Everything posted by disom93
80 brat brake issue
Ok guys need some urgent help. My brakes about a week ago pulled to the left when mash them and then it quit an now today the right side caliper stuck. There new calipers. Whats going on
Brat dome light
Any one give pointers on getting the cover off without breaking it
Brat dome light
Ok is their a trick to gettin the dome cover off? I couldnt get it to budge
Brat dome light
Haha its the only thing on my brat that doesnt work other then cassette and it annoys me
Brat dome light
Anyone know if the interior light off my 80 brat works off a door switch? Mine doesnt work at all just wonderinf how to get it to work
which distributor for brat?
Not to derail a thread but im about to order a ea81 disty for my brat ea71 what exactly will i need to make this work? Planning a msd coil and wires also
80 brat brake issue
Ok i cleaned em out with the pressure washer and seems ok now thanks
brat horible fuel milage
And no i didnt add 10% to that number. I was just excited to get better. I have a rebuild and throttle bushings cominf maybe help some
Yes stater is on top. And i think tires may be alot of it
I have a rebuild kit and throttle shaft bearings coming for my weber as we speak
Ok thanks
Electronic distributor swap for EA63 and EA71 vehicles
Did the link ever work?
Is there any signs as to telling if the cap and or rotor is bad?
Ok i pm u about something broke inside disty i havent had a straight answer as to what it is
The non ethanol is hard to find here i ran high trst this tank so well see how it does. It has new wires plugs filters. I did notice when settkng the mixture if my screwdriver touched the wires at the cap it would are off the screw driver to metal. Is this normal?
Any other tricks i can try? Would like to get it up a little
Just an update. Adjusted the choke some and drove it amd this tank it hot 17mpg arouns 5 mpg mote
80 brat brake issue
The brakes have worked good for 4 months no issues just all a sudden it started this
80 brat brake issue
Ny brat just started pulling to the left when i mash the brake hard? Has new calipers and pads anyone have any idea?
weber throttle play
Checked all hoses i may to the spray trick.
weber throttle play
Have so play in the throttle shaft on my weber 32-36 will the throttle shaft bearing kits fix this? Could this also be my random idle issue
I cant seem to find out what the piece is exactly. And i set the lean best idle on the weber today and it seems to idle snd sound better i guess well see
Do you think the coil could be bad making it get horrible fuel milage? Im stumped and some plastic piece in distributor is broke its black has holes in it its under the pickup and mounts for it its a black plastic piece
Can these adjuatments be made on the car?
Ok do you think its the tires + not cruising far causing the bad milage?
