, do you think I should go for it? Thanks for your input. It's always much appreciated.
Thanks again for the suggestions gentlemen. I have a few days off this week so I will get under there and see what I'm working with. I took a clearer picture to give you guys a better idea of what might have happened. It looks like a clean break and it doesn't seem like there's much pipe to work with. If you have any other suggestions before I attempt this task I'm all ears. Thanks again.
Hey guys, I was hoping to get your feedback and insight on a recent problem with my 99 Legacy GT. Yesterday, about 15 seconds from my house(thankfully), I heard what sounded like metal dragging under my car. The engine also sounded horrible. When I parked the car I noticed that part of the exhaust system fell off, near the catalytic converter. I attached a photo and am hoping for feedback and suggestions on how I should go about fixing it. As always, I really appreciate your help. Thanks guys.
I looked into JB Weld and it seems like a decent option considering the hole is not that big. It's more like a slit right at the seam on the pipe, rather than an actual hole. The only thing that concerns me is that it only resists temps up to 500F. But since I'm looking for a cheap fix, it sounds like a viable option. And it looks like something I can easily do myself. I will consider that if no other cheap options are available. Thanks for the quick reply porcupine73!
Hey guys, I've come once again to pick your brains about an exhaust leak I've been experiences for a few months. The leak is coming from the exhaust pipe, between the resonator and the muffler. There is a weld there that seems to be giving way and as a result the car sounds horrible. Even people that know nothing about cars ask what the hell is wrong with it when I start the car. The check engine light is also on, probably due to the cat not functioning efficiently. The local, corner mechanic, diagnosed the problem as being semi-serious because if the pipe breaks while I'm driving, it could puncture the floor and cause serious damage. I was quoted up to $1000 in parts and labour. He told me that I'd have to buy the entire section of pipe which includes the cat and resonator. Apparently, this part comes already all welded together from the factory. My question is, is it possible to simply have the pipe re-welded where the leak is located? I want to fix this as cheaply as possible because it is an old car and don't plan on driving it for too much longer. As always, your insight is much appreciated. Thank you gentlemen. Cheers!
Thanks EVOthis. I'm guessing that when they removed the heat shield last time, another one might have loosened up in the process because the rattling occurs at different RPM than before. Considering that apart from replacing fluids and bulbs I'm not mechanically inclined, I'll just have them remove the heat shield. I had suggested they clamp or screw it down but the advisor just told me they don't do that and they'd simply remove it. Since their first fix never really eliminated the noise, I hope they don't charge me this time. Haha!
Hello again For quite a while now, with my 99 Legacy GT, I've been tolerating a hissing sound coming from the vents in the cabin. Even after the engine is shut off, the sound sometimes lingers for a few seconds. Also, last summer I noticed my A/C is practically non-existent. Not sure if this is somehow related to the hissing. Maybe a leak somewhere that is preventing the conditioned air from reaching the cabin as well as the hissing sound? For the A/C can it be as simple as replacing/filling the refrigerant or is it possible I'm looking at a more serious problem (i.e. compressor, etc)? I have an appointment at Subaru tomorrow so I will definitely get this all checked out, but I like being somewhat informed before talking to the service advisor. Again, I really appreciate all your help.
Hi guys, I'm hoping to get some information on a minor annoyance with my 99 Legacy GT. About 2 months ago I had the heat shield removed due to a rattling/grinding sound that would occur at certain RPMs. The car was silent for about a week or two afterwards, but now there is a similar rattling/grinding noise that is even louder and more apparent than before. It's sometimes audible at idle but mostly at about 2300-2500 RPM. Can this be related to the heat shield removal? I have an appointment tomorrow to get this checked out but in the meantime, any thoughts? I appreciate your insight and expertise.
I really appreciate all the suggestions and feedback. And I'm relieved that the problem is nothing serious. Although I still don't quite understand why the heat shield only rattles at that particular RPM. I'm bringing my car in for brake maintenance next week so I will have the mechanic secure the heat shield. I park my car on grass all the time when I go to my cottage so I don't want to assume risk by removing the heat shield. Thanks again, you guys are great!
