djbob
  1. If you could scan it in, that would be awesome!!! I assume both are identical, can you lay a ruler besides it/them when you scan them, so i can scale if necessary at my end? I will private msg you my email. Thankyou very much for the assistance.
  2. thanks! that will help with the port diameters, i didnt think of that.... as for the spacing, i was a bit ambiguous with my english there, i meant the center spacing between two individual ports on one head - or is it just one gasket per head? Sorry for the painfull questions - I am gathering information for a possible mod, and i dont have access to a mpfi head to measure. Cheers
  3. I was wondering if anyone has the dimensions for the diameters and spacings of the ea82 mpfi (ie 2 inlet ports/head) inlet ports? The spacings are the most important, but the diameters would be helpfull too. Cheers
  4. I recently looked into doing it, and i spoke to my local Autocraft. These guys seem to be the subaru gurus in my area, and they have tried a few dual carb setups, but due to the tiny intakes on the ea82 heads, they managed to get - technically speaking - bugger all power, for a hell of a lot of money spent on parts and tuning. I definitly would look into sp/mpfi.
  5. cheers matt, i dont suppose ur subi has metal side-skirts? i might have seen it around already, look out for a white subaru dl wagon, with a bloody loud exhaust next time you are in hobart
  6. Cheers guys, hadn't thought about efi, should prob use the ea82 turbo wiring loom then, means it can account for boost... I will be sure to post update pics as it progresses over the next couple of months, should be a "bit" of a sleeper as it will be pushing about 110kW at the wheels once the heads have new metal spacer gaskets....
  7. Bit of a crazy project that i want to complete in the next couple of months, and i am wondering if anyone is as nuts as me..... I own an EA82 subaru, and i am intending to supercharge it with an sc12 supercharger from a toyota 4a-gze engine. the s.c. will sit atop the engine, on top of a custom manifold, with a new carby installed behind the s.c. in the spare tire well area... because of the layout, and my dis-like for bonnet scoops, i will need to use a side-draft carby in suck-through configeration. Is anyone willing to own up to wanting to do this as well... - or does anyone have any information, or ideas (other than an ej20t...) that i could use? Any help at all would be appreciated. Cheers
