The solution to my stripped idler bosses...
Drill the idler bolt bosses out to 29/64" and tap the holes to 1/2"x20TPI, 1" deep...
Cut a 4" length of 1/2"X20TPI all-thread and chuck it up in the lathe 3-jaw with 1" or so running free...
Face it, center drill it, then drill it to a depth of 1.15" with a 1/4" drill.
Next, finish out the hole with an S drill, and tap it to M10 -1.25...part the piece at 1" length,
Set it aside and repeat the drilling, tapping, and parting process 2 more times.
Blow out the chips from the new threads in the bosses as well as from the sleeves then
give them all a blast with ether to clean and prime the threads for the Locktite...
Place a jam nut on each mounting bolt and run the sleeve on 5 or 6 threads then jam it
fairly tight... screw the jam bolted sleeves into the block to test each for depth and flush
final fit. Now you're ready...
Coat the internal block and external sleeve threads with Red Locktite, making sure both surfaces are lightly
yet completely coated. Keeping any excess glue clear of the area where the jam nut will rest, slowly
tighten the bolt until the jam nut is snugged tight against the clean surface of the boss. Let it cure for
24 hours. Using 2 wrenches, release the jam nut and remove the bolt. You now have tight,
forward loaded inserts that are at least as strong as the original threads and fully capable of
taking the 26-32 ft.lbs of torque for secure idler operation.
Cost: about 6 bucks. (with the proper equipment of course.)
JT
