bosslady
  1. Fairtax4me, thanks for the post. Photos and any hints on adjustments would be very helpful. I plan on installing the motor and regulator kit.
  2. Made my own window washing fluid, which works just fine for winter. isopropyl alcohol, liquid castille soap and water. Much more friendly to environment.
  3. Cut the damned frayed cable for the automatic seatbelt on 1993 Legacy...shoulder seat belt stuck in the track, with the belt perfectly positioned to choke me...it is now a perfectly good manual seatbelt! Horrible design.
  4. Newbie here, thanks for reading. Driver's power window not raising or lowering properly. Motor seems to be working, so I figured the regulator was faulty. Removed the door panel and observed that one of the scissor arms --sturdy sheet metal--had sheared off near the center of the scissor mechanism. Obviously it needs to be replaced, but I wonder what could have caused this ? I have noticed that upon releasing the contol buttons on driver's and passenger sides that the motor seems to still be going---this is only when the windows are being closed. Looks like a few bolts need to come off to remove the old part...any tips or tricks to this procedure? Thank you , Legacy Wagon 241K miles
