Terryduper
  1. Overhaul your engine with the help of a mechanic and make sure that oil id filled in your engine area with proper coolant fill In radiator, so if your valve are sticking due to lack of oil or overheating it will resolve by this overhaul. If still some problem occurs, as you said one cylinder is working at startup. Than swap the cylinder parts like piston or block or rebuild them to make your car engine work proper. Prior knowledge source – www.hiperformer.com/engine_basics/how_engine_works.html complete guideline for engine repair.
  2. Check with different online auto parts dealer to find whether your auto part is available in their inventory list. Usually, I prefer to consider www.hiperformer.com/where-to-go for any sort of purchase or vehicle related assistance. They are one of the well known online dealers in US automobile auto parts world with their huge network to wrecking yard from all over nation.
  3. You should check this online dealer http://www.hiperformer.com/automotive to get your engine or other parts as you need. You can check their inventory with listed different car model auto parts available there.You
  4. As such there are a number of online dealers who can provide you this part. Still I will suggest you to go through http://www.hiperformer.com/where-to-go/ this is because they have huge network of Hiperformer dealer from top wrecking yards nationwide and also have used auto parts for different car models.
