Spacecadetchickn
Everything posted by Spacecadetchickn
  1. I've got this trans in a 91 leggy with a 4.111 tag on the rear and no bind issues.... More confirmation lol!
  2. Ok so probably not my issue.... Now the only wires I cut were to the evap box in the back because it was mangled anyway. Does power go to the evap box then to the FP? Pump turns on with a hardwire but not connected normally. Also does not explain the absence of a CEL when ignition is on. Thinking with my fingers sorry.
  3. I deleted the abs ... No airbags and what's the select monitor?
  4. Good stuff man.. Friend of mine is getting ready to do this with a 2.2 and hi low 5 spd. If you ever bring it out to the couve pm me so he could check it out...
  5. Some other pics of the leggy...she sits this way now
  6. Not too worried about a cel for that as my understanding is it should run fine without those... I haven't been able to get a cel at all since the swap... I'm pretty sure these have something to do with it. Not sure what they are/do...(not the check connectors)
  7. Hey guys I have 2 issues.. After a swap I'm missing a control unit under the dash( not sure what it is/does... And I don't have the fuel pump working ...(might b related) please help... Btw I took a 94 legacy sedan lsi chassis and put a 99OBW drivetrain(motor/trams/diff axles sturs hubs tires etc. aswell as the entire body harness fuel pump and dash.. Big frenchin project by yourself!( I did not use the OB gas tank, evap box, or drvr side sending unit. I'll post some pics when I figure out how! Lol!
  8. Oops my dislexia kicked on my button pushing.. Sorry .. Moderators please move:)
  9. Hello all. Been looking on the site for years but now I have a question so I signed up lol. First, I had a 1994 legacy lsi 4wd 2.2 at...and swapped in a (donor)99 ouback drivetrain 2.5d/at ( motor tranny diff axles hubs struts tires etc and yes it's lifted) I also did the dash swap with the whole ob harness(body dash gas tank engine bay).... It's sitting on the ground now and all I have left to do is the wire the pwr lock/ windows and figure out the fuel...which is my issue... Harness is all plugged in... I used the ob fuel pump in the 94 legacy tank) so, I have no cel, no fuel going to the motor and I'm not sure why. Also noteworthy, I did not use the evap box behind the pass side rear wheel( was smashed in the wreck. Please help... I'm stumped on the 2 month endeavor
